I’m unable to get my ESP32-CAM to work with Serial Monitor. The output is mangled whatever speed I try. SM in Arduino IDE works indeed.
Any idea?
Thanks Robert
Any idea?
Thanks Robert
If you have some output but it’s mangled, double check that you set the monitor_speed to the same baud rate used in the Serial.begin(); call in your firmware code.
That’s what I usually do, but doesn’t work in this case.
Please start a new project with the most minimal
void setup() { Serial.begin(115200); }
void loop() { Serial.println("test"); delay(1000); }
with the platformio.ini
[env:esp32cam]
board = esp32cam
Does it successfull upload? What’s the full serial monitor output / screenshot?
--- Terminal on /dev/cu.wchusbserial210 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
Does this also happen in the Arduino IDE?
Nope,
Arduino IDE 2.0.4 works out of the box.
Robert
Can you share a screenshot of the “Tools” configuration menu in the Arduino IDE to show what board and settings you used?
Okay, so in the Arduino IDE it’s running at twice the flash frequency and quad instead of dual mode…
Then change the platformio.ini to
[env:esp32cam]
board = esp32cam
board_build.f_flash = 80000000L
board_build.flash_mode = qio
and reupload the project. Is it any different?
Nope,
still the same ![]()
Robert
pio pkg update -g -p espressif32
/dev/cu.wchusbserial210 or /dev/tty.wchusbserial210?> pio pkg update -g -p espressif32
Platform Manager: Updating espressif32 @ 5.3.0
Platform Manager: Removing espressif32 @ 5.3.0
Platform Manager: espressif32@5.3.0 has been removed!
Platform Manager: Installing platformio/espressif32 @ 6.1.0
Platform Manager: espressif32@6.1.0 has been installed!
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch5 is already installed
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40500.0
Tool Manager: tool-esptoolpy@1.40500.0 has been installed!
Tool Manager: tool-esptoolpy@1.40500.0 is already up-to-date
Tool Manager: tool-mkfatfs@2.0.1 is already up-to-date
Tool Manager: tool-mklittlefs@1.203.210628 is already up-to-date
Tool Manager: tool-mkspiffs@2.230.0 is already up-to-date
Tool Manager: tool-openocd-esp32@2.1100.20220706 is already up-to-date
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch5 is already up-to-date
In ArduinoIDE is /dev/cu.wchusbserial210 selected.
HTH
Robert
Okay so that updated it to a platform that uses Arudino-ESP32 2.0.7 instead of 2.0.6. I hope this matches the version you have installed in the Arduino IDE? Check the Tools->Board->Board Manager → esp32 to verify.
When you do the “Upload and Monitor” task again, is it any different?
Yeah,
Arduino IDE reports version 2.0.7 of ESP32 platform. When I upload and monitor in Arduino IDE, it still works. Still no luck with PlatformIO
Robert
When you upload the firmware using PlatformIO but monitor it using the Arduino IDE’s serial monitor, is the output the same?
When I upload using VSCode, I can monitor via ArduinoIDE. Doesn’t work the other way, seems that just Serial Monitor is not able to apply the right settings.
Robert
Aha. So in actuality it’s just this problem.
Yeah. ![]()
Thanks a lot for your time helping me.
Have a nice weekend
Robert
