Hi Guys and Girls,
I have been struggling a bit moving from the arduino IDE to platformio. The interface is awesome and everything is soo much better than arduino. Everything is working when I move it over except for the modbus interface.
I am assuming arduino is doing something on the background that I am missing on this side.
Please see the basic example that is working on arduino but not on platformio below:
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
const int numCoils = 100; //Relay1, Relay2, Digital Out1, Digital Out2
const int numHoldingRegisters = 100; //ADC Measure, Timestamp?,
const int numDevices = 2;
Serial.begin(9600);
Serial2.begin(9600); //need to open the serial port to allow RS485 communication
// start the Modbus RTU server, with (slave) id 1
if (!ModbusRTUServer.begin(1, 9600)) {
Serial.println("Failed to start Modbus RTU Server!");
while (1);
// configure the LED
//pinMode(ledPin, OUTPUT);
//digitalWrite(ledPin, LOW);
//configure coil registers at address 0x00
ModbusRTUServer.configureCoils(0x0, numCoils);
//configure discrete inputs at address 0x00
ModbusRTUServer.configureDiscreteInputs(0x00, numCoils);
//configure holding registers at address 0x00
ModbusRTUServer.configureHoldingRegisters(0x00, numHoldingRegisters);
// configure input registers at address 0x00
ModbusRTUServer.configureInputRegisters(0x00, numHoldingRegisters);
Serial.println("Started Modbus RTU Server!");
// poll for Modbus RTU requests
ModbusRTUServer.poll();
//Serial.println(UpdateRegisters());
Please let me know if you have any ideas? I changed the rs485 library to point to serial 2. Could it be that Iâm not pointing it correctly?
Regards,
Bart
You did not explain how exactly you see that itâs not working. What is the exact difference in behavior? Any error messages?
Also thereâs a lot of info missing.
- what version of the ArduinoModbus library is being used in the Arduino IDE (look in the library manager)
- what version of ArduinoRS485 is used in the Arduino IDE?
- what version is the ESP32 core in the Arduino IDE?
- are you running the exact same sketch in PlatformIO and Arduino IDE?
- you say you modified the RS485 library. What ere the exact code changes? Are you using the same modified library in the Arduino IDE as well as in PlatformIO? How did you include the modified library in PlatformIO?
- What is the
platformio.ini
- What are the board settings (âToolsâ menu) in the Arduino IDE?
Hi, thanks for coming back to me ![:slight_smile: :slight_smile:](https://community.platformio.org/images/emoji/twitter/slight_smile.png?v=12)
Please see answers to your questions below:
You did not explain how exactly you see that itâs not working. What is the exact difference in behaviour? Any error messages?
It seems to have similar warnings regarding the âconfigâ variable being truncated in the RS485 class. A uint32 is being used but a uint16 is being expected. So everything looks similar.
But on the arduino ide I am able to use modpoll to send and receive data to the device. Unfortunately I only get timeouts on the platformio side.
V1.0.3
ArduinoRS485: V1.0.0
On platformio I am using the latest versions:
ArduinoModbus 1.0.6
ArduinoRS485 1.0.1
Are you running the exact same sketch in PlatformIO and Arduino IDE?
Yes I am.
You say you modified the RS485 library. What where the exact code changes?
Changes were made in the RS485.cpp file, line 181 from
//RS485Class RS485(SERIAL_PORT_HARDWARE, RS485_DEFAULT_TX_PIN, RS485_DEFAULT_DE_PIN, RS485_DEFAULT_RE_PIN);
to
RS485Class RS485(Serial2, 17, 21, 5);
I just made the changes in the file that is located in the libdeps folder. I assumed this should be ok?
What is the platformio.ini?
arduino-libraries/ArduinoRS485@^1.0.1
arduino-libraries/ArduinoModbus@^1.0.6
I hope this helps.
What about this one? (See Tools â Boards â Board Manager â ESP32)
Hi Gerhardt,
Iâm not able to see the core package via the arduino ide because I pulled it down manually via git. But looking in the folder I am able to find the following in the platform text file:
name=ESP32 Arduino
version=2.0.0
I hope that helps. Please send some suggestions if you have any. ![:slight_smile: :slight_smile:](https://community.platformio.org/images/emoji/twitter/slight_smile.png?v=9)
Regards,
Bart
With the latest Espressif32 platform version in PlatformIO (see releases) youâre getting Arduino core 1.0.6. So in total, youâre using a different Arduino core version and the two libraries are also of different versions.
You can do a quick check whether it also not works when you select 1.0.6 as the ESP32 core version in thte Arduino IDE.
Otherwise I suggest equalizing all options between the Arduino IDE and PlatformIO, comparison is not otherwise possible.
You should try this platformio.ini
, which will give you the latest master-branch version of Arduino-ESP32 and the library versions equal to what you use in the Arduino IDE.
First, delete the .pio
folder of the project, then paste in that platformio.ini
arduino-libraries/ArduinoRS485@1.0.0
arduino-libraries/ArduinoModbus@1.0.3
platform_packages =
toolchain-xtensa32 @ ~2.80400.0
framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#master
platformio/tool-esptoolpy @ ~1.30100
and build once. Cloning of the newer version will take some time. Then, you will have to re-do your library modifications in .pio\libdeps\esp32dev\ArduinoRS485
. (to make the changes permanent, its better to pull the ArduinoRS485 folder into lib/
, .pio
is a temporary folder).
Hi Gerhardt,
Thanks so much for the help. Youâre a genius! Works like a charm!!
Iâll keep track of the library versions in the future. I wasnât sure if there is a one to one correlation between the two systems. So thanks for teaching me the basics.
Again, thanks so much for making the platform awesome and keeping on supporting and building it.
Regards,
Bart
