Add a folder directory to libraries in PlataformIO [include_dir]
Hello, im trying to organize a code by features on PlatformIO i.e,
src
— main.cpp
— features
------ DAQ
--------- dataacquisition.h
--------- dataacquisition.cpp
------ packet
--------- packet.h
--------- packet.cpp
— core
------ pinSetup.h
I try to use
[plataformIO]
include_dir = src/features/DAQ
and it works for this one, but when i try to use both:
[plataformIO]
include_dir = src/features/packet
didnt work, actually i wish i could just make include_dir = scr/, and the compiler scan through all the paths on the src/: features/DAQ, features/packet and core/. Any ideias?
Best Regards
You’re using the wrong setting – include_dir is meant so that you can change the default path of the standard include directory, which is the include/ folder in the project. It’s not meant to support multiple directories (“multiple: no” as seen in the docs).
What you seem to want to do is add multiple directories to the include search path. Thas is done with build_flags as documented. It can be either put in every environment or in the [env] section. Example
[env]
   -I src/features/DAQ
   -I src/features/packet
[env:esp32]
