I tried to run this file:
Serial.begin(9600);
Serial.println(“Hello world!”);
Quite a basic code, I know, it was only for testing board, but I got error which I can’t solve:
C:\Users\Uldis.platformio\packages\framework-arduino-avr\cores\arduino\USBCore.cpp:73:29: error: ‘USB_VID’ was not declared in this scope
C:\Users\Uldis.platformio\packages\framework-arduino-avr\cores\arduino\USBCore.cpp:73:37: error: ‘USB_PID’ was not declared in this scope
Unable to reproduce.
>pio run
Processing leonardo (platform: atmelavr; board: leonardo; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/leonardo.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Leonardo
HARDWARE: ATMEGA32U4 16MHz, 2.50KB RAM, 28KB Flash
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Compiling .pio\build\leonardo\src\main.cpp.o
Compiling .pio\build\leonardo\FrameworkArduino\abi.cpp.o
Compiling .pio\build\leonardo\FrameworkArduino\hooks.c.o
Compiling .pio\build\leonardo\FrameworkArduino\main.cpp.o
Compiling .pio\build\leonardo\FrameworkArduino\new.cpp.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring.c.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\leonardo\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\leonardo\libFrameworkArduino.a
Indexing .pio\build\leonardo\libFrameworkArduino.a
Linking .pio\build\leonardo\firmware.elf
Checking size .pio\build\leonardo\firmware.elf
RAM: [= ] 6.4% (used 165 bytes from 2560 bytes)
Flash: [= ] 12.3% (used 3522 bytes from 28672 bytes)
Building .pio\build\leonardo\firmware.hex
============================================= [SUCCESS] Took 2.14 seconds =============================================
You may have corrupted your Arduino core package or platform somehow. Please remove the folders
C:\Users\Uldis\.platformio\packages\framework-arduino-avr\
C:\Users\Uldis\.platformio\platforms\atmelavr
And retry.
I solved a problem for myself. I saw that I was using basicaly a CONFIGURATION for just a chp - 32u4, but now I tried with using a MCU configuration: sparkfun_promicro16 and everything was solved with no problems.
Executing task in folder Atmega32U4_test: C:\Users\Uldis\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing leonardo (platform: atmelavr; board: sparkfun_promicro16; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sparkfun_promicro16.html
PLATFORM: Atmel AVR (3.4.0) > SparkFun Pro Micro 5V/16MHz
Found 7 compatible libraries
|-- <SomeSerial> 1.1.3
| |-- <SoftwareSerial> 1.0.0
Flash: [= ] 12.6% (used 3600 bytes from 28672 bytes)
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
Looking for upload port...
Auto-detected: COM7
Forcing reset using 1200bps open/close on port COM7
Waiting for the new upload port...
Uploading .pio\build\leonardo\firmware.hex
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file ".pio\build\leonardo\firmware.hex"
avrdude: writing flash (3600 bytes):
Writing | ################################################## | 100% 0.28s
avrdude: 3600 bytes of flash written
avrdude: verifying flash memory against .pio\build\leonardo\firmware.hex:
avrdude: load data flash data from input file .pio\build\leonardo\firmware.hex:
avrdude: input file .pio\build\leonardo\firmware.hex contains 3600 bytes
Reading | ################################################## | 100% 0.04s
avrdude: verifying ...
avrdude: 3600 bytes of flash verified
avrdude: safemode: Fuses OK (E:CB, H:D8, L:FF)
avrdude done. Thank you.
============================================================= [SUCCESS] Took 5.40 seconds =============================================================
