Platformio.ini
[env:esp32-s3-supermini]
board = esp32-s3-devkitc-1
board_build.flash_size = 4MB
board_upload.flash_size = 4MB
board_build.partitions = default.csv
-D ARDUINO_USB_MODE=1
-D ARDUINO_USB_CDC_ON_BOOT=1
-D CFG_TUD_ENABLED=1
-D USE_TINYUSB
witnessmenow/UniversalTelegramBot@^1.3.0
bblanchon/ArduinoJson@^7.2.2
adafruit/Adafruit TinyUSB Library@^3.7.7
#include <Adafruit_TinyUSB.h>
uint8_t const desc_boot_keyboard[] = {
TUD_HID_REPORT_DESC_KEYBOARD()
Adafruit_USBD_HID usb_boot_kbd;
void sendKey(uint8_t keycode) {
uint8_t keys[6] = { keycode, 0, 0, 0, 0, 0 };
usb_boot_kbd.keyboardReport(0, 0, keys);
delay(100);
usb_boot_kbd.keyboardRelease(0);
void sendString(const char* str) {
while (*str) {
char c = *str;
uint8_t key = 0;
if (c >= '0' && c <= '9') {
key = (c == '0') ? HID_KEY_0 : (HID_KEY_1 + (c - '1'));
} else if (c >= 'a' && c <= 'z') {
key = HID_KEY_A + (c - 'a');
} else if (c >= 'A' && c <= 'Z') {
key = HID_KEY_A + (c - 'A');
if (key != 0) {
sendKey(key);
delay(50);
str++;
TinyUSBDevice.begin();
usb_boot_kbd.setPollInterval(2);
usb_boot_kbd.setReportDescriptor(desc_boot_keyboard, sizeof(desc_boot_keyboard));
usb_boot_kbd.setBootProtocol(true);
usb_boot_kbd.begin();
Serial.println("USB Mount bekleniyor...");
unsigned long startMount = millis();
while (!TinyUSBDevice.mounted() && (millis() - startMount < 60000)) {
delay(1000);
Serial.print(".");
Serial.println("\n"+TinyUSBDevice.mounted());
I have a “ESP32 S3 Super Mini”. When I upload this code to board, it prints
“… (57 dot)” and nothing else.
When I add this code to end of setup function :
sendString("Hello, World!");
assert failed: xQueueSemaphoreTake queue.c:1545 (( pxQueue ))
Backtrace: 0x403777da:0x3fcebc90 0x4037ac41:0x3fcebcb0 0x403805a9:0x3fcebcd0 0x4037b9a2:0x3fcebe00 0x42001f95:0x3fcebe40 0x42001d11:0x3fcebe60 0x42001c02:0x3fcebe80 0x42001ca7:0x3fcebeb0 0x42001bbb:0x3fcebee0 0x420017c4:0x3fcebf00 0x420017f9:0x3fcebf30 0x420018aa:0x3fcebf50 0x420035e6:0x3fcebf70
ELF file SHA256: 50183c5a88f78d56
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x42021dee
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
when i do -D ARDUINO_USB_MODE=0
I cant compile the code.
I think I cant write this code with another library because I want to start computer with this func:
void triggerWakeup() {
if (tud_suspended()) {
tud_remote_wakeup();
if(wait(250)){
return;
sendKey(HID_KEY_SPACE);
How can i fix it…
