Oof, there is some weirdness going on there. I had to fix two library.json errors in the Portenta H7 AsyncTCP library (Commits · maxgerhardt/Portenta_H7_AsyncTCP · GitHub) and ignored a bunch of non-fitting libraries. PlatformIO’s library dependency finder isn’t yet the best for these extreme cases.
You can use
[env:portenta_h7_m7]
platform = ststm32
board = portenta_h7_m7
khoih-prog/AsyncMQTT_Generic@^1.5.0
Portenta_H7_AsyncTCP=https://github.com/maxgerhardt/Portenta_H7_AsyncTCP/archive/refs/heads/withdeps.zip
Ethernet
SocketWrapper
;lib_compat_mode = strict
lib_ldf_mode = deep+
lib_ignore =
STM32Ethernet
STM32duino LwIP
WiFi
Teensy41_AsyncTCP
ESPAsync_WiFiManager
WebServer_WT32_ETH01
STM32AsyncTCP
AsyncTCP_SSL
as the platformio.ini
with src/main.cpp
from AsyncMQTT_Generic/FullyFeatured_PortentaH7_Ethernet.ino at main · khoih-prog/AsyncMQTT_Generic · GitHub but with added
at the top, and src/defines.h
straight from AsyncMQTT_Generic/defines.h at main · khoih-prog/AsyncMQTT_Generic · GitHub.
Which should get you to
Linking .pio\build\portenta_h7_m7\firmware.elf
Checking size .pio\build\portenta_h7_m7\firmware.elf
RAM: [= ] 12.1% (used 63136 bytes from 523624 bytes)
Flash: [=== ] 25.3% (used 199200 bytes from 786432 bytes)
Building .pio\build\portenta_h7_m7\firmware.bin
Adding dfu suffix to firmware.bin
dfu-suffix (dfu-util) 0.9
Copyright 2011-2012 Stefan Schmidt, 2013-2014 Tormod Volden
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Suffix successfully added to file
==============================[SUCCESS] Took 37.07 seconds ==============================[
Edit Simplified platformio.ini
, no more build_flags
, reordered includes – don’t include Portenta_H7_AsyncTCP.h
in src/main.cpp
after all.
