Hi
I’m trying to add an Arduino Library ( u8g2 ) to an ESP-IDF with Arduino Core as component Project, but I’m having issues to do so.
First thing I did is I cloned the espidf-arduino-blink example (Link ) and opened it as a new project in VSC PlatformIO.
I then went to the Library manager of PlatformIO, searched for the library and added it to the Project.
After that, I started the Setup process according to the Library wiki.
However, when I add the Constructor (for example,
U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, 13, 11, 10, 8);
VSCode marks it with issues and tells me the identifier is undefined. However, If I go to the reference link, VSCode goes to the correct Class.
I’m a newbie and I don’t know much about C/C++ and, yes, this is going over my head. I tried using Arduino Core instead of Arduino as component and it works, so I could continue using that, but I want to learn and understand what’s happening and why it’s happening.
So, basically, the Constructor shows error “identifier undefined”
My code basically looks like this:
/* Blink Example
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <driver/gpio.h>
#include "sdkconfig.h"
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C(U8G2_R0,U8X8_PIN_NONE,21,22)
#if !CONFIG_AUTOSTART_ARDUINO
#else
u8g2.begin();
u8g2.firstPage();
do {
u8g2.setFont(u8g2_font_ncenB14_tr);
u8g2.drawStr(0,24,"Hello World!");
} while ( u8g2.nextPage() );
Does the project build in PlatformIO? Does the error show up after that, too? (Intelliesense errors are not always build errors and a result of the library bein temporarily not yet there yet or IntelliSense paths not being updated yet). If yes, does a project tasks → Miscellaneous → Rebuild IntelliSense help?
@maxgerhardt
It doesn’t
Here’s the error:
Compiling .pio/build/esp320/esp-idf/src/Blink.cpp.o src/Blink.cpp:29:1: error: 'U8G2_SSD1306_128X64_NONAME_F_HW_I2C' does not name a type U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, /* clock=*/ 22, /* data=*/ 21);
Aha, I can reproduce the error.
You see, all these classes (types) are only defined if
and that is only defined if
But when building in ESP-IDF + Arduino mode, apparently the ARDUINO macro isn’t set and thus also not the U8X8_USE_PINS
macro. (@valeros should that be fixed in the builder code maybe?)
Modify your project’s platformio.ini
to use another build_flags
directive like
[env]
framework = arduino, espidf
-D CONFIG_BLINK_GPIO=2
-D U8X8_USE_PINS
platform_packages =
; use a special branch
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#idf-release/v4.0
olikraus/U8g2 @ ^2.28.8
and it builds for me.
Linking .pio\build\esp32dev\firmware.elf
Building .pio\build\esp32dev\firmware.bin
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.6% (used 15052 bytes from 327680 bytes)
Flash: [== ] 18.6% (used 194709 bytes from 1048576 bytes)
esptool.py v3.0
============================================= [SUCCESS] Took 57.97 seconds =============================================
Thank you for the research and answer @maxgerhardt
Would it be too much trouble if I asked you more about this?
I’ve done the same backwards path in an Arduino framework project and also found that there’s no
#define ARDUINO
macro to be found, at least not in the project files. But the project builds without any build_flag
Why is this?
The Arduino-ESP32 builder script that is called by PlatformIO defines these macros.
CPPDEFINES=[
"ESP32",
"ESP_PLATFORM",
("F_CPU", "$BOARD_F_CPU"),
"HAVE_CONFIG_H",
("MBEDTLS_CONFIG_FILE", '\\"mbedtls/esp_config.h\\"'),
("ARDUINO", 10805),
"ARDUINO_ARCH_ESP32",
("ARDUINO_VARIANT", '\\"%s\\"' % env.BoardConfig().get("build.variant").replace('"', "")),
("ARDUINO_BOARD", '\\"%s\\"' % env.BoardConfig().get("name").replace('"', ""))
Apparantely in ESP-IDF + Arduino mode, just the ESP-IDF builder script takes over but doesn’t inject these macros.
The Arduino-IDE does that via a platform.txt
instruction.
# ESP32S2 Support Start
compiler.cpreprocessor.flags.esp32s2=-DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.3" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-I{compiler.sdk.path}/include/newlib/platform_include" "-I{compiler.sdk.path}/include/freertos/include" "-I{compiler.sdk.path}/include/freertos/include/esp_additions/freertos" "-I{compiler.sdk.path}/include/freertos/port/xtensa/include" "-I{compiler.sdk.path}/include/freertos/include/esp_additions" "-I{compiler.sdk.path}/include/esp_hw_support/include" "-I{compiler.sdk.path}/include/esp_hw_support/include/soc" "-I{compiler.sdk.path}/include/esp_hw_support/include/soc/esp32s2" "-I{compiler.sdk.path}/include/esp_hw_support/port/esp32s2" "-I{compiler.sdk.path}/include/esp_hw_support/port/esp32s2/private_include" "-I{compiler.sdk.path}/include/heap/include" "-I{compiler.sdk.path}/include/log/include" "-I{compiler.sdk.path}/include/lwip/include/apps" "-I{compiler.sdk.path}/include/lwip/include/apps/sntp" "-I{compiler.sdk.path}/include/lwip/lwip/src/include" "-I{compiler.sdk.path}/include/lwip/port/esp32/include" "-I{compiler.sdk.path}/include/lwip/port/esp32/include/arch" "-I{compiler.sdk.path}/include/soc/include" "-I{compiler.sdk.path}/include/soc/esp32s2" "-I{compiler.sdk.path}/include/soc/esp32s2/include" "-I{compiler.sdk.path}/include/hal/esp32s2/include" "-I{compiler.sdk.path}/include/hal/include" "-I{compiler.sdk.path}/include/hal/platform_port/include" "-I{compiler.sdk.path}/include/esp_rom/include" "-I{compiler.sdk.path}/include/esp_rom/include/esp32s2" "-I{compiler.sdk.path}/include/esp_rom/esp32s2" "-I{compiler.sdk.path}/include/esp_common/include" "-I{compiler.sdk.path}/include/esp_system/include" "-I{compiler.sdk.path}/include/esp_system/port/soc" "-I{compiler.sdk.path}/include/esp_system/port/public_compat" "-I{compiler.sdk.path}/include/xtensa/include" "-I{compiler.sdk.path}/include/xtensa/esp32s2/include" "-I{compiler.sdk.path}/include/driver/include" "-I{compiler.sdk.path}/include/driver/esp32s2/include" "-I{compiler.sdk.path}/include/esp_pm/include" "-I{compiler.sdk.path}/include/esp_ringbuf/include" "-I{compiler.sdk.path}/include/efuse/include" "-I{compiler.sdk.path}/include/efuse/esp32s2/include" "-I{compiler.sdk.path}/include/vfs/include" "-I{compiler.sdk.path}/include/esp_wifi/include" "-I{compiler.sdk.path}/include/esp_event/include" "-I{compiler.sdk.path}/include/esp_netif/include" "-I{compiler.sdk.path}/include/esp_eth/include" "-I{compiler.sdk.path}/include/tcpip_adapter/include" "-I{compiler.sdk.path}/include/esp_phy/include" "-I{compiler.sdk.path}/include/esp_phy/esp32s2/include" "-I{compiler.sdk.path}/include/esp_ipc/include" "-I{compiler.sdk.path}/include/app_trace/include" "-I{compiler.sdk.path}/include/esp_timer/include" "-I{compiler.sdk.path}/include/mbedtls/port/include" "-I{compiler.sdk.path}/include/mbedtls/mbedtls/include" "-I{compiler.sdk.path}/include/mbedtls/esp_crt_bundle/include" "-I{compiler.sdk.path}/include/app_update/include" "-I{compiler.sdk.path}/include/spi_flash/include" "-I{compiler.sdk.path}/include/bootloader_support/include" "-I{compiler.sdk.path}/include/nvs_flash/include" "-I{compiler.sdk.path}/include/pthread/include" "-I{compiler.sdk.path}/include/esp_gdbstub/include" "-I{compiler.sdk.path}/include/esp_gdbstub/xtensa" "-I{compiler.sdk.path}/include/esp_gdbstub/esp32s2" "-I{compiler.sdk.path}/include/espcoredump/include" "-I{compiler.sdk.path}/include/espcoredump/include/port/xtensa" "-I{compiler.sdk.path}/include/wpa_supplicant/include" "-I{compiler.sdk.path}/include/wpa_supplicant/port/include" "-I{compiler.sdk.path}/include/wpa_supplicant/esp_supplicant/include" "-I{compiler.sdk.path}/include/ieee802154/include" "-I{compiler.sdk.path}/include/console" "-I{compiler.sdk.path}/include/asio/asio/asio/include" "-I{compiler.sdk.path}/include/asio/port/include" "-I{compiler.sdk.path}/include/cbor/port/include" "-I{compiler.sdk.path}/include/unity/include" "-I{compiler.sdk.path}/include/unity/unity/src" "-I{compiler.sdk.path}/include/cmock/CMock/src" "-I{compiler.sdk.path}/include/coap/port/include" "-I{compiler.sdk.path}/include/coap/libcoap/include" "-I{compiler.sdk.path}/include/nghttp/port/include" "-I{compiler.sdk.path}/include/nghttp/nghttp2/lib/includes" "-I{compiler.sdk.path}/include/esp-tls" "-I{compiler.sdk.path}/include/esp-tls/esp-tls-crypto" "-I{compiler.sdk.path}/include/esp_adc_cal/include" "-I{compiler.sdk.path}/include/esp_hid/include" "-I{compiler.sdk.path}/include/tcp_transport/include" "-I{compiler.sdk.path}/include/esp_http_client/include" "-I{compiler.sdk.path}/include/esp_http_server/include" "-I{compiler.sdk.path}/include/esp_https_ota/include" "-I{compiler.sdk.path}/include/esp_https_server/include" "-I{compiler.sdk.path}/include/esp_lcd/include" "-I{compiler.sdk.path}/include/esp_lcd/interface" "-I{compiler.sdk.path}/include/protobuf-c/protobuf-c" "-I{compiler.sdk.path}/include/protocomm/include/common" "-I{compiler.sdk.path}/include/protocomm/include/security" "-I{compiler.sdk.path}/include/protocomm/include/transports" "-I{compiler.sdk.path}/include/mdns/include" "-I{compiler.sdk.path}/include/esp_local_ctrl/include" "-I{compiler.sdk.path}/include/sdmmc/include" "-I{compiler.sdk.path}/include/esp_serial_slave_link/include" "-I{compiler.sdk.path}/include/esp_websocket_client/include" "-I{compiler.sdk.path}/include/expat/expat/expat/lib" "-I{compiler.sdk.path}/include/expat/port/include" "-I{compiler.sdk.path}/include/wear_levelling/include" "-I{compiler.sdk.path}/include/fatfs/diskio" "-I{compiler.sdk.path}/include/fatfs/vfs" "-I{compiler.sdk.path}/include/fatfs/src" "-I{compiler.sdk.path}/include/freemodbus/common/include" "-I{compiler.sdk.path}/include/idf_test/include" "-I{compiler.sdk.path}/include/idf_test/include/esp32s2" "-I{compiler.sdk.path}/include/jsmn/include" "-I{compiler.sdk.path}/include/json/cJSON" "-I{compiler.sdk.path}/include/libsodium/libsodium/src/libsodium/include" "-I{compiler.sdk.path}/include/libsodium/port_include" "-I{compiler.sdk.path}/include/mqtt/esp-mqtt/include" "-I{compiler.sdk.path}/include/openssl/include" "-I{compiler.sdk.path}/include/perfmon/include" "-I{compiler.sdk.path}/include/spiffs/include" "-I{compiler.sdk.path}/include/usb/include" "-I{compiler.sdk.path}/include/touch_element/include" "-I{compiler.sdk.path}/include/ulp/include" "-I{compiler.sdk.path}/include/wifi_provisioning/include" "-I{compiler.sdk.path}/include/rmaker_common/include" "-I{compiler.sdk.path}/include/json_parser/upstream/include" "-I{compiler.sdk.path}/include/json_parser/upstream" "-I{compiler.sdk.path}/include/json_generator/upstream" "-I{compiler.sdk.path}/include/esp_schedule/include" "-I{compiler.sdk.path}/include/esp_rainmaker/include" "-I{compiler.sdk.path}/include/gpio_button/button/include" "-I{compiler.sdk.path}/include/qrcode/include" "-I{compiler.sdk.path}/include/ws2812_led" "-I{compiler.sdk.path}/include/esp_diagnostics/include" "-I{compiler.sdk.path}/include/rtc_store/include" "-I{compiler.sdk.path}/include/esp_insights/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/dotprod/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/support/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/hann/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman_harris/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman_nuttall/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/nuttall/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/flat_top/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/iir/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/fir/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/add/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/sub/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/mul/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/addc/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/mulc/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/sqrt/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/matrix/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/fft/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/dct/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/conv/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/common/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/kalman/ekf/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-I{compiler.sdk.path}/include/freertos/include/freertos" "-I{compiler.sdk.path}/include/arduino_tinyusb/tinyusb/src" "-I{compiler.sdk.path}/include/arduino_tinyusb/include" "-I{compiler.sdk.path}/include/esp_littlefs/include" "-I{compiler.sdk.path}/include/esp-dl/include" "-I{compiler.sdk.path}/include/esp-dl/include/tool" "-I{compiler.sdk.path}/include/esp-dl/include/typedef" "-I{compiler.sdk.path}/include/esp-dl/include/image" "-I{compiler.sdk.path}/include/esp-dl/include/math" "-I{compiler.sdk.path}/include/esp-dl/include/nn" "-I{compiler.sdk.path}/include/esp-dl/include/layer" "-I{compiler.sdk.path}/include/esp-dl/include/detect" "-I{compiler.sdk.path}/include/esp-dl/include/model_zoo" "-I{compiler.sdk.path}/include/esp-sr/esp-tts/esp_tts_chinese/include" "-I{compiler.sdk.path}/include/esp-sr/include/esp32" "-I{compiler.sdk.path}/include/esp-sr/src/include" "-I{compiler.sdk.path}/include/esp32-camera/driver/include" "-I{compiler.sdk.path}/include/esp32-camera/conversions/include" "-I{compiler.sdk.path}/include/fb_gfx/include"
compiler.c.elf.libs.esp32s2=-lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lusb -ltouch_element -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp_diagnostics -lrtc_store -lesp_insights -lesp-dsp -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lusb -ltouch_element -lcbor -lesp_diagnostics -lrtc_store -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -larduino_tinyusb -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -ljson -lspiffs -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lesp_phy -lphy -lesp_phy -lphy -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc
compiler.c.flags.esp32s2=-mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c
compiler.cpp.flags.esp32s2=-mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c
compiler.S.flags.esp32s2=-mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -x assembler-with-cpp -MMD -c
compiler.c.elf.flags.esp32s2=-T memory.ld -T sections.ld -T esp32s2.rom.ld -T esp32s2.rom.api.ld -T esp32s2.rom.libgcc.ld -T esp32s2.rom.newlib-funcs.ld -T esp32s2.rom.newlib-data.ld -T esp32s2.rom.spiflash.ld -T esp32s2.rom.newlib-time.ld -T esp32s2.peripherals.ld -mlongcalls -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy
compiler.ar.flags.esp32s2=cr
build.extra_flags.esp32s2=-DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT={build.cdc_on_boot} -DARDUINO_USB_MSC_ON_BOOT={build.msc_on_boot} -DARDUINO_USB_DFU_ON_BOOT={build.dfu_on_boot}
# ESP32S2 Support End
# ESP32C3 Support Start
compiler.cpreprocessor.flags.esp32c3=-DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.3" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-I{compiler.sdk.path}/include/newlib/platform_include" "-I{compiler.sdk.path}/include/freertos/include" "-I{compiler.sdk.path}/include/freertos/include/esp_additions/freertos" "-I{compiler.sdk.path}/include/freertos/port/riscv/include" "-I{compiler.sdk.path}/include/freertos/include/esp_additions" "-I{compiler.sdk.path}/include/esp_hw_support/include" "-I{compiler.sdk.path}/include/esp_hw_support/include/soc" "-I{compiler.sdk.path}/include/esp_hw_support/include/soc/esp32c3" "-I{compiler.sdk.path}/include/esp_hw_support/port/esp32c3" "-I{compiler.sdk.path}/include/esp_hw_support/port/esp32c3/private_include" "-I{compiler.sdk.path}/include/heap/include" "-I{compiler.sdk.path}/include/log/include" "-I{compiler.sdk.path}/include/lwip/include/apps" "-I{compiler.sdk.path}/include/lwip/include/apps/sntp" "-I{compiler.sdk.path}/include/lwip/lwip/src/include" "-I{compiler.sdk.path}/include/lwip/port/esp32/include" "-I{compiler.sdk.path}/include/lwip/port/esp32/include/arch" "-I{compiler.sdk.path}/include/soc/include" "-I{compiler.sdk.path}/include/soc/esp32c3" "-I{compiler.sdk.path}/include/soc/esp32c3/include" "-I{compiler.sdk.path}/include/hal/esp32c3/include" "-I{compiler.sdk.path}/include/hal/include" "-I{compiler.sdk.path}/include/hal/platform_port/include" "-I{compiler.sdk.path}/include/esp_rom/include" "-I{compiler.sdk.path}/include/esp_rom/include/esp32c3" "-I{compiler.sdk.path}/include/esp_rom/esp32c3" "-I{compiler.sdk.path}/include/esp_common/include" "-I{compiler.sdk.path}/include/esp_system/include" "-I{compiler.sdk.path}/include/esp_system/port/soc" "-I{compiler.sdk.path}/include/esp_system/port/include/riscv" "-I{compiler.sdk.path}/include/esp_system/port/public_compat" "-I{compiler.sdk.path}/include/riscv/include" "-I{compiler.sdk.path}/include/driver/include" "-I{compiler.sdk.path}/include/driver/esp32c3/include" "-I{compiler.sdk.path}/include/esp_pm/include" "-I{compiler.sdk.path}/include/esp_ringbuf/include" "-I{compiler.sdk.path}/include/efuse/include" "-I{compiler.sdk.path}/include/efuse/esp32c3/include" "-I{compiler.sdk.path}/include/vfs/include" "-I{compiler.sdk.path}/include/esp_wifi/include" "-I{compiler.sdk.path}/include/esp_event/include" "-I{compiler.sdk.path}/include/esp_netif/include" "-I{compiler.sdk.path}/include/esp_eth/include" "-I{compiler.sdk.path}/include/tcpip_adapter/include" "-I{compiler.sdk.path}/include/esp_phy/include" "-I{compiler.sdk.path}/include/esp_phy/esp32c3/include" "-I{compiler.sdk.path}/include/esp_ipc/include" "-I{compiler.sdk.path}/include/app_trace/include" "-I{compiler.sdk.path}/include/esp_timer/include" "-I{compiler.sdk.path}/include/mbedtls/port/include" "-I{compiler.sdk.path}/include/mbedtls/mbedtls/include" "-I{compiler.sdk.path}/include/mbedtls/esp_crt_bundle/include" "-I{compiler.sdk.path}/include/app_update/include" "-I{compiler.sdk.path}/include/spi_flash/include" "-I{compiler.sdk.path}/include/bootloader_support/include" "-I{compiler.sdk.path}/include/nvs_flash/include" "-I{compiler.sdk.path}/include/pthread/include" "-I{compiler.sdk.path}/include/esp_gdbstub/include" "-I{compiler.sdk.path}/include/esp_gdbstub/riscv" "-I{compiler.sdk.path}/include/esp_gdbstub/esp32c3" "-I{compiler.sdk.path}/include/espcoredump/include" "-I{compiler.sdk.path}/include/espcoredump/include/port/riscv" "-I{compiler.sdk.path}/include/wpa_supplicant/include" "-I{compiler.sdk.path}/include/wpa_supplicant/port/include" "-I{compiler.sdk.path}/include/wpa_supplicant/esp_supplicant/include" "-I{compiler.sdk.path}/include/ieee802154/include" "-I{compiler.sdk.path}/include/console" "-I{compiler.sdk.path}/include/asio/asio/asio/include" "-I{compiler.sdk.path}/include/asio/port/include" "-I{compiler.sdk.path}/include/bt/common/osi/include" "-I{compiler.sdk.path}/include/bt/include/esp32c3/include" "-I{compiler.sdk.path}/include/bt/common/api/include/api" "-I{compiler.sdk.path}/include/bt/common/btc/profile/esp/blufi/include" "-I{compiler.sdk.path}/include/bt/common/btc/profile/esp/include" "-I{compiler.sdk.path}/include/bt/host/bluedroid/api/include/api" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_common/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_core" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_core/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_core/storage" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/btc/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_models/common/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_models/client/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/mesh_models/server/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/api/core/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/api/models/include" "-I{compiler.sdk.path}/include/bt/esp_ble_mesh/api" "-I{compiler.sdk.path}/include/cbor/port/include" "-I{compiler.sdk.path}/include/unity/include" "-I{compiler.sdk.path}/include/unity/unity/src" "-I{compiler.sdk.path}/include/cmock/CMock/src" "-I{compiler.sdk.path}/include/coap/port/include" "-I{compiler.sdk.path}/include/coap/libcoap/include" "-I{compiler.sdk.path}/include/nghttp/port/include" "-I{compiler.sdk.path}/include/nghttp/nghttp2/lib/includes" "-I{compiler.sdk.path}/include/esp-tls" "-I{compiler.sdk.path}/include/esp-tls/esp-tls-crypto" "-I{compiler.sdk.path}/include/esp_adc_cal/include" "-I{compiler.sdk.path}/include/esp_hid/include" "-I{compiler.sdk.path}/include/tcp_transport/include" "-I{compiler.sdk.path}/include/esp_http_client/include" "-I{compiler.sdk.path}/include/esp_http_server/include" "-I{compiler.sdk.path}/include/esp_https_ota/include" "-I{compiler.sdk.path}/include/esp_https_server/include" "-I{compiler.sdk.path}/include/esp_lcd/include" "-I{compiler.sdk.path}/include/esp_lcd/interface" "-I{compiler.sdk.path}/include/protobuf-c/protobuf-c" "-I{compiler.sdk.path}/include/protocomm/include/common" "-I{compiler.sdk.path}/include/protocomm/include/security" "-I{compiler.sdk.path}/include/protocomm/include/transports" "-I{compiler.sdk.path}/include/mdns/include" "-I{compiler.sdk.path}/include/esp_local_ctrl/include" "-I{compiler.sdk.path}/include/sdmmc/include" "-I{compiler.sdk.path}/include/esp_serial_slave_link/include" "-I{compiler.sdk.path}/include/esp_websocket_client/include" "-I{compiler.sdk.path}/include/expat/expat/expat/lib" "-I{compiler.sdk.path}/include/expat/port/include" "-I{compiler.sdk.path}/include/wear_levelling/include" "-I{compiler.sdk.path}/include/fatfs/diskio" "-I{compiler.sdk.path}/include/fatfs/vfs" "-I{compiler.sdk.path}/include/fatfs/src" "-I{compiler.sdk.path}/include/freemodbus/common/include" "-I{compiler.sdk.path}/include/idf_test/include" "-I{compiler.sdk.path}/include/idf_test/include/esp32c3" "-I{compiler.sdk.path}/include/jsmn/include" "-I{compiler.sdk.path}/include/json/cJSON" "-I{compiler.sdk.path}/include/libsodium/libsodium/src/libsodium/include" "-I{compiler.sdk.path}/include/libsodium/port_include" "-I{compiler.sdk.path}/include/mqtt/esp-mqtt/include" "-I{compiler.sdk.path}/include/openssl/include" "-I{compiler.sdk.path}/include/spiffs/include" "-I{compiler.sdk.path}/include/wifi_provisioning/include" "-I{compiler.sdk.path}/include/rmaker_common/include" "-I{compiler.sdk.path}/include/json_parser/upstream/include" "-I{compiler.sdk.path}/include/json_parser/upstream" "-I{compiler.sdk.path}/include/json_generator/upstream" "-I{compiler.sdk.path}/include/esp_schedule/include" "-I{compiler.sdk.path}/include/esp_rainmaker/include" "-I{compiler.sdk.path}/include/gpio_button/button/include" "-I{compiler.sdk.path}/include/qrcode/include" "-I{compiler.sdk.path}/include/ws2812_led" "-I{compiler.sdk.path}/include/esp_diagnostics/include" "-I{compiler.sdk.path}/include/rtc_store/include" "-I{compiler.sdk.path}/include/esp_insights/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/dotprod/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/support/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/hann/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman_harris/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/blackman_nuttall/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/nuttall/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/windows/flat_top/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/iir/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/fir/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/add/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/sub/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/mul/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/addc/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/mulc/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/math/sqrt/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/matrix/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/fft/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/dct/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/conv/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/common/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/kalman/ekf/include" "-I{compiler.sdk.path}/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-I{compiler.sdk.path}/include/esp_littlefs/include" "-I{compiler.sdk.path}/include/esp-dl/include" "-I{compiler.sdk.path}/include/esp-dl/include/tool" "-I{compiler.sdk.path}/include/esp-dl/include/typedef" "-I{compiler.sdk.path}/include/esp-dl/include/image" "-I{compiler.sdk.path}/include/esp-dl/include/math" "-I{compiler.sdk.path}/include/esp-dl/include/nn" "-I{compiler.sdk.path}/include/esp-dl/include/layer" "-I{compiler.sdk.path}/include/esp-dl/include/detect" "-I{compiler.sdk.path}/include/esp-dl/include/model_zoo" "-I{compiler.sdk.path}/include/esp32-camera/driver/include" "-I{compiler.sdk.path}/include/esp32-camera/conversions/include" "-I{compiler.sdk.path}/include/fb_gfx/include"
compiler.c.elf.libs.esp32c3=-lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lspiffs -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp_diagnostics -lrtc_store -lesp_insights -lesp-dsp -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lcbor -lesp_diagnostics -lrtc_store -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lbtbb -lesp_phy -lphy -lbtbb -lesp_phy -lphy -lbtbb -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc
compiler.c.flags.esp32c3=-march=rv32imc -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Wno-error=format= -nostartfiles -Wno-format -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c
This file has been truncated. show original
See -DARDUINO=..
maxgerhardt:
"ARDUINO", 10805
Ok, I’m getting in a rabbit hole. That might take me a while to understand, but thank you for the patience and for replying.
Getting back to the business, that’s why you asked @valeros if this needs to be added to the builder or not, correct?
It might be an overlook or could be intentional, correct?
The Arduino IDE encodes the version of itself, e.g. “1.8.5” in the ARDUINO
macro as this integer, and since it’s passed to the compiler as a -DARDUINO=10805
flag macro value is globally visible in any file, so some libraries use this macro to determine in what environment they’re running in, nothing wild
Yes exactly, he’s a main developer of the platforms. It might be correct that a ARDUINO
macro is not added, or it might not be. But for you this seems to be right thing to make the library happy.
