Arduino leonardo timer made with register not recognized
Hi The idea is of having an IRQ every 16 mSec using an old board Leonardo of arduino.
The question is why it not recognize the registers
int16_t button_store;
//Let’s setup a interrupt that will check the key inputs on the analog input A0.
TCCR2A = 0; //Make sure that the TCCR2A register is set to zero
TCCR2B = 0; //Make sure that the TCCR2A register is set to zero
TIMSK2 |= (1 << OCIE2A); //Set the interupt enable bit OCIE2A in the TIMSK2 register
//Set the CS20, CS21 and CS22 bit in the TCCRB register to set the prescaler to 1024
TCCR2B |= (1 << CS22|1 << CS21|1 << CS20);
//The compare register is set to 249 => 16ms / (1s / (16.000.000MHz / 1024)) - 1 = 249
OCR2A = 249;
TCCR2A |= (1 << WGM21); //Set counter 2 to CTC (clear timer on compare) mode
ISR(TIMER2_COMPA_vect){
if(button_store == -1)button_store = analogRead(0);
if(button_store > 1000)button_store = -1;
platformio.ini
[env:leonardo]
board = leonardo
=========MKING IT RESULT
src\main.cpp: In function ‘void setup()’:
src\main.cpp:9:3: error: ‘TCCR2A’ was not declared in this scope
src\main.cpp:9:3: note: suggested alternative: ‘TCCR0A’
TCCR0A
src\main.cpp:10:3: error: ‘TCCR2B’ was not declared in this scope
src\main.cpp:10:3: note: suggested alternative: ‘TCCR0B’
TCCR0B
src\main.cpp:11:3: error: ‘TIMSK2’ was not declared in this scope
src\main.cpp:11:3: note: suggested alternative: ‘TIMSK0’
TIMSK0
src\main.cpp:11:19: error: ‘OCIE2A’ was not declared in this scope
src\main.cpp:11:19: note: suggested alternative: ‘OCIE0A’
OCIE0A
src\main.cpp:12:19: error: ‘CS22’ was not declared in this scope
TCCR2B |= (1 << CS22|1 << CS21|1 << CS20); //Set the CS20, CS21 and CS22 bit in the TCCRB register to set the prescaler to 1024
src\main.cpp:12:19: note: suggested alternative: ‘CS12’
CS12
src\main.cpp:12:29: error: ‘CS21’ was not declared in this scope
src\main.cpp:12:29: note: suggested alternative: ‘CS01’
CS01
src\main.cpp:12:39: error: ‘CS20’ was not declared in this scope
src\main.cpp:12:39: note: suggested alternative: ‘CS00’
CS00
src\main.cpp:13:3: error: ‘OCR2A’ was not declared in this scope
OCR2A = 249; //The compare register is set to 249 => 16ms / (1s / (16.000.000MHz / 1024)) - 1 = 249
src\main.cpp:13:3: note: suggested alternative: ‘OCR3A’
OCR3A
src\main.cpp:14:19: error: ‘WGM21’ was not declared in this scope
src\main.cpp:14:19: note: suggested alternative: ‘WGM41’
WGM41
In file included from C:\Users\gsrad.platformio\packages\framework-arduino-avr\cores\arduino/Arduino.h:30:0,
from src\main.cpp:1:
src\main.cpp: In function ‘void TIMER2_COMPA_vect()’:
src\main.cpp:22:5: warning: ‘TIMER2_COMPA_vect’ appears to be a misspelled ‘signal’ handler, missing ‘__vector’ prefix [-Wmisspelled-isr]
Adding these no difference
#include <avr/io.h>
#include <avr/interrupt.h>
The Leonardo has a differnt MCU (ATmega32U) than the UNO has (ATmega328).
The ATmega32 doesn’t have a Timer2! It has the timers 0, 1, 3, and 4 but not a timer 2!
Ok solved replaced Timer2 with Timer1
