Hi, I couldn’t find an answer to my specific problem and I don’t know if the problem is with PlatformIO or not. If it is not, I am hoping someone could send me to the correct place to ask the question.
First, some details about the environment. I am using Arch Linux x64 with the udev rules installed, and my user is added to the group which has access to the serial port (I don’t know if this is important). I am using PlatformIO 3.1.0.
I tried uploading to the Adafruit HUZZAH which is a breakout board for the ESP8266. I bought a FDTI cable which works when connecting to its virual terminal either via picocom or screen. I can even program it via lua by issuing commands on the terminal, but I cannot get PlatformIO to upload a compiled program to the device. I tried the platform init
command with the following board types: huzzah
, nodemcu
, and esp12e
and the same problem occurs when the following command is run pio run -v -t upload
[Thu Sep 22 20:51:00 2016] Processing huzzah (platform: espressif8266, board: huzzah, framework: arduino)
MethodWrapper(["upload"], [".pioenvs/huzzah/firmware.bin"])
Warning! Please install `99-platformio-udev.rules` and check that your board's PID and VID are listed in the rules.
https://raw.githubusercontent.com/platformio/platformio/develop/scripts/99-platformio-udev.rules
Auto-detected: /dev/ttyUSB0
esptool -vv -cd nodemcu -cb 115200 -cp "/dev/ttyUSB0" -cf .pioenvs/huzzah/firmware.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from /dev/ttyUSB0 to /dev/ttyUSB0
espcomm_upload_file
espcomm_upload_mem
opening port /dev/ttyUSB0 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
serialport_receive_C0: 00 instead of C0
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
warning: espcomm_sync failed
error: espcomm_open failed
:*** [upload] Error 255
=============================================== [ERROR] Took 3.53 seconds ===============================================
If there is any more information I could provide to help in figuring out this problem, I would be glad to provide it.
