Hi guys
have small issue with libneai.a file
just cannot use it in my project
add all files into /src folder
main.c:(.text.startup.main+0x1a): undefined reference to neai_oneclass_init' main.c:(.text.startup.main+0x38): undefined reference to neai_oneclass’
Without seeing neither your project structure nor your platformio.ini it’s a little bit guessing , but I think you’re missing some directive for linking libneai.
Adding an additional library for linking should work with something like that
-lneai
If the library resides in a unusual place it could be necessary also to add the path to it with
