Using Adafruit Feather M0 and ILI9341 with SD card read/write breakout. I have compiled code that works with the TFT display and can read/write the SD card. But recently, code compiled on PlatformIO won’t access the SD card after a write to the TFT display. The same code compiled on Arduino IDE runs and accesses the SD card. Do I have something configured wrong?
Without your platformio.ini
, code, the used Arduino core version for your board, your Arduino IDE configuration and the versions of the libraries you used in the Arduino IDE there’s an almost 0% chance that anything meaningful can be said about your error.
