Hello, I’ve been working with this libraries for a few weeks know and know when i try to compile my project that uses Adafruit LedBackpack i get this error:
Adafruit_SPIDevice.h:82:71: error: could not convert '& ASPI' from 'ASPI_t*' to 'SPIClass*'
I have the project i coded but I’ve also done a minimal code to see where it crashes and it happens as soon as i #include <Adafruit_LEDBackpack.h>
This is my platformio.ini:
[platformio]
default_envs = debug
[env:release]
platform = atmelsam
board = due
lib_ldf_mode = deep
lib_extra_dirs = ../../libs, ../../external
adafruit/Adafruit DRV2605 Library@^1.2.0
adafruit/Adafruit BusIO @ ^1.11.5
https://github.com/adafruit/Adafruit_LED_Backpack.git
adafruit/Adafruit GFX Library @ ^1.11.0
[env:debug]
platform = atmelsam
board = due
lib_ldf_mode = deep
build_flags = -DDEBUG=1
What’s the minimal code with which this issue can be reproduced?
MinimalMachin.h:
// Audio Includes
#include <SdFat.h>
#include <AudioI2S.h>
// Touch Screen Includes
#include <GD2.h>
// Motor Includes
#include <Adafruit_DRV2605.h>
// Visual Includes
#include <DueFlashStorage.h>
main.cpp:
#include "MachineTest.h"
void setup(){
void loop(){
So basically i get an error when importing <Adafruit_LEDBackpack.h>
. If i want to build other projects that were working on debug
environment, with a release
environment i get the same error.
Basically just importing <Adafruit_LEDBackpack.h>
I’m getting an error
I cannot reproduce this issue with
[env:due]
platform = atmelsam
board = due
and code
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
void setup() { }
void loop() {}
builds fine
Processing due (platform: atmelsam; board: due; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/due.html
PLATFORM: Atmel SAM (8.0.0) > Arduino Due (Programming Port)
HARDWARE: AT91SAM3X8E 84MHz, 96KB RAM, 512KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink, stlink)
- framework-arduino-sam @ 1.6.12
- framework-cmsis @ 1.40500.0 (4.5.0)
- framework-cmsis-atmel @ 1.2.2
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 11 compatible libraries
|-- Adafruit LED Backpack Library @ 1.3.2+sha.508c0e6
| |-- Adafruit BusIO @ 1.11.6
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- Adafruit GFX Library @ 1.11.2
| | | |-- Wire @ 1.0
| | | |-- SPI @ 1.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- SPI @ 1.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- SPI @ 1.0
|-- Wire @ 1.0
|-- SPI @ 1.0
Compiling .pio\build\due\src\main.cpp.o
Compiling .pio\build\due\libd0b\Wire\Wire.cpp.o
Compiling .pio\build\due\lib0e2\SPI\SPI.cpp.o
Compiling .pio\build\due\lib1d6\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Compiling .pio\build\due\lib1d6\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\due\lib1d6\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\due\lib57e\Adafruit GFX Library\Adafruit_GFX.cpp.o
In file included from C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.cpp:25:0:
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.h: In constructor 'TwoWire::TwoWire(Twi*, void (*)(), void (*)())':
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.h:96:7: warning: 'TwoWire::twi' will be initialized after [-Wreorder]
Twi *twi;
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.h:72:10: warning: 'uint8_t TwoWire::rxBufferIndex' [-Wreorder]
uint8_t rxBufferIndex;
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.cpp:95:1: warning: when initialized here [-Wreorder]
TwoWire::TwoWire(Twi *_twi, void(*_beginCb)(void), void(*_endCb)(void)) :
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.h:108:16: warning: 'TwoWire::status' will be initialized after [-Wreorder]
TwoWireStatus status;
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\libraries\Wire\src\Wire.h:90:30: warning: 'void (* TwoWire::onBeginCallback)()' [-Wreorder]
void (*onBeginCallback)(void);
Compiling .pio\build\due\lib57e\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Compiling .pio\build\due\lib57e\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
Compiling .pio\build\due\lib57e\Adafruit GFX Library\glcdfont.c.o
Compiling .pio\build\due\libd4c\Adafruit LED Backpack Library\Adafruit_LEDBackpack.cpp.o
Compiling .pio\build\due\FrameworkArduinoVariant\variant.cpp.o
Compiling .pio\build\due\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\due\FrameworkArduino\Print.cpp.o
Compiling .pio\build\due\FrameworkArduino\Reset.cpp.o
Compiling .pio\build\due\FrameworkArduino\RingBuffer.cpp.o
Archiving .pio\build\due\lib0e2\libSPI.a
Archiving .pio\build\due\libd0b\libWire.a
Compiling .pio\build\due\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\due\FrameworkArduino\UARTClass.cpp.o
Compiling .pio\build\due\FrameworkArduino\USARTClass.cpp.o
Compiling .pio\build\due\FrameworkArduino\USB\CDC.cpp.o
Archiving .pio\build\due\lib1d6\libAdafruit BusIO.a
Compiling .pio\build\due\FrameworkArduino\USB\PluggableUSB.cpp.o
Compiling .pio\build\due\FrameworkArduino\USB\USBCore.cpp.o
Compiling .pio\build\due\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\due\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\due\FrameworkArduino\WString.cpp.o
Archiving .pio\build\due\libFrameworkArduinoVariant.a
Compiling .pio\build\due\FrameworkArduino\abi.cpp.o
Compiling .pio\build\due\FrameworkArduino\avr\dtostrf.c.o
Compiling .pio\build\due\FrameworkArduino\cortex_handlers.c.o
Compiling .pio\build\due\FrameworkArduino\hooks.c.o
Compiling .pio\build\due\FrameworkArduino\iar_calls_sam3.c.o
Compiling .pio\build\due\FrameworkArduino\itoa.c.o
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp: In function 'void USB_ISR()':
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp:688:21: warning: this 'else' clause does not guard... [-Wmisleading-indentation]
else
C:\Users\Max Gerhardt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp:690:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'else'
UDD_Send8(EP0, 0);
Archiving .pio\build\due\libd4c\libAdafruit LED Backpack Library.a
Compiling .pio\build\due\FrameworkArduino\main.cpp.o
Compiling .pio\build\due\FrameworkArduino\new.cpp.o
Compiling .pio\build\due\FrameworkArduino\syscalls_sam3.c.o
Compiling .pio\build\due\FrameworkArduino\watchdog.cpp.o
Compiling .pio\build\due\FrameworkArduino\wiring.c.o
Compiling .pio\build\due\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\due\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\due\FrameworkArduino\wiring_pulse.cpp.o
Compiling .pio\build\due\FrameworkArduino\wiring_pulse_asm.S.o
Compiling .pio\build\due\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\due\lib57e\libAdafruit GFX Library.a
Archiving .pio\build\due\libFrameworkArduino.a
Linking .pio\build\due\firmware.elf
Checking size .pio\build\due\firmware.elf
RAM: [ ] 3.0% (used 2980 bytes from 98304 bytes)
Flash: [= ] 5.1% (used 26664 bytes from 524288 bytes)
Building .pio\build\due\firmware.bin
============================================================================== [SUCCESS] Took 4.63 seconds ==============================================================================
Can you reproduce that?
Even with
[env:due]
platform = atmelsam
board = due
and
#include <Adafruit_SPIDevice.h>
void setup() { }
void loop() {}
no error.
I did a clean install of all repos with a new computer and had the same problem. Maybe if you install also SdFat, Audio and GD2?
GD2 is the problem.
.pio\libdeps\due\gd2-lib/GD2.h:133:13: error: conflicting declaration 'SPIClass ASPI'
#define SPI ASPI
just redefining the crucial SPI
object to ASPI
in the header… what is this library thinking?
Reordering the includes solves it though.
#include <SdFat.h>
#include <GD2.h>
void setup() { }
void loop() {}
with
[env:due]
platform = atmelsam
board = due
https://github.com/maxgerhardt/gd2-lib.git
greiman/SdFat@^2.1.2
https://github.com/fraimondo/DueFlashStorage.git
but this is a HUGE code smell on why GD2.h is doing that.
Other parts lower in the code which try to access “SPI” but get this weird “ASPI” object will be problematic though.
I’ve updated my version of the GD2 lib to solve this properly: GitHub - maxgerhardt/gd2-lib: Gameduino 2/3/3X library sources
You can use that with the same platformio.ini
above, just delete the .pio
folder prior to rebuilding so that it pulls the latest version. Then the SPI
redefine only happens in the one cpp file that needs it.
I included your GS2 library (which i already manually had installed) in the platformio, i changed the #include <GD2.h>
at the end of includes.
But now I am getting this error:
In file included from /Users/$$/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp:2:0:
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::desel()':
.pio/libdeps/debug/gd2-lib/GD2.h:179:5: error: 'SPI' was not declared in this scope
SPI.transfer(0xff); // force DO release
.pio/libdeps/debug/gd2-lib/GD2.h:179:5: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::sd_delay(byte)':
.pio/libdeps/debug/gd2-lib/GD2.h:183:7: error: 'SPI' was not declared in this scope
SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:183:7: note: suggested alternative: 'ASPI'
SPI.transfer(0xff);
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::cmd(byte, uint32_t, uint8_t)':
.pio/libdeps/debug/gd2-lib/GD2.h:197:5: error: 'SPI' was not declared in this scope
SPI.transfer(0x40 | cmd);
.pio/libdeps/debug/gd2-lib/GD2.h:197:5: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'byte sdcard::response()':
.pio/libdeps/debug/gd2-lib/GD2.h:207:9: error: 'SPI' was not declared in this scope
r = SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:207:9: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'byte sdcard::R1()':
.pio/libdeps/debug/gd2-lib/GD2.h:217:5: error: 'SPI' was not declared in this scope
SPI.transfer(0xff); // trailing byte
.pio/libdeps/debug/gd2-lib/GD2.h:217:5: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'byte sdcard::sdR3(uint32_t&)':
.pio/libdeps/debug/gd2-lib/GD2.h:224:26: error: 'SPI' was not declared in this scope
ocr = (ocr << 8) | SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:224:26: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h:225:5: error: 'SPI' was not declared in this scope
.pio/libdeps/debug/gd2-lib/GD2.h:225:5: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'byte sdcard::sdR7()':
.pio/libdeps/debug/gd2-lib/GD2.h:235:7: error: 'SPI' was not declared in this scope
SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:235:7: note: suggested alternative: 'ASPI'
SPI.transfer(0xff);
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::begin(byte)':
.pio/libdeps/debug/gd2-lib/GD2.h:267:20: error: 'SPI' was not declared in this scope
while ((r1 = SPI.transfer(0xff)) & 0x80)
.pio/libdeps/debug/gd2-lib/GD2.h:267:20: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h:271:7: error: 'SPI' was not declared in this scope
.pio/libdeps/debug/gd2-lib/GD2.h:271:7: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::cmd17(uint32_t)':
.pio/libdeps/debug/gd2-lib/GD2.h:391:12: error: 'SPI' was not declared in this scope
while (SPI.transfer(0xff) != 0xfe)
.pio/libdeps/debug/gd2-lib/GD2.h:391:12: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void sdcard::rdn(byte*, uint32_t, uint16_t)':
.pio/libdeps/debug/gd2-lib/GD2.h:399:7: error: 'SPI' was not declared in this scope
SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:399:7: note: suggested alternative: 'ASPI'
SPI.transfer(0xff);
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h:401:14: error: 'SPI' was not declared in this scope
*d++ = SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:401:14: note: suggested alternative: 'ASPI'
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h:403:7: error: 'SPI' was not declared in this scope
SPI.transfer(0xff);
.pio/libdeps/debug/gd2-lib/GD2.h:403:7: note: suggested alternative: 'ASPI'
SPI.transfer(0xff);
ASPI
.pio/libdeps/debug/gd2-lib/GD2.h: In member function 'void Reader::fetch512(byte*)':
.pio/libdeps/debug/gd2-lib/GD2.h:804:29: error: 'SPI' was not declared in this scope
memset(dst, 0xff, 512); SPI.transfer(dst, 512);
.pio/libdeps/debug/gd2-lib/GD2.h:804:29: note: suggested alternative: 'ASPI'
ASPI
/Users/$$$/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp: In member function 'void BingUIClass::_options()':
/Users/$$$/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp:778:30: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'int' [-Wformat=]
value);
BingUI is another library that uses GD2, but it is imported after BingMachine (The one where i changed the order of includes)
maxgerhardt:
This library I manually install my fork from Git because i need to make manual changes to it. Does it matter for this issue?
I don’t think so, since the fault originates from the GD2 library.
Then apparenlty, from what i read in the last error i sent, it is looking for ASPI object.
My bad, indeed there are still references to SPI
that I haven’t seen… Will do a better fix.
Could you please again delete the .pio
and rebuild, I’ve made a few more changes.
I’ll put the full output just in case
Processing debug (platform: atmelsam; board: duelow; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/duelow.html
PLATFORM: Atmel SAM (7.1.0) > Arduino Due (Low Bootloader)
LDF Modes: Finder ~ deep, Compatibility ~ soft
Found 22 compatible libraries
|-- Adafruit DRV2605 Library @ 1.2.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- SPI @ 1.0
| | | |-- Wire @ 1.0
| | | |-- SPI @ 1.0
| | |-- SPI @ 1.0
| | |-- Wire @ 1.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- gd2-lib @ 1.3.4+sha.8440ff6
| |-- SPI @ 1.0
|-- BingMachine
| |-- SdFat @ 1.1.0
| | |-- SPI @ 1.0
| |-- ArduinoMD5
| |-- DueFlashStorage @ 1.0.0
| | | |-- Wire @ 1.0
| | | |-- SPI @ 1.0
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| | | | |-- Wire @ 1.0
| | | | |-- SPI @ 1.0
| | | |-- SPI @ 1.0
| | | |-- Wire @ 1.0
| | | |-- Wire @ 1.0
| | | |-- SPI @ 1.0
| | | |-- Wire @ 1.0
| | | |-- SPI @ 1.0
| | |-- SPI @ 1.0
| | |-- Wire @ 1.0
| |-- BingUI @ 0.2
| | | |-- SPI @ 1.0
| |-- AudioI2S @ 1.0.1
| | |-- SdFat @ 1.1.0
| | | |-- SPI @ 1.0
| | |-- SPI @ 1.0
|-- BingUI @ 0.2
| | |-- SPI @ 1.0
Compiling .pio/build/debug/src/main.cpp.o
Compiling .pio/build/debug/libdff/Wire/Wire.cpp.o
Compiling .pio/build/debug/lib01f/SPI/SPI.cpp.o
Compiling .pio/build/debug/lib839/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
Compiling .pio/build/debug/lib839/Adafruit BusIO/Adafruit_I2CDevice.cpp.o
Compiling .pio/build/debug/lib839/Adafruit BusIO/Adafruit_SPIDevice.cpp.o
Compiling .pio/build/debug/libfc2/Adafruit DRV2605 Library/Adafruit_DRV2605.cpp.o
Compiling .pio/build/debug/lib41d/Adafruit GFX Library/Adafruit_GFX.cpp.o
In file included from src/main.cpp:3:0:
/Users/ivanmindlin/Repos/Bing-Project/libs/BingMachine/src/debug.h:5:2: warning: #warning "Using DEBUG features" [-Wcpp]
In file included from /Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.cpp:25:0:
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.h: In constructor 'TwoWire::TwoWire(Twi*, void (*)(), void (*)())':
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.h:96:7: warning: 'TwoWire::twi' will be initialized after [-Wreorder]
Twi *twi;
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.h:72:10: warning: 'uint8_t TwoWire::rxBufferIndex' [-Wreorder]
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.cpp:95:1: warning: when initialized here [-Wreorder]
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.h:108:16: warning: 'TwoWire::status' will be initialized after [-Wreorder]
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/libraries/Wire/src/Wire.h:90:30: warning: 'void (* TwoWire::onBeginCallback)()' [-Wreorder]
.pio/libdeps/debug/Adafruit DRV2605 Library/Adafruit_DRV2605.cpp: In member function 'boolean Adafruit_DRV2605::init()':
.pio/libdeps/debug/Adafruit DRV2605 Library/Adafruit_DRV2605.cpp:76:11: warning: unused variable 'id' [-Wunused-variable]
uint8_t id = readRegister8(DRV2605_REG_STATUS);
src/main.cpp:14:48: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
char * lang_folders[N_LANGS] = {"eng/", "spa/"};
src/main.cpp:15:61: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
char * type_folders[N_TYPES] = {"word/", "phrase/", "sent/"};
Archiving .pio/build/debug/libfc2/libAdafruit DRV2605 Library.a
Indexing .pio/build/debug/libfc2/libAdafruit DRV2605 Library.a
Compiling .pio/build/debug/lib41d/Adafruit GFX Library/Adafruit_GrayOLED.cpp.o
Compiling .pio/build/debug/lib41d/Adafruit GFX Library/Adafruit_SPITFT.cpp.o
Compiling .pio/build/debug/lib41d/Adafruit GFX Library/glcdfont.c.o
Archiving .pio/build/debug/lib01f/libSPI.a
Archiving .pio/build/debug/libdff/libWire.a
Indexing .pio/build/debug/lib01f/libSPI.a
Indexing .pio/build/debug/libdff/libWire.a
Archiving .pio/build/debug/lib839/libAdafruit BusIO.a
Indexing .pio/build/debug/lib839/libAdafruit BusIO.a
Compiling .pio/build/debug/libf7a/Adafruit LED Backpack Library/Adafruit_LEDBackpack.cpp.o
Compiling .pio/build/debug/lib891/gd2-lib/GD2.cpp.o
Compiling .pio/build/debug/lib891/gd2-lib/GD2Terminal.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FatFile.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FatFileLFN.cpp.o
In file included from .pio/libdeps/debug/gd2-lib/GD2.cpp:40:0:
.pio/libdeps/debug/gd2-lib/transports/wiring.h: In member function 'void GDTransport::begin1()':
.pio/libdeps/debug/gd2-lib/transports/wiring.h:119:14: warning: unused variable 'x' [-Wunused-variable]
uint16_t x = __rd16(0x0c0000UL);
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FatFilePrint.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FatFileSFN.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FatVolume.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/FmtNumber.cpp.o
Archiving .pio/build/debug/lib41d/libAdafruit GFX Library.a
Archiving .pio/build/debug/libf7a/libAdafruit LED Backpack Library.a
Indexing .pio/build/debug/lib41d/libAdafruit GFX Library.a
Indexing .pio/build/debug/libf7a/libAdafruit LED Backpack Library.a
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/StdioStream.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/fstream.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/istream.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/FatLib/ostream.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/MinimumSerial.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SdCard/SdSpiCard.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SdCard/SdSpiCardEX.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SdCard/SdioCardEX.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SdCard/SdioTeensy.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SpiDriver/SdSpiESP8266.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SpiDriver/SdSpiParticle.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SpiDriver/SdSpiSAM3X.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SpiDriver/SdSpiSTM32.cpp.o
Compiling .pio/build/debug/libe22/SdFatEx/SpiDriver/SdSpiTeensy3.cpp.o
Compiling .pio/build/debug/libf0d/ArduinoMD5/MD5.cpp.o
Compiling .pio/build/debug/libea1/DueFlashStorage/DueFlashStorage.cpp.o
Compiling .pio/build/debug/libea1/DueFlashStorage/efc.cpp.o
Compiling .pio/build/debug/libea1/DueFlashStorage/flash_efc.cpp.o
/Users/ivanmindlin/Repos/Bing-Project/external/DueFlashStorage/src/DueFlashStorage.cpp: In member function 'boolean DueFlashStorage::write(uint32_t, byte*, uint32_t, uint8_t)':
/Users/ivanmindlin/Repos/Bing-Project/external/DueFlashStorage/src/DueFlashStorage.cpp:63:19: warning: suggest parentheses around '+' in operand of '&' [-Wparentheses]
if ((flash_start+offset & 3) != 0) {
Compiling .pio/build/debug/lib759/BingUI/BingUI.cpp.o
/Users/ivanmindlin/Repos/Bing-Project/external/DueFlashStorage/src/flash_efc.cpp: In function 'uint32_t flash_is_locked(uint32_t, uint32_t)':
/Users/ivanmindlin/Repos/Bing-Project/external/DueFlashStorage/src/flash_efc.cpp:669:11: warning: variable 'ul_error' set but not used [-Wunused-but-set-variable]
uint32_t ul_error;
Compiling .pio/build/debug/lib759/BingUI/BingUIClass.cpp.o
Compiling .pio/build/debug/liba1e/Audio/AudioI2S.cpp.o
Archiving .pio/build/debug/libe22/libSdFatEx.a
In file included from /Users/ivanmindlin/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp:5:0:
/Users/ivanmindlin/Repos/Bing-Project/libs/BingUI/src/debug.h:5:2: warning: #warning "Using DEBUG features" [-Wcpp]
Indexing .pio/build/debug/libe22/libSdFatEx.a
Compiling .pio/build/debug/liba1e/Audio/DAC.cpp.o
Compiling .pio/build/debug/libb9b/BingMachine/BingMachine.cpp.o
/Users/ivanmindlin/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp: In member function 'void BingUIClass::_options()':
/Users/ivanmindlin/Repos/Bing-Project/libs/BingUI/src/BingUIClass.cpp:778:30: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'int' [-Wformat=]
value);
Archiving .pio/build/debug/lib891/libgd2-lib.a
Compiling .pio/build/debug/libb9b/BingMachine/BingMachineClass.cpp.o
Indexing .pio/build/debug/lib891/libgd2-lib.a
Compiling .pio/build/debug/libb9b/BingMachine/RandPerm.cpp.o
Archiving .pio/build/debug/libea1/libDueFlashStorage.a
Archiving .pio/build/debug/libf0d/libArduinoMD5.a
Indexing .pio/build/debug/libea1/libDueFlashStorage.a
Indexing .pio/build/debug/libf0d/libArduinoMD5.a
Compiling .pio/build/debug/libb9b/BingMachine/v3/BingMachineV3.cpp.o
Compiling .pio/build/debug/libb9b/BingMachine/v3/error.cpp.o
Compiling .pio/build/debug/FrameworkArduinoVariant/variant.cpp.o
Compiling .pio/build/debug/FrameworkArduino/IPAddress.cpp.o
In file included from /Users/ivanmindlin/Repos/Bing-Project/libs/BingMachine/src/v3/BingMachineV3.cpp:6:0:
/Users/ivanmindlin/Repos/Bing-Project/libs/BingMachine/src/v3/../debug.h:5:2: warning: #warning "Using DEBUG features" [-Wcpp]
Compiling .pio/build/debug/FrameworkArduino/Print.cpp.o
Compiling .pio/build/debug/FrameworkArduino/Reset.cpp.o
Archiving .pio/build/debug/liba1e/libAudio.a
Indexing .pio/build/debug/liba1e/libAudio.a
/Users/ivanmindlin/Repos/Bing-Project/libs/BingMachine/src/v3/BingMachineV3.cpp: In function 'void reboot_to_flash1()':
/Users/ivanmindlin/Repos/Bing-Project/libs/BingMachine/src/v3/BingMachineV3.cpp:269:12: warning: unused variable 'EEFC_FCMD_CGPB' [-Wunused-variable]
const int EEFC_FCMD_CGPB = 0x0C;
Compiling .pio/build/debug/FrameworkArduino/RingBuffer.cpp.o
Compiling .pio/build/debug/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/debug/FrameworkArduino/UARTClass.cpp.o
Compiling .pio/build/debug/FrameworkArduino/USARTClass.cpp.o
Archiving .pio/build/debug/libFrameworkArduinoVariant.a
Indexing .pio/build/debug/libFrameworkArduinoVariant.a
Compiling .pio/build/debug/FrameworkArduino/USB/CDC.cpp.o
Compiling .pio/build/debug/FrameworkArduino/USB/PluggableUSB.cpp.o
Archiving .pio/build/debug/lib759/libBingUI.a
Compiling .pio/build/debug/FrameworkArduino/USB/USBCore.cpp.o
Indexing .pio/build/debug/lib759/libBingUI.a
Compiling .pio/build/debug/FrameworkArduino/WInterrupts.c.o
Compiling .pio/build/debug/FrameworkArduino/WMath.cpp.o
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/cores/arduino/USB/USBCore.cpp: In function 'void USB_ISR()':
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/cores/arduino/USB/USBCore.cpp:688:21: warning: this 'else' clause does not guard... [-Wmisleading-indentation]
else
/Users/ivanmindlin/.platformio/packages/framework-arduino-sam/cores/arduino/USB/USBCore.cpp:690:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'else'
UDD_Send8(EP0, 0);
Compiling .pio/build/debug/FrameworkArduino/WString.cpp.o
Compiling .pio/build/debug/FrameworkArduino/abi.cpp.o
Compiling .pio/build/debug/FrameworkArduino/avr/dtostrf.c.o
Archiving .pio/build/debug/libb9b/libBingMachine.a
Compiling .pio/build/debug/FrameworkArduino/cortex_handlers.c.o
Compiling .pio/build/debug/FrameworkArduino/hooks.c.o
Compiling .pio/build/debug/FrameworkArduino/iar_calls_sam3.c.o
Indexing .pio/build/debug/libb9b/libBingMachine.a
Compiling .pio/build/debug/FrameworkArduino/itoa.c.o
Compiling .pio/build/debug/FrameworkArduino/main.cpp.o
Compiling .pio/build/debug/FrameworkArduino/new.cpp.o
Compiling .pio/build/debug/FrameworkArduino/syscalls_sam3.c.o
Compiling .pio/build/debug/FrameworkArduino/watchdog.cpp.o
Compiling .pio/build/debug/FrameworkArduino/wiring.c.o
Compiling .pio/build/debug/FrameworkArduino/wiring_analog.c.o
Compiling .pio/build/debug/FrameworkArduino/wiring_digital.c.o
Compiling .pio/build/debug/FrameworkArduino/wiring_pulse.cpp.o
Compiling .pio/build/debug/FrameworkArduino/wiring_pulse_asm.S.o
Compiling .pio/build/debug/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/debug/libFrameworkArduino.a
Indexing .pio/build/debug/libFrameworkArduino.a
Linking .pio/build/debug/firmware.elf
.pio/build/debug/lib759/libBingUI.a(BingUIClass.cpp.o):(.bss.ASPI+0x0): multiple definition of `ASPI'
.pio/build/debug/src/main.cpp.o:(.bss.ASPI+0x0): first defined here
.pio/build/debug/libb9b/libBingMachine.a(BingMachine.cpp.o):(.bss.ASPI+0x0): multiple definition of `ASPI'
.pio/build/debug/libb9b/libBingMachine.a(BingMachineV3.cpp.o):(.bss.ASPI+0x0): multiple definition of `ASPI'
.pio/build/debug/lib891/libgd2-lib.a(GD2.cpp.o):(.bss.ASPI+0x0): multiple definition of `ASPI'
*** [.pio/build/debug/firmware.elf] Error 1
======================================================== [FAILED] Took 5.50 seconds ========================================================
Environment Status Duration
debug FAILED 00:00:05.495
================================================== 1 failed, 0 succeeded in 00:00:05.495 ==================================================
The terminal process "platformio 'run', '--environment', 'debug'" terminated with exit code: 1.
My bad, I made yet another mistake which I need to fix xD
Now it should actually work. Please remove the .pio
folder again and rebuild.
No problem! You are absolutely saving my life
It worked!!
First, thanks a lot. Why did this error occur? What changed?
Second, to what annonymus location can i send i gift to thank all the help?
