Arduino Due ( RamFunc ) ISR
Projects with PIO Arduino Due ( execute code in RAM).
my test: compiling led blink, loader in RAM
reloked VTOR…
jmp code = ok.
problems is: ISR in libray… error
test1: Serial library… failure ISR.
solution: creat function serial.
see:
_MYREG->RAM_VECTOR[24] = (uint32_t)tablefunc[2]; // Serial
IRQn_Type _dwId = UART_IRQn; add it
pmc_enable_periph_clk( _dwId ) ;
blablabla…
NVIC_EnableIRQ(_dwId); goto! ok
now:
Due_CAN
erro init CAN0.
_MYREG->RAM_VECTOR[59] = (uint32_t)tablefunc[4]; // (uint32_t)(&CAN0_Handler), //4
         Can0.begin(CAN_BPS_500K);  error !
         Can0.watchFor();
problems is ISR.
thanks,
Carlos.
The problem happens on this line, in " due_can.cpp"
m_pCan->CAN_MR &= ~CAN_MR_CANEN; //immediately disable the CAN hardware if it had previously been enabled
reset_handler,
thanks,
Carlos.
