Hi all,
I’m trying to write a simple wrapper around ‘Serial.print’ so I can easily disable all my output messages in one go. I was also creating something a bit more powerful that would allow for multiple arguments.
I created this:
#define DEBUG_LOG(msg, ...) MsgOutImpl(msg, ##__VA_ARGS__)
void MsgOutImpl(const char* msg, ...)
char buff[256];
va_list argptr;
va_start(argptr, msg);
vsnprintf(buff, 256, msg, argptr);
Serial.println(buff);
Now, it seems to work fine for most things, however I was trying to print out float values and the output is a ‘?’.
So doing DEBUG_LOG("%f", 12.0f) will print ‘?’.
Target platform is: nanoatmega328new
Any ideas what may be going on here?
Thanks!
Floating point support depends on the used C library and flags. Without knowing the platform you’re compiling for (ststm32?) we cannot suggest a solution.
Ah sorry about that. This is targeting ‘nanoatmega328new’.
As discussed in https://blog.startingelectronics.com/floating-point-numbers-dont-print-sprintf-atmel-studio-avr-c/, you can see that you need to add
build_flags = -Wl,-u,vfprintf -lprintf_flt
to the platformio.ini to enable floating point printf support.
Got it, I’ll give it a go this evening.
Thanks a bunch.
Hi nachocpol,
it seems I have exactly the same problem that you describe, yet I don’t understand answer you got, I am targeting Arduino uno board using Arduino IDE
Please post your platformio.ini, src/main.cpp and serial output that you’re having problems with.
The solution was to add the buildflags mentioned by @maxgerhardt. If you are using the Arduino IDE I guess you need to find a way to add the flags there.
