I tried to run my m5 stack core with platformio and arduino framework, but when I build, got this error :
In file included from C:/Users/joach/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:24,
from src/main.cpp:1:
c:\users\joach.platformio\packages\toolchain-xtensa-esp32\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdint.h:9:16: fatal error: stdint.h: No such file or directory
I checked this, but file is existing.
Are there things with installing, that leads to this error? br joachim
With what platformio.ini is that?
this one:
[env:m5stack-core-esp32]
board = m5stack-core-esp32
br joachim
Okay that should definitely not be failing. Please remove the folders
c:\users\joach\.platformio\packages\toolchain-xtensa-esp32
C:/Users/joach/.platformio/.cache
and build the project again to get a clean redownload of compiler + framework.
Hi Max, fine. Now it is working. Have I made something wrong during init? br joachim
