Here to post on my own topic again, But maybe I can help some poor shmuck who has the same issue down the road.
Here is the (stripped down) script I wrote:
gitlab_ci_lib_replacer.py in the folder [project_root]/scripts/CI
import os
import re
pio_ini = 'platformio.ini'
search_regex = '^(\s*?)git@(.*?gitlab.*?):(.*?)$'
ci_token = os.environ['CI_JOB_TOKEN']
replace_regex = '\\1https://gitlab-ci-token:'+ ci_token + '@\\2/\\3'
updated_content = ""
with open (pio_ini, 'r') as f:
content = f.read()
updated_content = re.sub(search_regex, replace_regex, content, flags = re.M)
f.close()
with open (pio_ini, 'w') as f:
f.write(updated_content)
f.close()
Since I wanted this script to only run for CI builds, I called it from the gitlab ci config:
.gitlab-ci.yml
build:
stage: build
image: python:3.9-buster
rules:
- if: $CI_COMMIT_TAG =~ /^v[\d]{1,3}\.[\d]{1,3}\.[\d]{1,3}$/ # Only run on version tags (v1.2.3, etc.)
before_script:
- "pip install -U platformio"
- "python scripts/CI/gitlab_ci_lib_replacer.py"
script:
- "pio run -e my_env"
How does this actually work?
When using private git repositories as libraries, it is easy to pull them on dev systems using SSH. As soon as you try to run them in CI, that causes an issue. In order to make the CI work with SSH, you need to have an SSH key for the CI build. This is possible in gitlab using deploy keys but it comes with some safety caveats. Primarily, when the SSH private key is added as a CI variable, you have to be concerned with how other developers have access to it. If they can change the CI config, they could use the SSH key to pull the library and push it to their own upstream (even if they don’t personally have access to that libraries repo!). This creates a security loophole, and that’s not what we want. Of course, you can protect those files through careful merge checks, branch protection, etc. But I didn’t want to make it hard to change stuff, I just wanted private repos to stay private.
The way I solved this above is using the CI_JOB_TOKEN. This is essentially a personal access token generated by gitlab that is only valid while that specific CI job is running. It is created under the name of the user who triggered the CI job. So, it has access to the repos the triggering user does. We can utilize this behavior by regex replacing the SSH git repo URLs with Token-based HTTPS git repo URLs.
When PIO goes to pull the libraries, it uses the HTTPS+Token URL we just changed in the .ini file to pull the library with the CI_JOB_TOKEN (which is redacted using regex in the CI output on gitlab).
The regex in the file above replaces lines like this:
lib_deps = git@gitlab.com:timomerschen/Artnet.git# v1.0
with:
lib_deps = https://gitlab-ci-token:123456789abcdef@gitlab.com/:timomerschen/Artnet.git# v1.0
Of course, if you are using a self-hosted gitlab instance, youll have to fix the regex (maybe make the gitlab.com part a variable).
TLDR
SSH is hard to do securely with CI, So use CI tokens. The script above replaces the SSH URLs with HTTPS+Token URLs.
Dont mind me as a mark my own reply as the solution
