I’m trying to customize the config portal of the WifiManager to give it a new and enhanced look. I read about adding/uploading image files to a “data” folder using the Arduino IDE, but not sure how to do it on PlatformIO.
Thanks
Thanks
It’s the same for PlatformIO. Files in the data/ folder will be converted to a SPIFFS image and you can upload it via the special target “Upload SPIFFS” in your IDE or pio run -t uploadfs. See Espressif 8266 — PlatformIO latest documentation (more recent: Espressif 8266 — PlatformIO latest documentation)
Thank you very much for your continued support. I’ll give it a try and let you know! ![]()
By the way, do you suggest any specific location for “data” folder?
From Espressif 8266 — PlatformIO latest documentation
- Create
datafolder (it should be on the same level assrcfolder) and put files here. Also, you can specify own location for data_dir
Also refer Redirecting...
That was very helpful and I’m reading the instructions now!
Thank you again!
Could you please refer me to the docs where I can read more about running tasks in the IDE cause I didn’t find a way to run “Upload File System image” task in PlatformIO IDE.
Also, for CLI command, please let me know if the following does the job:
platformio run --uploadfs
Thx
*** UPDATE ***
Sorry for confusion. Just found it!
See Redirecting...
