I’m a beginner and trying to add a library from GitHub to my project.
I have added the following code in my platformio.ini file:
; nrf24L01
tmrh20/RF24@^1.3.11
; E22
https://github.com/wanfp97/EByte_LoRa_E22_Series_Library
the library for the nrf24L01 works well but after I add in the E22 library using the GitHub link and rebuild, the following error occurs:
If I’m not mistaken, the SoftwareSerial.h is an inbuilt library for the Arduino framework. Am I adding the GitHub library wrongly? If yes, please guide me on how to add the library correctly.
Ps: I can’t find the library by searching it within the Platformio and thus I’m adding it using the GitHub link.
Since the library inclusion is guarded by a macro
PlatformIO’s library dependency finder (LDF) needs to be set to a more aggressive mode to recognize the dependency. As per docs, try adding
lib_ldf_mode = chain+
to the platformio.ini
and retry compilation.
Did you mean like this?
but the problem still remains
I cannot reproduce the issue when using the source code
#include <RF24.h>
#include <LoRa_E22.h>
and platformio.ini
[env:uno]
board = uno
; nrf24L01
tmrh20/RF24@^1.3.11
; E22
Make sure to at least include the library’s header in your code.
|-- <RF24> 1.3.11
| |-- <SPI> 1.0
|-- <EByte LoRa E22 library> 0.9.0+sha.7b3aa2a
| |-- <SoftwareSerial> 1.0
|-- <SPI> 1.0
Checking size .pio\build\uno\firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.4% (used 444 bytes from 32256 bytes)
==================== [SUCCESS] Took 2.39 seconds ====================
