After i upload the code into the arduino, i get the notification that the device has disconnected improperly. Eventhought the code get uploaded into the arduino, the arduino will not be identified anymore. The only way to make it identifiable again is to factory-reset the board, following this guide https://docs.arduino.cc/tutorials/nano-rp2040-connect/rp2040-01-technical-reference#forcing-bootloader. Moreover this problem dosen’t seem to happen with the arduino IDE.
- Executing task: platformio run --target upload --upload-port /dev/cu.usbmodem1201
Processing nanorp2040connect (platform: raspberrypi; board: nanorp2040connect; framework: arduino)
Verbose mode can be enabled via-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Raspberry Pi RP2040 (1.8.0) > Arduino Nano RP2040 Connect
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 3.5.4
- tool-openocd-raspberrypi @ 2.1100.0 (11.0)
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 41 compatible libraries
Scanning dependencies…
|-- Adafruit NeoPixel @ 1.11.0
|-- neopixel_led
Checking size .pio/build/nanorp2040connect/firmware.elf
RAM: [== ] 15.3% (used 41452 bytes from 270336 bytes)
Flash: [ ] 0.2% (used 4158 bytes from 2097152 bytes)
Configuring upload protocol…
AVAILABLE: cmsis-dap, jlink, picotool, raspberrypi-swd
CURRENT: upload_protocol = picotool
Looking for upload port…
Using manually specified: /dev/cu.usbmodem1201
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem1201
Uploading .pio/build/nanorp2040connect/firmware.elf
rp2040load 1.0.1 - compiled with go1.15.8
…Loading into Flash: [ ] 0%
Loading into Flash: [= ] 5%
Loading into Flash: [=== ] 10%
Loading into Flash: [==== ] 15%
Loading into Flash: [====== ] 20%
Loading into Flash: [======= ] 25%
Loading into Flash: [========= ] 30%
Loading into Flash: [========== ] 35%
Loading into Flash: [============ ] 40%
Loading into Flash: [============= ] 46%
Loading into Flash: [=============== ] 51%
Loading into Flash: [================ ] 56%
Loading into Flash: [================== ] 61%
Loading into Flash: [=================== ] 66%
Loading into Flash: [===================== ] 71%
Loading into Flash: [====================== ] 76%
Loading into Flash: [======================== ] 81%
Loading into Flash: [========================= ] 86%
Loading into Flash: [=========================== ] 92%
Loading into Flash: [============================= ] 97%
Loading into Flash: [==============================] 100%
=============================================================================================================================================== [SUCCESS] Took 3.30 seconds ===============================================================================================================================================
* Executing task: platformio run --target upload --upload-port /dev/cu.usbmodem1201
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/nanorp2040connect.html
|-- neopixel_led
Looking for upload port...
*** [upload] Error 1
=============================================================================================================================================== [FAILED] Took 11.64 seconds ===============================================================================================================================================
* The terminal process "platformio 'run', '--target', 'upload', '--upload-port', '/dev/cu.usbmodem1201'" terminated with exit code: 1.
As you can see after the first upload the bord is not seen anymore. It must be something related to platformIO because i don’t have this problem with the arduino ide.
Thank you in advance, any help is appreciated.
