Arduino.h missing?
Hello, I see red squiggly lines under #include <Arduino.h>. The project will build but obviously this is not ideal. I have seen a few other posts with similar issues but no real resolutions were provided. Any idea where to start with troubleshooting this? Thank you.
What’s in your `platformio.ini’?
i.e. for a Arduino Uno it would look something like…
[env:uno]
board = uno
Sounds like my issue, which was solved by deleting the .vscode directory in the project folder and restarting vscode.
I have the same problem.
I have this problem too
PLEASE HELP !!! the minimum on a packet is explaining include paths
or do not advertise a c/C++ project. Making things complex leads to 1000 of different explanations all over the world With as only result people are more confused and more annoyed…
PLATFORM IO ADVICES tot add arduino.h At least explain how it is to be found !!!
If your project compiles properly (try pressing theBuild button), Arduino.h has been found, and you have once again been deceived by IntelliSense (which once again, has nothing to do with PlatformIO) into thinking there is something wrong with your project.
Arduino.h is part of the Arduino core, meaning that it does not need to be installed separately, and IntelliSense should find it as it is located in a standard include path. There is one caveat that I know of… if you have a new install of PlatformIO, and have NOT tried to build a project yet, it is possible the Arduino board support package has not been installed yet, making the error valid. However, PlatformIO will install it automatically as part of the dependency checks at the start of the build, hence everything will compile fine. If IntelliSense detects that the files are now present is another matter, but in this edge case, it should go away after a restart of the VSCode code editor.
Please offer some help on this FIRST STEP ISSUE
-Restarting platform IO after erasing is NO HELP
TELL ME
A) WHERE DO I FIND Arduino.H ( Needed by documentation as convertion change !!!0
B) HOw to get rid ONCE AND FOR EVER OF THE STUPID ERROR
in case it matters :slight_smile:
following HUGE CODE
#include <Arduino.h> ;//erase .vscode if it fails
Serial.println(“I am the HALL 2000 and I never made an error !”);
platformIO.ini
; Redirecting...
[env:ttgo-lora32-v1]
board = ttgo-lora32-v1
Please give something ONE CAN UNDERSTAND or EVEN BETTER WRITE A DOC THAT EXPLAINS
Platform IO is supposed to be platform independent ??? its so dependent on who knows what it does not even find its OWN SUGGESTION !
but on first use, proves completely useless because it is completely empty
goal: do arduino/esp32 development !!!
envir: windows 10
Vscode known and setup
Platform IO setup
ini file
  [env:esp-wrover-kit]
	board = esp-wrover-kit
	framework = espidf
	upload_options=COM4
code
code simplified
    #include <Arduino.h>    <<<<<<<<<<<<<<NOT FOUND  so somethinh about  include paths /libraries is not setup  correctly
  Serial.begin(115200);    <<<<<<<<<<<<<<<<<    Serial not defined confirms remark  above !!!!!!
  Serial.println("I am the HALL 2000 and I never made an error !");
There is NO C++ error but it can not start missing include paths and libraries
it sometimes comiles some of the libraries involved
THis is the basis of the basis AND I GET NO REAONABLE ANSWER IN MONTHS (big FRUSTRATION,Product worthless!!!)
Question as … where is Arduimo.h Library not found !!! … is crypticaly answered
explaining you should use TH library manager … but load WHAT
there is no respect for the beginner… it claims the include paths and library paths are NOT setup correctly.
upon asking for a way to setup include paths?libraries I getting the fourth degree.
Everyone can create MISTORIES THIS IS GETTING VERY ANNOYING THEY ARE NOT HELPFULL
IF ONE CAN USE THE LIBRARY MANAGER WHERE ARE THE FILES in ARDUINO (to copy) and to be placed in PLATFORMIO…
lib_extra_dirs =c:\Install\Arduino\Arduino\libraries <<<arduino install location
c:\use\Devlo\libraries
seems NOT HELPFULL AT ALL
What are the KEYWORDS to LOAD ties
		 a) THE core  arduino  library      ( ARDUINO.h, Serial .....)  there is enough doc how to find json , wifi ....
		    THE CORE  arduino  8266  libary ( ARDUINO.h, Serial .....)  there is enough doc how to find json , wifi ....
		    THE  CORE  ESP32    library     ( ARDUINO.h, Serial .....)  there is enough doc how to find json , wifi ....
		    THE CORE   RTOS  library        ( ARDUINO.h, Serial .....)  there is enough doc how to find json , wifi ....
		      all frameworks .... MINIMUM   ALL THE CORES !!!!!!
		  B)
		  		Can they be   inserted  with the  LIBRARY MANAGER  [ YES/ NO ]
		  		Can I Reuse   the arduino IDE  include/library  (same updates .... it takes MONTHS ... to get an answer from platform IO
		  		Can I add my OWN INCLUDES/LIBRARIES
		  		CAN I INSTALL THIS   ABOVE MY PROJECT (common to all MY projects )
		  C)    Arduino IDE is an all containing packet
		  		PLEASE  DOCUMENT  WHERE TO FIND  THESE CORE  LIBRARIES   !!!!!!
		 WILL THIS SOLVE  THE  ARDUINI.H  proroble m and simular   FOR EVER .....  [ YES /NO ]
	PLease  do NOT refer me to standards Using any off  the  utility libraries
	please   Platform IO  on its own caused  MONTHS of delay .... BE EXPLICT
				FOR  ARDUINO IDE   the y can be INTERNAL ( included in the packet !!!!)
				FOR  PLATFORM IO    THIS MUST BE EXPLICITELY DOCUMENTED  NOT INTERNAL IN THE PACKET
         Sorry  for the capitals  MONTHS frustration  ......
Why have you defined the framework as framework = espidf when you are doing Arduino code?
Change it to :
upload_port = COM4
And try compiling that code again. The IntelliSense (red squiggle underlines) should then go away, and compilation should be successful. If it compiles successfully, but the squiggles remain and there is stuff listed in the Problems tab then there is still something wrong with the Microsoft C/C++ extension’s IntelliSense configuration.
Addendum: upload_options is also not valid, it should have been upload_port.
Negatve it does not.
I m that hopeless i tried everything including all frameworks.
Need to know where it picks rhe libraries typicaly the arduino core libraries using esp32 mainly.
Os windows 10.
Leads to failed link --verbose without errors at random…
Even after 100 reinstalls…
Compilers do not do things randomly, so that is not the case.
With the following platformio.ini and main.cpp , what is the compiler output / build log?
platformio.ini:
upload_port = COM4
main.cpp:
  Serial.println("I am the HAL 2000 and I never made an error !");
  delay(100);
You should get something something like this. Post yours in the reply.
Processing esp-wrover-kit (platform: espressif32; board: esp-wrover-kit; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 1.12.0 > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Found 26 compatible libraries
Compiling .pio\build\esp-wrover-kit\src\main.cpp.o
Generating partitions .pio\build\esp-wrover-kit\partitions.bin
Archiving .pio\build\esp-wrover-kit\libFrameworkArduinoVariant.a
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\Esp.cpp.o
Indexing .pio\build\esp-wrover-kit\libFrameworkArduinoVariant.a
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp-wrover-kit\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp-wrover-kit\libFrameworkArduino.a
Indexing .pio\build\esp-wrover-kit\libFrameworkArduino.a
Linking .pio\build\esp-wrover-kit\firmware.elf
Retrieving maximum program size .pio\build\esp-wrover-kit\firmware.elf
Checking size .pio\build\esp-wrover-kit\firmware.elf
Building .pio\build\esp-wrover-kit\firmware.bin
esptool.py v2.6
RAM:   [          ]   4.7% (used 15436 bytes from 327680 bytes)
Flash: [==        ]  16.5% (used 216653 bytes from 1310720 bytes)
======================================================= [SUCCESS] Took 37.89 seconds =======================================================
It keeps coming back as soon as you re-edit the file!
EDITED/SOLUTION:
Disabled ’ C/C++ Clang Command Adapter, by Yasuaki MITANI’.
‘C/C++ for Visual Studio Code, by Microsoft’ seems to be doing the job…
I noticed that problem appeared after cmake installation… so I deleted cmake and extensions
What is your OS where you have installer PlatformIO ?
OS version / Linux Kernel ?
Missing arduino.h is still a problem with no solution. Tried all of the recommended hacks. No fix. It is unclear to me where I should look in vscode to add headers.
Deleting cmake is not really an option as removing cmake removes a bunch of other packages.
Fedora 41 Linux. vscode and platformio insalled in my home directory.
Thank you
RLH
platformip.ini
[env:lilygo-t-display]
board = lilygo-t-display
lib_deps = bodmer/TFT_eSPI@^2.5.43
main.cpp:
#include <TFT_eSPI.h>
TFT_eSPI tft=TFT_eSPI();
// put function declarations here:
int myFunction(int, int);
tft.init();
tft.setRotation(1);
tft.fillScreen(TFT_BLACK);
tft.drawString(“Hello world”, 30, 30, 2)
Build output:
Compiling .pio/build/lilygo-t-display/src/main.cpp.o
*** [.pio/build/lilygo-t-display/bootloader.bin] Source /home/harker/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin/bootloader_dio_40m.elf' not found, needed by target .pio/build/lilygo-t-display/bootloader.bin’.
src/main.cpp:1:10: fatal error: Arduino.h: No such file or directory
  • Looking for Arduino.h dependency? Check our library registry!
  • CLI > platformio lib search “header:Arduino.h”
  • Web > PlatformIO Registry
compilation terminated.
*** [.pio/build/lilygo-t-display/src/main.cpp.o] Error 1
==================================== [FAILED] Took 1.33 seconds ====================================
Looks like your framework is corrupted.
  • Close VS Code
  • Delete the framework-arduinoespressif32 folder (located in ~/.platformio/.platformio/packages/)
  • Restart VS Code
  • Wait until PIO finished all tasks
Thank you! Fixed it.
RLH
I know this is an old thread but I wanted to add one more hint. I had the squiggles under arduino.h in my project, followed all the suggestions and it still persisted. The project would build but I was really bothered by the squiggles.
Turns out intellisense is case sensitive on filenames but the build system is not. I had arduino.h instead of Arduino.h and that is why intellisense was unhappy.
One other thing to check for - we are using ESP32 and there was an ancient arduino.h file that got included from 2014 that was including mbed.h in the project. Well ESP32 uses FreeRTOS and not mbed, so I cleaned up all references to that very old library.
If you are still having squiggle issues, grep your project for case problems in filenames and make sure you are not including things that do not match your project framework (like mbed).
That depends to the OS you’re using.
Windows isn’t case sensitive, but Linux is.
