Hey,
As of PIO v3.4.0 at atmelsam 2.3.0, the Due is not found when uploading:
Auto-detected: COM4
Forcing reset using 1200bps open/close on port COM4
Uploading .pioenvs\default\firmware.bin
No device found on COM4
*** [upload] Error 1
However, there are no problems using the Arduino IDE or on the version of pio I had previously (v3.3.1).
The funny thing was I uploaded it fine, then noticed I had out of date versions of things, then uploaded again to find this error. This happened on two PCs so far!
edit:
This also happens with a fresh project initialised with platformio init -d ./test_project_due --board due, with a copy of Blink.ino and uploading platformio run -t upload
Looking for upload port...
Auto-detected: COM6
Forcing reset using 1200bps open/close on port COM6
Uploading .pioenvs\due\firmware.bin
No device found on COM6
This is the output from the older working version:
Auto-detected: COM6
Atmel SMART device 0x285e0a60 found
Erase flash
done in 0.033 seconds
So it seems the port is found ok, but maybe if it isnt recognising the device type, the reset bit didnt work?
