Hi I am trying to add an assembler function to my C project. The assembler function is in a separate file asm.S. Compiling works fine and the asm.S.o file is generated but linking does not work and I get the warning “undefined reference to `ASM_TST(unsigned int, unsigned int, unsigned int, unsigned int)” and of course it does not work.
My assembler file asm.S:
.section .text
.equ TEST_ABC, 0x40000000
.equ HUGO_ABC, 0x08
.global ASM_TST
ASM_TST:
mov r0, #4
mov r1, #HUGO_ABC
add r0, r1
bx LR
.end
I have a prototype declaration for the function asm.h:
typedef unsigned int UINT32_t;
/* Prototype declarations */
UINT32_t ASM_TST(UINT32_t, UINT32_t, UINT32_t, UINT32_t);
My C program is the standard blink:
#include "asm.h"
//#define PIN_LED_RED PB14
//#define PIN_LED_RED PB12
#define PIN_LED_RED PC13
void setup()
// initialize LED digital pin as an output.
pinMode(PIN_LED_RED, OUTPUT);
void loop()
// turn the LED on (HIGH is the voltage level)
digitalWrite(PIN_LED_RED, HIGH);
Serial.println("HIGH");
// wait for a second
delay(1000);
// turn the LED off by making the voltage LOW
digitalWrite(PIN_LED_RED, LOW);
Serial.println("LOW");
delay(1000);
/* Call ASM routine */
ASM_TST(1, 2, 3, 4);
My platform.ini file:
[env:genericSTM32F103CB]
platform = ststm32
board = genericSTM32F103CB
upload_protocol = dfu
board_build.core = maple
-D SERIAL_USB
-D GENERIC_BOOTLOADER
debug_tool = stlink
lib_extra_dirs = C:\Users\xxx\Documents\PlatformIO\Projects\lib_shared
What have I missed?
