Having much fun with ESP8266 over Platformio teased me to try ESP32. This project was considered as good start.
Of course, installation process went not well: Arduino could not download JSON configuration, and all tricks of disabling/changing proxy didn’t help. So I thought I can build the project in my favorite Platformio.
Followed this guide, and apparently failed with complaint about “getWebParameter” on Finish of the Project Wizard.
However, the project structure was created, I can open it. The platformio.ini contains:
So far looks OK.
I added main.ino in src folder and pasted the source from the initial project example.
The sketch can’t compile due to “#include errors detected. Please update your includePath. Squiggles are disabled for this translation unit…” for all includes:
I thought that ESP32-Cam board isn’t installed since I never didn’t install it explicitly. So I opened ‘Boards’ and found it there. However, I don’t understand how do I install/add the board to Platformio?
What do I miss?
Maybe title doesn’t match the topic, improvement is welcome.
Specific boards don’t need to be added, only platforms. If you’ve created any project with a espressif32 platform board, then the platform will be installed, and plaformio will know about all of the espressif32 boards supported. Alternately, when you select it the first time via the PIO ‘New Project’ screen, that’s the reason for the long delay… it’s trying to download the platform files then.
Regardless, the first time you run the build, PlatformIO will download any platform files, and toolchains needed. And when you try to do an upload, it’ll download any tools missing needed to do the upload. And if you try to debug, again, any missing tools will be downloaded.
If the framework files didn’t download, then the intellisense warning is real… the files are missing. Or it’s possible it just hasn’t worked it out yet. In a nutshell, ignore the intellisense warnings, and try and build your code. There’s a good chance the warnings will go away. Otherwise, you might need to remove the project from the workspace, and re-add it just to liven it up.
Thank you @pfeerick for the elaboration about platforms.
Initially, the build went along with the Intellisense, throwing fatal error on the ‘dependency finder’.
I uninstalled Espressif 32 platform, installed it again and restarted the MS code. Now the build progresses a little:
Processing esp32cam (platform: espressif32; board: esp32cam; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32cam.html
PLATFORM: Espressif 32 1.10.0 > AI Thinker ESP32-CAM
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-arduinoespressif32 2.10003.190916 (1.0.3), tool-esptoolpy 1.20600.0 (2.6.0)
Converting main.ino
Found 60 compatible libraries
|-- <WiFi> 1.0
Compiling .pio\build\esp32cam\src\main.ino.cpp.o
Generating partitions .pio\build\esp32cam\partitions.bin
Compiling .pio\build\esp32cam\lib914\WiFi\ETH.cpp.o
Compiling .pio\build\esp32cam\lib914\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32cam\lib914\WiFi\WiFiAP.cpp.o
xtensa-esp32-elf-g++: error: src\main.ino.cpp: No such file or directory
xtensa-esp32-elf-g++: fatal error: no input files
compilation terminated.
*** [.pio\build\esp32cam\src\main.ino.cpp.o] Error 1
================================================================== [FAILED] Took 36.95 seconds ==================================================================
The error caused by #include "dl_lib.h". Indeed this file doesn’t present on my computer.
I commented this include out and… the build passed. =)
What is this header for? How is it important?
Likely, I must ask the example originator… Just in case you know
I’m not sure what the header is for, other than it being potentially related to the face recognition capabilities (esp-face), it was removed in version 1.0.3 of the Arduino core. This means you can see if simply commenting it is enough, or if you need to revert to version 1.0.2 of the Arduino core, the last version it was present in. For platformio, that would be v1.8.0 of the espressif platform, so platform = espressif32@1.8.0 in your platformio.ini. The other alternative being to find out what changes need to be made to the code to update it.
