astate
February 11, 2021, 9:01am
1
Hi, I have an Apple M1 computer, installed an Arm version of VS Code, try to run ESP32 with espidf example without success, however, the Arduino example ran just fine, shows the error message as following:
'platformio/toolchain-xtensa32 @ ~2.80400.0' requirements for your system 'darwin_arm64'"
and
PlatformIO Core 5.1.0
Python 3.9.1-final.0
System Type darwin_arm64
Platform macOS-11.1
File System Encoding utf-8
Locale Encoding UTF-8
PlatformIO Core Directory /Users/lee/.platformio
PlatformIO Core Executable /Users/lee/.platformio/penv/bin/platformio
Python Executable /Users/lee/.platformio/penv/bin/python
Global Libraries 0
Development Platforms 2
Tools & Toolchains 6
Does it have anything to do with the toolchain not compatible in arm structure?
astate:
That is weird, this says Darwin Arm64 and in the other instance where someone is running an M1 chip, PlatformIO declares it as darwin_x86_x64 (possibly through emulation) at Platform IDE for VSCode on Mac ARM/M1? - #21 by tecnico-solar-boat .
@ivankravets the Xtensa32 8.4.0 version seems to be missing / not yet declared compatible with darwin_arm64?
valeros
February 11, 2021, 7:28pm
4
I’ve updated packages, @astate please try to run your project again.
astate
February 12, 2021, 1:43am
5
It’s now working!
Although had to get around the cffi problem of the need to manually compile the rust (Homebrew shipped with the X86 version), and using
env CRYPTOGRAPHY_SUPPRESS_LINK_FLAGS=1 LDFLAGS="$(brew --prefix openssl@1.1)/lib/libssl.a $(brew --prefix openssl@1.1)/lib/libcrypto.a" CFLAGS="-I$(brew --prefix openssl@1.1)/include" pip install cryptography
to compile cryptography, afterward, everything works fine.
Thank you guys for the great work!
astate
February 12, 2021, 9:44am
6
Also have add to note that I’m using the insider Arm version of the VS Code
Can be verified running on Apple silicon by open Activity Monitor
The user from previous thread probably using the Intel version of the VSCode?
