Hi, I’m trying to upload code to Arduboy using PlatformIO CLI.
Its Arduino Leonardo based.
Somtimes it works but In most cases I got
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
scons: *** [upload] Error 1
Arduino IDE works always. Only difference is this:
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem1411
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem1411, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem1411, /dev/tty.Bluetooth- Incoming-Port, /dev/tty.usbmodem1411, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem1411, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.Bluetooth-Incoming- Port, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem1411, } => {/dev/cu.usbmodem1411, /dev/tty.usbmodem1411, }
Found upload port: /dev/cu.usbmodem1411
Anyone have a clue, what should I do before run avrdude ?
Thanks.
