So I switched from the Arduino IDE to platformIO after having the same compilation problem,thinking it would go away(btw this problem arose recently,beforehand I used to upload code normally),so when i write some code and try to upload it via the upload icon in the bottom bar ,I get this output:
`Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.1.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 6 compatible libraries
Checking size .pio/build/uno/firmware.elf
RAM: [= ] 9.2% (used 188 bytes from 2048 bytes)
Flash: [ ] 4.9% (used 1576 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Using manually specified: /dev/ttyS4
Uploading .pio/build/uno/firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
*** [upload] Error 1`
should I consider buying a new board or is it another problem?
