In Clion, platformio plugin is installed, platformio is installed, but building projects is always gathering Info
What does time pio boards
output at the end?
Never came out. Cannot be used.
So the pio boards
command outputs nothing or is the time
command not available?
Does the pio boards
command work inside the terminal of CLION too? (Create any dummy project and there should be a Terminal tab at the bottom):
Looks like everything is installed properly, no idea what’s going on. You should open a bug on the CLion side at https://youtrack.jetbrains.com/issues?q=tag:%20platformio with the tag “platformio”.
All right, thank you very much!
