Hello all,
something strange is happening.
I have a firmware for ESP32 which has been properly working for the last months.
Last friday I updated something on the PlatformIO IDE (perhaps the IDE itself or some libraries) and now my ESP32 keeps rebooting.
The log is:
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:12776
load:0x40080400,len:3032
entry 0x400805e4
ESP_ERROR_CHECK failed: esp_err_t 0x103 (ESP_ERR_INVALID_STATE) at 0x40088464
file: "lib/TimersManager/TimersManager.cpp" line 79
func: void TimersManager::Timer_Frame_Begin()
expression: esp_timer_create(&timer_args, &timer_frame)
abort() was called at PC 0x40088467 on core 0
Backtrace:0x40082fdd:0x3ffe3ab00x40088471:0x3ffe3ad0 0x4008d9cd:0x3ffe3af0 0x40088467:0x3ffe3b70 0x400d1dac:0x3ffe3b90 0x400d1ca1:0x3ffe3bd0 0x400d1cde:0x3ffe3bf0 0x400da27f:0x3ffe3c10 0x4008288d:0x3ffe3c40 0x400791f2:0x3ffe3c90 |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
The code indicated in the log is the following:
esp_timer_create_args_t timer_args;
timer_args = {
.callback = frame_callback,
.arg = NULL,
.dispatch_method = ESP_TIMER_TASK
ESP_ERROR_CHECK(esp_timer_create(&timer_args, &timer_frame)); <--- THIS IS LINE 79
ESP_ERROR_CHECK(esp_timer_start_periodic(timer_frame, period_frame_us));
I want to specify that I asked some my colleague to flash the same code from their PC and it’s running.
I also just tried to uninstall and re-install VS Code and PlatformIO without success: it keeps crashing.
Can someone help me?
Thank you
