Are there any plans for updating PlatformIO to support the esp-idf framework release 4.2?
There are some new features relating to heap management that I would like to use, it would just be nice to know about the plans.
Thanks!
Thanks!
Already usable in the bleeding-edge development branch since yesterday, see Add support for ESP-IDF v4.2 ¡ Issue #455 ¡ platformio/platform-espressif32 ¡ GitHub.
Thanks! I missed that one.
I used the âpio platform updateâ but the version file in ââŚplatformio\packages\framework-espidfâ still say â3.40100.200827â? Actually all the files in the folder has the date from the previous esp-idf release (4.1). How do I update the esp-idf framework to the new release 4.2?
Udpating is done exactly like the comment says on github. You need to modify the platformio.ini
of your project, replace the original platform = espressif32
line by the bleeding edge version platform = https://github.com/platformio/platform-espressif32.git
platform = GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO
I already have that in the platformio.ini file from the last time you helped me with the debug adapter speed?
[platformio]
default_envs = nodemcu-32s[env:nodemcu-32s]
;platform = espressif32
board = nodemcu-32s
;board_debug.adapter_speed = 500
;board_upload.flash_size = 8MB
;board_upload.maximum_size = 8388608
board_upload.flash_size = 4MB
board_upload.maximum_size = 4194304
framework = espidf
debug_tool = olimex-arm-usb-ocd-h
;upload_protocol = olimex-arm-usb-ocd-h
;board_build.partitions = ESP32_OTA_8M.csv
board_build.partitions = ESP32_OTA_4M.csv
Then pio platform update
should have updated that too.
Remove the folders of the form C:\Users\<user>\.platformio\platforms\espressif32@src*
to force a redownload on the next build.
Thanks, that did it!
Is there a special procedure to follow when updating the framework(s)?
When re-building the project I now get this message:
*** [.pio\build\nodemcu-32s\bootloader\soc\esp32\adc_periph.o] Source
C:\Users\Niels\.platformio\packages\framework-espidf\components\soc\esp32\adc_periph.c' not found, needed by target
.pio\build\nodemcu-32s\bootloader\soc\esp32\adc_periph.oâ.
Looking for the file I found it in another path:
âŚplatformio\packages\framework-espidf\components\soc\soc\esp32
So it seems it now needs ââŚsoc/soc/âŚâ in order to reach the file? Do you know where that is configured?
I was testing the example at platform-espressif32/examples/espidf-aws-iot at develop ¡ platformio/platform-espressif32 ¡ GitHub with the bleeding-edge platform and additionally folliwing this comment regarding inclusion of binary files and I donât receive such an error.
PLATFORM: Espressif 32 (2.1.0+sha.1d1a7ca) > Espressif ESP32 Dev Module
DEBUG: Current (esp-prog) External (esp-prog, esp32s2_kaluga_v1, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210114 (8.4.0)
Linking .pio\build\esp32dev\firmware.elf
Building .pio\build\esp32dev\firmware.bin
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 10.0% (used 32780 bytes from 327680 bytes)
Flash: [======= ] 72.9% (used 764504 bytes from 1048576 bytes)
esptool.py v3.0
======================= [SUCCESS] Took 57.61 seconds =======================
If in doubt remove the folders C:\Users\Max\.platformio\packages\framework-espidf*
, execute the âCleanâ task in the project and rebuild.
Thanks that did the trick!
So, what is your preferred platform/framework update procedure? I would like not to use so much time (yours and mine) on the next update.
I have followed the exact same steps as follows:
But it keeps downloading framework-espidf@3.40402.0
Here is my platformio.ini file:
framework = espidf
debug_tool = esp-prog
debug_speed = 1000
upload_protocol = esp-prog
upload_port = esp-prog
board_build.partitions = partitions.csv
board_build.f_flash = 80000000L
board_build.embed_txtfiles = src/Certs/certs.pem
Can anyone tell me why it wonât install latest package (framework-espidf)?
But that is the latest version according to
platform-espressif32/platform.json at 03254d41cb8e63e9b37d7c796ad55f2c00869ea5 ¡ platformio/platform-espressif32 ¡ GitHub and PlatformIO Registry.
Note that this encodes ESP-IDF 4.4.2.
Which version did you expect?
Ah, you are right. I donât know what I was thinking.
The reason for my confusion is that I was trying to use:
#include "tcpip_adapter.h"
But it kept using a deprecated version of the header file, instead of the following:
So I assumed that I must have an older version of ESP-IDF.
