I am trying to use advanced scripting to access the ELF file and I am having trouble finding any documentation on the env object.
Win10, Board robotdyn_blackpill_f303cc
I am trying to execute a subprocess inside of the build directory.
ret = subprocess.run([“CMD”], shell=True, capture_output=True, check=True, cwd = env.Get(“BUILD_DIR”))
Problem is, that the output of env.Get(“BUILD_DIR”) is “$PROJECT_BUILD_DIR\$PIOENV”, which obviously is not a valid path. How do I get the final path out of the env object without building it myself?
There is no documentation that I could find on the functions available with the env object.
So which function should be used to get the parsed, final path without doing it manually? And I would suggest to build a function-based doc for the env object to make such things easier to find.
BR
