I’ve been using VSC and PlatformIO for a while now with Arduino nanos without issue, however with the latest boards I’m getting from China I cannot get Platform IO to upload any code.
It works from Arduino IDE fine, but not from PIO.
Executing task: platformio run --target upload <
Processing nano (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr 5.1.0
Found 6 compatible libraries
|-- <DIO2> 1.6.0
Compiling .pio/build/nano/src/main.cpp.o
Compiling .pio/build/nano/libf1a/DIO2/digital2.c.o
Archiving .pio/build/nano/libFrameworkArduinoVariant.a
Compiling .pio/build/nano/FrameworkArduino/CDC.cpp.o
Indexing .pio/build/nano/libFrameworkArduinoVariant.a
Compiling .pio/build/nano/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/nano/FrameworkArduino/HardwareSerial0.cpp.o
Compiling .pio/build/nano/FrameworkArduino/HardwareSerial1.cpp.o
Compiling .pio/build/nano/FrameworkArduino/HardwareSerial2.cpp.o
Compiling .pio/build/nano/FrameworkArduino/HardwareSerial3.cpp.o
Compiling .pio/build/nano/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/nano/FrameworkArduino/PluggableUSB.cpp.o
Compiling .pio/build/nano/FrameworkArduino/Print.cpp.o
Archiving .pio/build/nano/libf1a/libDIO2.a
Compiling .pio/build/nano/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/nano/FrameworkArduino/Tone.cpp.o
Compiling .pio/build/nano/FrameworkArduino/USBCore.cpp.o
Compiling .pio/build/nano/FrameworkArduino/WInterrupts.c.o
Compiling .pio/build/nano/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/nano/FrameworkArduino/WString.cpp.o
Compiling .pio/build/nano/FrameworkArduino/abi.cpp.o
Indexing .pio/build/nano/libf1a/libDIO2.a
Compiling .pio/build/nano/FrameworkArduino/hooks.c.o
Compiling .pio/build/nano/FrameworkArduino/main.cpp.o
Compiling .pio/build/nano/FrameworkArduino/new.cpp.o
Compiling .pio/build/nano/FrameworkArduino/wiring.c.o
Compiling .pio/build/nano/FrameworkArduino/wiring_analog.c.o
Compiling .pio/build/nano/FrameworkArduino/wiring_digital.c.o
Compiling .pio/build/nano/FrameworkArduino/wiring_pulse.S.o
Compiling .pio/build/nano/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/nano/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/nano/libFrameworkArduino.a
Indexing .pio/build/nano/libFrameworkArduino.a
Linking .pio/build/nano/firmware.elf
Checking size .pio/build/nano/firmware.elf
RAM: [= ] 9.9% (used 202 bytes from 2048 bytes)
Flash: [= ] 11.4% (used 3504 bytes from 30720 bytes)
Building .pio/build/nano/firmware.hex
AVAILABLE: arduino
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/nano/firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
Logs from Arduino:
avrdude: Version 6.3-20190619
System wide configuration file is "/mnt/500GB-Linux/Downloads/arduino-1.8.15/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/greg/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: reading input file "/home/greg/nfs/PlatformIO/2114 RAM Tester/.pio/build/nano/firmware.hex"
avrdude: writing flash (3504 bytes):
Writing | ################################################## | 100% 0.57s
avrdude: 3504 bytes of flash written
avrdude: verifying flash memory against /home/greg/nfs/PlatformIO/2114 RAM Tester/.pio/build/nano/firmware.hex:
avrdude: load data flash data from input file /home/greg/nfs/PlatformIO/2114 RAM Tester/.pio/build/nano/firmware.hex:
avrdude: input file /home/greg/nfs/PlatformIO/2114 RAM Tester/.pio/build/nano/firmware.hex contains 3504 bytes
Reading | ################################################## | 100% 0.45s
avrdude: verifying ...
avrdude: 3504 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
VSC:
Version: 1.61.2
Commit: 6cba118ac49a1b88332f312a8f67186f7f3c1643
Date: 2021-10-19T14:58:13.605Z
Electron: 13.5.1
Chrome: 91.0.4472.164
Node.js: 14.16.0
V8: 9.1.269.39-electron.0
OS: Linux x64 5.11.0-37-generic
platformio.ini
[env:nano]
#board = nanoatmega168
board = nanoatmega328
upload_flags = -V
Any else having similar issues? Not sure where to look next.
