App_main not found "again"
I gave PlatformIO a try 2 days ago and installed it, hoping to quickly repair a messed up ESP-IDF installation. Sadly I spent more time on PlatformIO than I would have needed to reinstall the IDF. Anyway, I like the idea of PlatformIO so I post my problems to find help.
I use VSC + PlatformIO, ESP32 Heltec board and IDF (NO Arduino).
I created a new project (intended to be shifted to CPP in order to try overloading and classes), consisting of one function and app_main().
ESP32
ESP-IDF
Heltec32 Board
#include <stdint.h>
uint8_t test_overload(uint8_t a){
    a=a+1;
    return a;
extern "C" {
    void app_main(void);
void app_main(){
    uint8_t b;
    b=8;
    b=test_overload(b);
In VSC + PlatformIO I hit the clear symbol, then the flask symbol.
I get “undefined reference to ‘app_main’” no matter what I try.
All the hints, like “use extern C”, etc. do not work. Even downloading an example (ESP32_BLINK) gives the same problem.
Any ideas?
I hope that I just failed to understand something, as I am new to PlatformIO.
Hind regards
GvTT
You are executing the test task, which will ignore all source files in src/ and instead use the ones from test/. This folder is empty, thus your firmware is missing the app_main() function at link time.
It seems you’re executing the “Test” task instead of the “Build” and “Upload” tasks? Test is for unit testing.
As Max pointed out, you want the tick (build) icon, not the flask :wink: See the following to see what each icon does.
https://docs.platformio.org/en/latest/ide/vscode.html#platformio-toolbar
Great, thank you very much!
You were absolutely right.
My apologies for not having read the instructions first.
Knowing I can compile my code I will read about using PlatformIO.
Compared to VSC + ESP-IDF I am surprised how easy the installation was.
Knowing my fault using it, I am impressed that my first compiles (C & CPP) worked right “out if the box”.
Now I can and will recommend using PlatformIO.
It will keep me busy while finding all the adjustments I might want to make - like specifying a different storage location, personal libraries, etc. I found this already covered in the forum.
A positive surprise,
many thanks to PlatformIO as well as to maxgerhardt and pfeerick
Georg
Instructions… who needs to read the destructions? :laughing: Yes, it’s good to have docs.platformio.org and the forum bookmarked as I’m sure you’ll be visiting both a bit whilst acclimating yourself do a new IDE… I know I regularly visit the documentation, and often suggest edits, so don’t be afraid to point out any mistakes and make suggestions! :wink:
