Hello everyone,
I have been having a blast with my Arduino project, I have been using Library’s that I have found in the automatic library look up which will import them for me. Given I’m new to Arduino I found this super helpful.
However I want to use this library and can’t seem to find it in the automatic library look up section. Arduino Playground - Charlieplex Library
How does one go about adding it to the project.
The developer that made the library says this, but i’m using the platform.io in VSC
"Put the Charlieplex folder in "hardware\libraries".
In the Arduino IDE, create a new sketch (or open one) and
select from the menubar “Sketch->Import Library->Charlieplex”.
Once the library is imported, an “#include Charlieplex.h” line will appear
at the top of your Sketch."
however when reading the readme section in lib is seems I should put it in there. Plus I want to be able to use this on all my computer which I have been coding on.
How do you think I should go about installing this library.
EDIT
After coping over the files to the lib section and then cleaning my teensy and rebuilding after adding “#include Charlieplex.h” in the main.cpp
I get the following output
Compiling .pio\build\teensy36\lib2e1\Charlieplex\Charlieplex.cpp.o
Archiving .pio\build\teensy36\lib2e1\libCharlieplex.a
It is the only one that says Archiving
why does it say Archiving?
Thank you for reading,
Joe
