Hi, I have a problem with Arduino IOT cloud library ESP32 and PlatformIO.
Won`t compile and this is the error message :
“resource”: “/c:/Users/boRko/Desktop/arduinocloud proba/.pio/libdeps/esp32dev/WiFiNINA/src/utility/wifi_drv.h”,
“owner”: “cpp”,
“severity”: 8,
“message”: “‘PinStatus’ does not name a type”,
“startLineNumber”: 293,
“startColumn”: 12,
“endLineNumber”: 293,
“endColumn”: 12
Btw, its an empty sketch, it
s doing nothing, just connects to the Arduino IOT cloud and it works with Arduino IDE.
I don’t think the ESP32 needs a WiFiNINA library to communicate with the internet, likely the library isn’t used in this case. Add
lib_compat_mode = strict
(docs) to the platformio.ini
to try and filter out these non-compatible libraries. If that fails, lib_ignore
them, e.g. with lib_ignore = WiFiNINA
lib_compat_mode = strict is making more problems, but adding lib_ignore = WiFiNINA to platformio.ini, works and now compiles
Thanks a lot man, I didnt know that such command existed, I
m still new to coding and PlatformIO too.
Cheers!
The installation of non-needed dependencies for a library may also be related to Library dependencies installing for all platforms · Issue #4338 · platformio/platformio-core · GitHub, so hopefully that is fixed soon at the source.
