Hi there,
I am quite new to using PlatformIO with Arduino as a IDF component. After long struggles I finally succeeded to have it working in general. Now I have issues to use an Arduino library (“Adafruit BMP3XX”) in this context.
Building fails with:
.pio/libdeps/lolin_d32_pro/Adafruit Unified Sensor/Adafruit_Sensor.cpp: In member function 'void Adafruit_Sensor::printSensorDetails()':
.pio/libdeps/lolin_d32_pro/Adafruit Unified Sensor/Adafruit_Sensor.cpp:11:3: error: 'Serial' was not declared in this scope
Serial.println(F("------------------------------------"));
.pio/libdeps/lolin_d32_pro/Adafruit Unified Sensor/Adafruit_Sensor.cpp:11:18: error: 'F' was not declared in this scope
*** [.pio\build\lolin_d32_pro\lib149\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o] Error 1
To reproduce it should be sufficient to generate a new esp-idf project and use this platformio.ini:
[env:lolin_d32_pro]
board = lolin_d32_pro
framework = arduino, espidf
monitor_filters = default, printable
monitor_flags = --raw
platform_packages =
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#idf-release/v4.0
adafruit/Adafruit BMP3XX Library@^2.0.2
adafruit/Adafruit BusIO@^1.7.2
; needed for Adafruit_BusIO to compile (ESP32 define is missing else -> "'BitOrder' has not been declared")
; https://community.platformio.org/t/add-arduino-library-to-esp-idf-with-arduino-core-as-component/18562/4
-D ESP32
and this main.cpp:
extern “C” void app_main(void) {}
You will have to use menuconfig to enable:
Component config -> mbedTLS -> TLS Key Exchange Methods-> Enable pre-shared-key ciphersuites
That’s about it. Cam anybody help me to tackle that issue?
Thanks in advance!
Keith
