Changed a pio project configuration from
to
framework = espidf
and back.
Now I can#t compile the project any more:
------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (6.0.1) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
Found 39 compatible libraries
Scanning dependencies…
|-- ArduinoJson @ 6.20.1
|-- TFT_eSPI @ 2.5.21
|-- ESPNtpClient @ 0.2.7
|-- Time @ 1.6.1
|-- AsyncTCP @ 1.1.1
|-- ESP Async WebServer @ 1.2.3
|-- SD @ 2.0.0
|-- WiFi @ 2.0.0
Linking .pio\build\esp32dev\firmware.elf
c:/users/miko/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\lib758\libESP Async WebServer.a(WebAuthentication.cpp.o):(.literal._ZL6getMD5PhtPc+0x4): undefined reference tombedtls_md5_starts' c:/users/miko/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\lib758\libESP Async WebServer.a(WebAuthentication.cpp.o): in function
getMD5(unsigned char*, unsigned short, char*)‘:
D:\Dokumente\PlatformIO\Projects\esp32_espnow_server/.pio/libdeps/esp32dev/ESP Async WebServer/src/WebAuthentication.cpp:73: undefined reference to `mbedtls_md5_starts’
*** [.pio\build\esp32dev\firmware.elf] Error 1
========================================== [FAILED] Took 22.65 seconds ===================
Reinstalled AsyncTCP and AsyncWebswerver, but that didn’t fix the problem.
What’s wrong?
