Hello everyone,
I’m trying to implement generic STM32F070CBTx board and my build is failing because it includes the startup file from another variant, namely MALYANMx00_F070CB. The build output looks like this:
Processing stm32f070cbtx (framework: arduino; platform: ststm32; board: genericSTM32F070CBTx)
Library Manager: Installing git+https://github.com/banoz/PSM.Library.git#feature/timer
git version 2.46.0.windows.1
Cloning into 'C:\Users\Vas\.platformio\.cache\tmp\pkg-installing-qt48g2sy'...
remote: Enumerating objects: 13, done.
remote: Counting objects: 100% (13/13), done.
remote: Compressing objects: 100% (10/10), done.
remote: Total 13 (delta 0), reused 8 (delta 0), pack-reused 0 (from 0)
Receiving objects: 100% (13/13), 4.30 KiB | 880.00 KiB/s, done.
Library Manager: PSM@0.0.1+sha.8a920d6 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F070CBTx.html
PLATFORM: ST STM32 (17.5.0) > Generic STM32F070CBTx
HARDWARE: STM32F070CBT6 48MHz, 16KB RAM, 128KB Flash
DEBUG: Current (stlink) External (cmsis-dap, jlink, stlink)
- framework-arduinoststm32 @ 4.20801.240815 (2.8.1)
- framework-cmsis @ 2.50900.0 (5.9.0)
- toolchain-gccarmnoneeabi @ 1.120301.0 (12.3.1)
Found 15 compatible libraries
|-- PSM @ 0.0.1+sha.8a920d6
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\PeripheralPins.c.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\generic_clock.c.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\startup_Mx00_f070xb.S.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\startup_stm32f070xb.s.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\variant_MALYANMx00_F070CB.cpp.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduinoVariant\variant_generic.cpp.o
Compiling .pio\build\stm32f070cbtx\SrcWrapper\src\HAL\stm32yyxx_hal.c.o
Compiling .pio\build\stm32f070cbtx\SrcWrapper\src\HAL\stm32yyxx_hal_adc.c.o
Compiling .pio\build\stm32f070cbtx\SrcWrapper\src\HAL\stm32yyxx_hal_adc_ex.c.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduino\wiring_shift.c.o
Compiling .pio\build\stm32f070cbtx\FrameworkArduino\wiring_time.c.o
Archiving .pio\build\stm32f070cbtx\libFrameworkArduino.a
Linking .pio\build\stm32f070cbtx\firmware.elf
c:/users/vas/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/stm32f070cbtx/FrameworkArduinoVariant/startup_stm32f070xb.s.o:(.isr_vector+0x0): multiple definition of `g_pfnVectors'; .pio/build/stm32f070cbtx/FrameworkArduinoVariant/startup_Mx00_f070xb.S.o:(.isr_vector+0x0): first defined here
c:/users/vas/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/stm32f070cbtx/FrameworkArduinoVariant/startup_stm32f070xb.s.o: in function `Default_Handler':
(.text.Default_Handler+0x0): multiple definition of `Default_Handler'; .pio/build/stm32f070cbtx/FrameworkArduinoVariant/startup_Mx00_f070xb.S.o:(.text.Default_Handler+0x0): first defined here
*** [.pio\build\stm32f070cbtx\firmware.elf] Error 1
As you can see it collects both .s files, as well as both variant_*.cpp files.
As soon as I remove the startup_Mx00_f070xb.S from the variant folder it compiles successfully.
I tried using build_src_filter but with no success, and this wouldn’t look pretty anyways.
Is it possible to filter out these files at all? What am I missing?
