I’m having trouble using a library from the registry: AsyncMqtt_Generic for the portenta_H7_m7 board. The author has provided examples and and a platformio.ini file, but even though they do compile in the Arduino IDE, they do not compile in Platform IO. I have reached out to the author, and he sugested this forum.
The problem seems to be wrong/missing dependencies, the first error I get is a fatal error: stm32_def.h: No such file or directory.
This goes away if I add board_build.core = maple to the ini file, but this results in errors like: fatal error: Udp.h: No such file or directory fatal error: Arduino.h: No such file or directory fatal error: IPAddress.h: No such file or directory
… and also in the C/C++ configurations: Cannot find: C:/Users/Marius/.platformio/packages/framework-arduino-mbed/cores/maple
I have a feeling that this is related to the package Arduino_Core_STM32 not being correctly installed, but I can’t figure out how to install this…
Any tips on how I should proceed to fix these issues?
Oof, there is some weirdness going on there. I had to fix two library.json errors in the Portenta H7 AsyncTCP library (Commits · maxgerhardt/Portenta_H7_AsyncTCP · GitHub) and ignored a bunch of non-fitting libraries. PlatformIO’s library dependency finder isn’t yet the best for these extreme cases.
Linking .pio\build\portenta_h7_m7\firmware.elf
Checking size .pio\build\portenta_h7_m7\firmware.elf
RAM: [= ] 12.1% (used 63136 bytes from 523624 bytes)
Flash: [=== ] 25.3% (used 199200 bytes from 786432 bytes)
Building .pio\build\portenta_h7_m7\firmware.bin
Adding dfu suffix to firmware.bin
dfu-suffix (dfu-util) 0.9
Copyright 2011-2012 Stefan Schmidt, 2013-2014 Tormod Volden
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Suffix successfully added to file
==============================[SUCCESS] Took 37.07 seconds ==============================[
Edit Simplified platformio.ini, no more build_flags, reordered includes – don’t include Portenta_H7_AsyncTCP.h in src/main.cpp after all.
Hello @maxgerhardt , thank you so much for replying.
The old errors are gone, but now instead I get errors related to WifiClient.h: fatal error: WiFiClient.h: No such file or directory
I don’t need wifi, but I tried removing it from the ignore list in platformio.ini anyway, now the build doesn’t fail until the linking phase where it stops with:
.pio\build\portenta_h7_m7\libc9a\libEthernet.a(Ethernet.cpp.o):(.bss.Ethernet+0x0): multiple definition of `Ethernet'
.pio\build\portenta_h7_m7\lib47c\libEthernet.a(Ethernet.cpp.o):(.bss.Ethernet+0x0): first defined here
*** [.pio\build\portenta_h7_m7\firmware.elf] Error 1
Also I get a waring early on related to the AsyncTCP library, I guess the link to your fork is the issue?
Library Manager: Warning! Could not install dependency {'owner': 'khoih-prog', 'name': 'Portenta_H7_AsyncTCP', 'version': '>=1.3.0', 'platforms': ['ststm32']} for package 'AsyncMQTT_Generic'
Even after deleting .pio I still get the same errors.
Wifi ignored fatal error: WiFiClient.h: No such file or directory
Wifi not ignored:
I’m sorry, which files or folders should I delete?
I tried deleting the whole Ethernet folder \.pio\libdeps\portenta_h7_m7\Ethernet, but that one is immediately recreated on the next build which yields the same error.
Do you think it’s correct, better and final to modify the platformio.ini to move the lib_deps to related platforms, e.g. inside [env:portenta_h7_m7], etc.
If OK, I’ll change all of my libraries.
For example
;PlatformIO Project Configuration File
[platformio]
; chose environment:
; ESP8266
; ESP32
; SAMD
; NRF52
; STM32
; pico
;default_envs = ESP8266
;default_envs = ESP32
;default_envs = SAMD
;default_envs = pico
;default_envs = NRF52
;default_envs = STM32
default_envs = portenta_h7_m7
;default_envs = portenta_h7_m4
;default_envs = teensy
[env]
; Serial configuration
; choose upload speed, serial-monitor speed
upload_speed = 921600
;upload_port = COM11
;monitor_speed = 9600
;monitor_port = COM11
; Checks for the compatibility with frameworks and dev/platforms
lib_compat_mode = strict
lib_ldf_mode = chain+
;lib_ldf_mode = deep+
; set your debug output (default=Serial)
; -D DEBUG_ESP_PORT=Serial
; comment the folowing line to enable WiFi debugging
; -D NDEBUG
[env:teensy]
platform = teensy
; PlatformIO 4.x
; Teensy41_AsyncTCP@>=1.0.0
; PlatformIO 5.x
khoih-prog/Teensy41_AsyncTCP@>=1.0.0
platform = ststm32
board = portenta_h7_m7
; PlatformIO 4.x
; Portenta_H7_AsyncTCP@>=1.3.2
; PlatformIO 5.x
khoih-prog/Portenta_H7_AsyncTCP@>=1.3.2
[env:portenta_h7_m4]
platform = ststm32
board = portenta_h7_m4
; PlatformIO 4.x
; PlatformIO 5.x
[env:pico]
; Just a sample
; You have to research and fix if there is issue
platform = raspberrypi
board = pico
upload_protocol = picotool
; PlatformIO 4.x
; AsyncTCP_RP2040W@>=1.0.0
; PlatformIO 5.x
khoih-prog/AsyncTCP_RP2040W@>=1.0.0
[env:ESP8266]
platform = espressif8266
; PlatformIO 4.x
; https://github.com/khoih-prog/ESPAsyncTCP.git
; PlatformIO 5.x
; Board configuration
; choose your board by uncommenting one of the following lines
;board = gen4iod
;board = huzzah
;board = esp32doit-devkit-v1
[env:ESP32]
; PlatformIO 4.x
; AsyncTCP@>=1.1.1
; PlatformIO 5.x
me-no-dev/AsyncTCP@>=1.1.1
;board = esp32cam
;board = nina_w10
[env:STM32]
platform = ststm32
; PlatformIO 4.x
; https://github.com/khoih-prog/STM32AsyncTCP.git
; STM32duino LwIP@>=2.1.2
; STM32duino STM32Ethernet@>=1.3.0
; PlatformIO 5.x
; philbowles/STM32AsyncTCP
stm32duino/STM32duino LwIP@>=2.1.2
stm32duino/STM32duino STM32Ethernet@>=1.3.0
; Choose your board by uncommenting one of the following lines
; Board configuration Nucleo-144
;board = nucleo_f207zg
;board = feather_f405
; Board configuration Many more Boards to be filled
Not sure if the above was directed at me or not.
No idea what you mean by
" Do you think it’s correct, better and final to modify the platformio.ini to move the lib_deps to related platforms, e.g. inside [env:portenta_h7_m7] , etc."
I have however removed the MQTT_generic libary and I still get the same error
.pio/libdeps/esp32doit-devkit-v1/STM32Ethernet/src/utility/ethernetif.cpp:48:10: fatal error: stm32_def.h: No such file or directory
Looking for stm32_def.h dependency? Check our library registry!
I’m having the same issue but with the Websockets2_generic library. I’ve sent the posts that suggest removing parts of the library.json but I’ve not been able to make that work.
This is the main.cpp which is just one of the examples from the websockets2 lib.
Portenta_H7-Ethernet_ServerAllFunctionsDemo.ino
For Portenta_H7 with Murata WiFi module/shield.
Based on and modified from Gil Maimon's ArduinoWebsockets library https://github.com/gilmaimon/ArduinoWebsockets
to support STM32F/L/H/G/WB/MP1, nRF52 and SAMD21/SAMD51 boards besides ESP8266 and ESP32
The library provides simple and easy interface for websockets (Client and Server).
Example first created on: 10.05.2018
Original Author: Markus Sattler
Built by Khoi Hoang https://github.com/khoih-prog/Websockets2_Generic
Licensed under MIT license
#include <SPI.h>
#include "defines.h"
#include <WebSockets2_Generic.h>
#include <WiFiWebServer.h>
using namespace websockets2_generic;
WebsocketsServer SocketsServer;
int status = WL_IDLE_STATUS;
#define WEBSOCKETS_PORT 8080
// Change pins according to your boards
#define RED_LED LEDR
#define GREEN_LED LEDG
#define BLUE_LED LEDB
// For Portenta_H7
#define LED_ON LOW
#define LED_OFF HIGH
WiFiWebServer server(80);
String IPAddressToString(IPAddress _address)
String str = String(_address[0]);
str += ".";
str += String(_address[1]);
str += ".";
str += String(_address[2]);
str += ".";
str += String(_address[3]);
return str;
void setup()
while (!Serial && millis() < 5000);
Serial.print("\nStarting Portenta_H7_ServerAllFunctionsDemo using WiFi on "); Serial.println(BOARD_NAME);
Serial.println(WEBSOCKETS2_GENERIC_VERSION);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE)
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
Serial.print(F("Connecting to SSID: "));
Serial.println(ssid);
status = WiFi.begin(ssid, password);
delay(1000);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED)
delay(500);
// Connect to WPA/WPA2 network
status = WiFi.status();
if (WiFi.status() == WL_CONNECTED)
Serial.print("Connected to Wifi, IP address: ");
else
Serial.println("No WiFi");
return;
SocketsServer.listen(WEBSOCKETS_PORT);
Serial.print(SocketsServer.available() ? "WebSockets Server Running and Ready on " : "Server Not Running on ");
Serial.print("IP address: ");
Serial.print(WiFi.localIP());
Serial.print(", Port: ");
Serial.println(WEBSOCKETS_PORT); // Websockets Server Port
// handle index
server.on("/", []()
String wsServer = String("ws://") + IPAddressToString(WiFi.localIP()) + ":" + WEBSOCKETS_PORT + "/";
Serial.print("wsServer: ");
Serial.println(wsServer);
// send index.html
server.send(200, "text/html", "<html><head><script>var connection = new WebSocket(wsServer, ['arduino']);connection.onopen = function () { connection.send('Connect ' + new Date()); }; connection.onerror = function (error) { console.log('WebSocket Error ', error);};connection.onmessage = function (e) { console.log('Server: ', e.data);};function sendRGB() { var r = parseInt(document.getElementById('r').value).toString(16); var g = parseInt(document.getElementById('g').value).toString(16); var b = parseInt(document.getElementById('b').value).toString(16); if(r.length < 2) { r = '0' + r; } if(g.length < 2) { g = '0' + g; } if(b.length < 2) { b = '0' + b; } var rgb = '#'+r+g+b; console.log('RGB: ' + rgb); connection.send(rgb); }</script></head><body>LED Control:<br/><br/>R: <input id=\"r\" type=\"range\" min=\"0\" max=\"255\" step=\"1\" oninput=\"sendRGB();\" /><br/>G: <input id=\"g\" type=\"range\" min=\"0\" max=\"255\" step=\"1\" oninput=\"sendRGB();\" /><br/>B: <input id=\"b\" type=\"range\" min=\"0\" max=\"255\" step=\"1\" oninput=\"sendRGB();\" /><br/></body></html>");
server.begin();
digitalWrite(RED_LED, LED_OFF);
digitalWrite(GREEN_LED, LED_OFF);
digitalWrite(BLUE_LED, LED_OFF);
WebsocketsClient* client = NULL;
void loop()
server.handleClient();
client = new WebsocketsClient;
if (client)
*client = SocketsServer.accept();
if (client->available())
WebsocketsMessage msg = client->readNonBlocking();
// log
Serial.print("Got Message: ");
Serial.println(msg.data());
// return echo
client->send("Echo: " + msg.data());
// close the connection
client->close();
delete client;
Since I did not really understand what this library really depended on I excluded all the libraries that it includes by default then started adding them back in based on the complier errors until it worked… I would be very grateful for a quick explanation of how this websockets 2 library functions.
Dear community, opening this topic as people searching for help on building the AsyncMqtt_Generic for the Portenta H7 might run into this thread and find some useful up-to date information in early 2024.
Using ArduinoCore-mbed 3.5.4 made it possible for me to compile the project succesfully.
Initially when I tried to compile the example with the most recent ArduinoCore-mbed 4.0.10, I got an error:
Compiling .pio\build\opta\lib031\Portenta_H7_AsyncTCP@src-604b5ceafe255af4b260b9758b724419\Portenta_H7_AsyncTCP.cpp.o
In file included from .pio\libdeps\opta\Portenta_H7_AsyncTCP@src-604b5ceafe255af4b260b9758b724419\src\AsyncPrinter.h:52:0,
from .pio\libdeps\opta\Portenta_H7_AsyncTCP@src-604b5ceafe255af4b260b9758b724419\src\AsyncPrinter.cpp:52:
.pio\libdeps\opta\Portenta_H7_AsyncTCP@src-604b5ceafe255af4b260b9758b724419\src\Portenta_H7_AsyncTCP.h:109:12: fatal error: lwip/ip_addr.h: No such file or directory
#include "lwip/ip_addr.h"
compilation terminated.
Now for me it is not entirely clear what is actually the breaking change between ArduinoCore-mbed 3.5.4 and 4.0.10. Is there anyone who can point to this error, or has a fix for this problem.
It seems that something fishy is going on with the lwip from mbed and the portenta h7, but all the files seem to be in the repo:
Small sidenote: my target is an arduino Opta, but it is essentially the same as the Portenta H7. In any case the example platformio.ini has the portenta h7 as target.
#include "rtos.h"
#include "MCUboot.h"
using namespace std::chrono_literals;
return;
while (true)
rtos::ThisThread::sleep_for(1s);
maybe @maxgerhardt might have a solution, as i have seen he has quite some knowledge of the plarformio build system.
