Adafruit_TinyUSB_Arduino on ESP32-S3 and USB MSC
Issues with Adafruit_TinyUSB_Arduino on ESP32-S3 and USB MSC
Hello everyone,
I am experiencing difficulties getting the Adafruit_TinyUSB_Arduino library to work correctly on an ESP32-S3, using the USB MSC mode to access an SD card. I tried the “msc_sdfat” example proposed by Adafruit (link here), but I’m facing stability issues.
Context
Following a post on the PlatformIO forum (link here), I was able to resolve compilation issues using a solution proposed by maxgerhardt. This solution managed to address the include order issues related to TinyUSB configuration in PlatformIO.
I have subsequently been able to compile the project and upload it to my board. Maxgerhardt also created a git repository to start a base project with the Adafruit_TinyUSB library that compiles on ESP32-S3 (link in comment).
However, here’s what’s happening. When I upload the code to the board, there is a successful serial communication that displays SD card information. However, this serial communication seems to fail and resets in a loop. Occasionally, the ESP interacts with my computer and appears as a USB-MSC with the name of my SD card, but disappears immediately.
Configuration
My board is a custom board with an ESP32-S3-WROOM-1. All communications to the computer are done via USB pin. I would like to know if I can use the serial monitor and the USB MSC on the same hardware. Otherwise, what could be the problem?
Here is my platformio.ini file:
[env:esp32s3box]
board = esp32s3box
   https://github.com/maxgerhardt/Adafruit_TinyUSB_Arduino/archive/refs/heads/master.zip
build_unflags = -DARDUINO_USB_MODE=1
   -DUSE_TINYUSB=true
   -DCDC_ENABLED=0
   -DCORE_DEBUG_LEVEL=5
   -DARDUINO_USB_MODE=0
   -Iinclude/
   '-DCFG_TUSB_CONFIG_FILE"'tusb_config_esp32.h"'
lib_archive = no
; Serial Monitor options
monitor_filters =
   debug
In an attempt to troubleshoot the issue, I tried to enable TinyUSB debug logging as explained in the same (link in the comment).
Execution of the task:
Here is the output of my monitor
 *  Exécution de la tâche : platformio device monitor --environment esp32s3box --port /dev/cu.usbmodem3485187020082
 --- Terminal on /dev/cu.usbmodem3485187020082 | 115200 8-N-1
 --- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
 --- More details at https://bit.ly/pio-monitor-filters
 --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
 Disconnected (read failed: [Errno 6] Device not configured)
 Reconnecting to /dev/cu.usbmodem3485187020082 .  Connected!
 SD contents:
          0 .Spotlight-V100/
         18 test.txt
          0 foo.txt
          0 coucou.txt
          0 .Trashes/
          0 ._coucou.txt
          0 ._test.txt
          0 .fseventsd/
 Reconnecting to /dev/cu.usbmodem3485187020082    Connected!
 SD contents:
          0 .Spotlight-V100/
         18 test.txt
          0 foo.txt
          0 coucou.txt
          0 .Trashes/
          0 ._coucou.txt
          0 ._test.txt
          0 .fseventsd/
My device, before being flashed, appears as:
/dev/cu.usbmodem14201  USB JTAG/serial debug unit USB VID:PID=303A:1001 SER=34:85:18:70:20:08 LOCATION=0-1.4.2
And after flashing and resetting, it appears as:
/dev/cu.usbmodem3485187020082  Espressif ESP32-S3-Box USB VID:PID=303A:1001 SER=348518702008 LOCATION=0-1.4.2
I’m not sure if this is a compatibility issue between the USB Serial and USB MSC or if there’s something else I am missing. Any guidance or suggestions would be greatly appreciated.
Thanks for your time!
Github Repository Adafruit_TinyUSB library that compiles on ESP32-S3
TinyUSB debug
Have you tried against the regular Adafruit Master, not my fork? The fix has already landed in there after all.
Thanks for your answer. I changed the version of the library and in build_flags, I gave the full path
adafruit/Adafruit TinyUSB Library@^2.2.2
‘-DCFG_TUSB_CONFIG_FILE=“/Users/nicolas/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/arduino_tinyusb/include/tusb_config.h”’
However, the problem remains the same. I found a post from March 2023 that managed to get the AdaFruit TinyUSB library to work on an ESP32-S3 by changing the framework of espressif/arduino-esp32 to version v2.0.0
I’ve tried to change version by following the steps explained here but can’t compile. I admit I’d rather avoid going back to an old branch.
Do you have any other suggestions?
I finally did it! I used another script from the AdaFruit examples to expose the SD card via USB and Wifi. After adapting it to my hardware, the SD card appears correctly via USB and works perfectly. I didn’t really understand it, but I think the card had to be powered up, then switched on and connected via USB. In my numerous attempts, the card was permanently connected via USB…
For those who would like the Adafruit code adapted to a custom SPI port and use the SD card as a storage medium (not the internal flahs) accessible via USB MSC or Wifi here is the code:
 Adafruit invests time and resources providing this open source code,
 please support Adafruit and open-source hardware by purchasing
 products from Adafruit!
 MIT license, check LICENSE for more information
 Copyright (c) 2019 Ha Thach for Adafruit Industries
 All text above, and the splash screen below must be included in
 any redistribution
/* This example expose SD card as mass storage using
 * SdFat Library
 any redistribution
/* This example is based on "arduino-esp32/libraries/WebServer/examples/FSBrowser"
 * to expose on-board external Flash as USB Mass Storage and webserver. Both interfaces
 * can make changes to file system
 * How to run this example
 * 1. Create secrets.h and define your "SECRET_SSID" and "SECRET_PASSWORD"
 * 2. Compile and upload this sketch
 * 3. Your ESP will be expose as MassStorage device.
 * 4. If it is your first run (otherwise skip this step):
 *   - you may need to format the drive as FAT. Note: If your PC failed to format, you could format
 *     it using follow sketch "https://github.com/adafruit/Adafruit_SPIFlash/tree/master/examples/SdFat_format"
 *   - Copy all files in 'data/' folder of this example to the root directory of the MassStorage disk drive
 * 5. When prompted, open http://esp32fs.local/edit to access the file browser
 * 6. Modify/Update USB drive then refresh your browser to see if the change is updated
 * 7. Upload/Edit a file using web browser then see if the USB Drive is updated. Note: the usb drive could
 * briefly disappear and reappear to force PC to refresh its cache
 * NOTE: Following library is required
 *   - Adafruit_SPIFlash https://github.com/adafruit/Adafruit_SPIFlash
 *   - SdFat https://github.com/adafruit/SdFat
#include "SPI.h"
#include "SdFat.h"
#include "Adafruit_SPIFlash.h"
#include "Adafruit_TinyUSB.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
// check if secrets.h is includable, if not please
// create one with SSDI & PASSWORD macro as following example:
#if __has_include("secrets.h")
  #include "secrets.h"
#else
  #warning "Please create secrets.h with SSID & PASSWORD defined"
  #define SECRET_SSID      "your-ssid"
  #define SECRET_PASSWORD  "your-password"
// Debug with FTDI (Serial0) or USBCDC (Serial)
#define DBG_SERIAL Serial
// ESP32 use same flash device that store code.
// Therefore there is no need to specify the SPI and SS
Adafruit_FlashTransport_ESP32 flashTransport;
Adafruit_SPIFlash flash(&flashTransport);
// file system object from SdFat
FatVolume fatfs;
// File system on SD Card
SdFat sd;
SdFile root;
SdFile file;
// USB Mass Storage object
Adafruit_USBD_MSC usb_msc;
bool fs_formatted;  // Check if flash is formatted
bool fs_changed;    // Set to true when browser write to flash
const char* host = "esp32fs";
WebServer server(80);
//holds the current upload
File32 fsUploadFile;
const int chipSelect = 44;
#define SPI_MISO 42
#define SPI_MOSI 1
#define SPI_SCLK 2
#define SPI_SS 44
#define LED_BUILTIN 38
void setupMassStorage(void);
void refreshMassStorage(void);
void setupServer(void);
String formatBytes(size_t bytes);
String getContentType(String filename);
bool exists(String path);
bool handleFileRead(String path);
void handleFileUpload();
void handleFileDelete();
void handleFileCreate();
void handleFileList();
bool msc_ready_callback(void);
int32_t msc_read_cb (uint32_t lba, void* buffer, uint32_t bufsize);
int32_t msc_write_cb (uint32_t lba, uint8_t* buffer, uint32_t bufsize);
void msc_flush_cb (void);
// Setup
  // Initialiser la carte SD
  SPI.begin(SPI_SCLK, SPI_MISO, SPI_MOSI, SPI_SS);
  if ( !sd.begin(chipSelect, SD_SCK_MHZ(50)) )
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1) delay(1);
    // Size in blocks (512 bytes)
  #if SD_FAT_VERSION >= 20000
    uint32_t block_count = sd.card()->sectorCount();
  #else
    uint32_t block_count = sd.card()->cardSize();
  // Set disk vendor id, product id and revision with string up to 8, 16, 4 characters respectively
  usb_msc.setID("Adafruit", "External Flash", "1.0");
  // Set callback
  usb_msc.setReadWriteCallback(msc_read_cb, msc_write_cb, msc_flush_cb);
  // Set disk size, SD block size is always 512
  usb_msc.setCapacity(block_count, 512);
  // MSC is ready for read/write
  fs_changed = false;
  usb_msc.setReadyCallback(0, msc_ready_callback);
  usb_msc.begin();
  // Init file system on the flash
  fs_formatted = fatfs.begin(sd.card());
  if ( !fs_formatted )
    DBG_SERIAL.println("Failed to init files system, flash may not be formatted");
  flash.begin();
  fs_changed = true;
  //WIFI INIT
  DBG_SERIAL.printf("Connecting to %s\n", SECRET_SSID);
  if (String(WiFi.SSID()) != String(SECRET_SSID)) {
    WiFi.mode(WIFI_STA);
    WiFi.begin(SECRET_SSID, SECRET_PASSWORD);
    delay(500);
    DBG_SERIAL.print(".");
  DBG_SERIAL.println("");
  DBG_SERIAL.print("Connected! IP address: ");
  DBG_SERIAL.println(WiFi.localIP());
  MDNS.begin(host);
  DBG_SERIAL.print("Open http://");
  DBG_SERIAL.print(host);
  DBG_SERIAL.println(".local/edit to access the file browser");
  //SERVER INIT
  //list directory
  server.on("/list", HTTP_GET, handleFileList);
  //load editor
  server.on("/edit", HTTP_GET, []() {
    if (!handleFileRead("/edit.htm")) {
      server.send(404, "text/plain", "FileNotFound");
  //create file
  server.on("/edit", HTTP_PUT, handleFileCreate);
  //delete file
  server.on("/edit", HTTP_DELETE, handleFileDelete);
  //first callback is called after the request has ended with all parsed arguments
  //second callback handles file uploads at that location
  server.on("/edit", HTTP_POST, []() {
    server.send(200, "text/plain", "");
  }, handleFileUpload);
  //called when the url is not defined here
  //use it to load content from fatfs
  server.onNotFound([]() {
    if (!handleFileRead(server.uri())) {
  //get heap status, analog input value and all GPIO statuses in one json call
  server.on("/all", HTTP_GET, []() {
    String json = "{";
    json += "\"heap\":" + String(ESP.getFreeHeap());
    json += ", \"gpio\":" + String((uint32_t)(0));
    json += "}";
    server.send(200, "text/json", json);
    json = String();
  server.begin();
  DBG_SERIAL.println("HTTP server started");
void setup()
#ifdef LED_BUILTIN
  pinMode(LED_BUILTIN, OUTPUT);
  DBG_SERIAL.begin(115200);
  setupMassStorage();
  //  while ( !DBG_SERIAL ) delay(10);   // wait for native usb
  DBG_SERIAL.println("TinyUSB Mass Storage with ESP32 File Browser example");
  DBG_SERIAL.print("JEDEC ID: 0x"); DBG_SERIAL.println(flash.getJEDECID(), HEX);
  DBG_SERIAL.print("Flash size: "); DBG_SERIAL.print(flash.size() / 1024); DBG_SERIAL.println(" KB");
  setupServer();
// Handle requests
//format bytes
String formatBytes(size_t bytes) {
  if (bytes < 1024) {
    return String(bytes) + "B";
  } else if (bytes < (1024 * 1024)) {
    return String(bytes / 1024.0) + "KB";
  } else if (bytes < (1024 * 1024 * 1024)) {
    return String(bytes / 1024.0 / 1024.0) + "MB";
  } else {
    return String(bytes / 1024.0 / 1024.0 / 1024.0) + "GB";
String getContentType(String filename) {
  if (server.hasArg("download")) {
    return "application/octet-stream";
  } else if (filename.endsWith(".htm")) {
    return "text/html";
  } else if (filename.endsWith(".html")) {
    return "text/html";
  } else if (filename.endsWith(".css")) {
    return "text/css";
  } else if (filename.endsWith(".js")) {
    return "application/javascript";
  } else if (filename.endsWith(".png")) {
    return "image/png";
  } else if (filename.endsWith(".gif")) {
    return "image/gif";
  } else if (filename.endsWith(".jpg")) {
    return "image/jpeg";
  } else if (filename.endsWith(".ico")) {
    return "image/x-icon";
  } else if (filename.endsWith(".xml")) {
    return "text/xml";
  } else if (filename.endsWith(".pdf")) {
    return "application/x-pdf";
  } else if (filename.endsWith(".zip")) {
    return "application/x-zip";
  } else if (filename.endsWith(".gz")) {
    return "application/x-gzip";
  return "text/plain";
bool exists(String path){
  bool yes = false;
  File32 file = fatfs.open(path, O_READ);
  if(file && !file.isDirectory()){
    yes = true;
  file.close();
  return yes;
bool handleFileRead(String path) {
  DBG_SERIAL.println("handleFileRead: " + path);
  if (path.endsWith("/")) {
    path += "index.htm";
  String contentType = getContentType(path);
//  String pathWithGz = path + ".gz";
  if ( /*exists(pathWithGz) ||*/ exists(path)) {
//    if (exists(pathWithGz)) {
//      path += ".gz";
    server.streamFile(file, contentType);
    file.close();
    return true;
  return false;
void handleFileUpload() {
  if (server.uri() != "/edit") {
    return;
  HTTPUpload& upload = server.upload();
  if (upload.status == UPLOAD_FILE_START) {
    String filename = upload.filename;
    if (!filename.startsWith("/")) {
      filename = "/" + filename;
    DBG_SERIAL.print("handleFileUpload Name: "); DBG_SERIAL.println(filename);
    fsUploadFile = fatfs.open(filename, O_WRITE | O_CREAT | O_TRUNC);
    filename = String();
  } else if (upload.status == UPLOAD_FILE_WRITE) {
    DBG_SERIAL.print("handleFileUpload Data: "); DBG_SERIAL.println(upload.currentSize);
    if (fsUploadFile) {
      fsUploadFile.write(upload.buf, upload.currentSize);
    }else
      DBG_SERIAL.print("handleFileUpload file is not opened !!!");
  } else if (upload.status == UPLOAD_FILE_END) {
    if (fsUploadFile) {
      fsUploadFile.close();
      refreshMassStorage();
    DBG_SERIAL.print("handleFileUpload Size: "); DBG_SERIAL.println(upload.totalSize);
void handleFileDelete() {
  if (server.args() == 0) {
    return server.send(500, "text/plain", "BAD ARGS");
  String path = server.arg(0);
  DBG_SERIAL.println("handleFileDelete: " + path);
  if (path == "/") {
    return server.send(500, "text/plain", "BAD PATH");
  if (!exists(path)) {
    return server.send(404, "text/plain", "FileNotFound");
  fatfs.remove(path.c_str());
  path = String();
void handleFileCreate() {
  DBG_SERIAL.println("handleFileCreate: " + path);
  if (path == "/") {
  if (exists(path)) {
    return server.send(500, "text/plain", "FILE EXISTS");
  File32 file = fatfs.open(path, O_WRITE | O_CREAT);
  if (file) {
    file.close();
  } else {
    return server.send(500, "text/plain", "CREATE FAILED");
  path = String();
void handleFileList() {
  if (!server.hasArg("dir")) {
    return;
  String path = server.arg("dir");
  DBG_SERIAL.println("handleFileList: " + path);
  File32 root = fatfs.open(path);
  path = String();
  String output = "[";
  if(root.isDirectory()){
      File32 file = root.openNextFile();
      char fname[256];
      while(file){
          if (output != "[") {
            output += ',';
          output += "{\"type\":\"";
          output += (file.isDirectory()) ? "dir" : "file";
          output += "\",\"name\":\"";
          //output += String(file.path()).substring(1);
          file.getName(fname, sizeof(fname));
          output += fname;
          output += "\"}";
  output += "]";
  server.send(200, "text/json", output);
// Loop
void loop()
  server.handleClient();
  delay(2);//allow the cpu to switch to other tasks
// Callback invoked when received READ10 command.
// Copy disk's data to buffer (up to bufsize) and
// return number of copied bytes (must be multiple of block size)
  bool rc;
  rc = sd.card()->readSectors(lba, (uint8_t*) buffer, bufsize/512);
#else
  rc = sd.card()->readBlocks(lba, (uint8_t*) buffer, bufsize/512);
  return rc ? bufsize : -1;
// Callback invoked when received WRITE10 command.
// Process data in buffer to disk's storage and
// return number of written bytes (must be multiple of block size)
  bool rc;
  rc = sd.card()->writeSectors(lba, buffer, bufsize/512);
#else
  rc = sd.card()->writeBlocks(lba, buffer, bufsize/512);
// Callback invoked when WRITE10 command is completed (status received and accepted by host).
// used to flush any pending cache.
  sd.card()->syncDevice();
#else
  sd.card()->syncBlocks();
  // clear file system's cache to force refresh
  sd.cacheClear();
  fs_changed = true;
// Invoked when received Test Unit Ready command.
// return true allowing host to read/write this LUN e.g SD card inserted
  // if fs has changed, mark unit as not ready temporarily to force PC to flush cache
  bool ret = !fs_changed;
  fs_changed = false;
  return ret;
Here is my platform.ini file :
[env:esp32s3box]
board = esp32s3box
-DUSE_TINYUSB=true
-DCDC_ENABLED=0
'-DCFG_TUSB_CONFIG_FILE="/Users/nicolas/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/arduino_tinyusb/include/tusb_config.h"'
