I was able to get PIO working with the Sparkfun Pro NRF52840 Mini. This involved:
- Creating a board definition
.\core_dir\platforms\nordicnrf52\boards
- Adding Arduino
variant.h
and variant.cpp
files to .\core_dir\packages\framework-arduinoadafruitnrf52\variants\sparkfun_pro_nrf52840_mini
- Adding bootloader to
- Editing
.\core_dir\packages\framework-arduinoadafruitnrf52\boards.txt
and adding Sparkfun board info.
This Github repo has the needed files and instructions for manually performing this setup.
Is there a way to get these changes baked into PlatformIO proper?
Please file a feature request here Issues · platformio/platform-nordicnrf52 · GitHub
A better solution with patching could be as described here Redirecting...
Then, you can use default Adafruit board and just override variant via board_build.variant = sparkfun_pro_nrf52840_mini
P.S: No need to copy boards.txt, we don’t use it.
Hi, I followed up the instructions and got stuck where pio cannot find the usb.h:
.platformio\packages\framework-arduinoadafruitnrf52\variants\sparkfun_pro_nrf52840_mini\variant.cpp:26:10: fatal error: usb.h: No such file or directory
I have installed the arduino USB libraries but still the error won’t go.
Is there any update to this? I found some close devices in the list but not the sparkfun_pro_nrf52840_mini?
