First time using PlatformIO so it could be a user error, but the symptom is that the same code works as expected when compiled/uploaded through the Arduino IDE, but bluetooth communication from the nrf52832 to a phone doesn’t work when compiled/uploaded via PlatformIO.
I can establish a bluetooth connection, and transmit data from the connected device to the nrf52832. The console log of the nrf52832 shows it received the information from the phone and no errors are shown…just no data is sent back to the phone.
The only difference between the code is the inclusion of #include “Arduino.h” in main.cpp.
I’m not sure what to validate/compare next. Any tips on how to discover what’s different between the two build pipelines? I can post the code or verbose build output, or whatever else would be useful to help debug. Thanks. Here’s the build output to start with:
> pio run --target upload -e adafruit_feather_nrf52832
Processing adafruit_feather_nrf52832 (platform: nordicnrf52; board: adafruit_feather_nrf52832; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/adafruit_feather_nrf52832.html
PLATFORM: Nordic nRF52 (4.5.0) > Adafruit Bluefruit nRF52832 Feather
HARDWARE: NRF52832 64MHz, 64KB RAM, 512KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-arduinoadafruitnrf52 1.2100.201028 (21.0)
- tool-bossac-nordicnrf52 1.10901.201022 (1.9.1)
- tool-openocd 2.1000.200630 (10.0)
- tool-sreccat 1.164.0 (1.64)
Found 14 compatible libraries
|-- <Adafruit Little File System Libraries> 0.11.0
|-- <Adafruit Internal File System on Bluefruit nRF52> 0.11.0
|-- <Adafruit Bluefruit nRF52 Libraries> 0.21.0
Checking size .pio/build/adafruit_feather_nrf52832/firmware.elf
RAM: [= ] 13.9% (used 9100 bytes from 65536 bytes)
Flash: [= ] 13.7% (used 71628 bytes from 524288 bytes)
AVAILABLE: blackmagic, cmsis-dap, jlink, nrfjprog, nrfutil, stlink
CURRENT: upload_protocol = nrfutil
Looking for upload port...
Auto-detected: /dev/cu.usbserial-01E02A38
Uploading .pio/build/adafruit_feather_nrf52832/firmware.zip
Upgrading target on /dev/cu.usbserial-01E02A38 with DFU package /Users/dan/code/cyclometry/arduino/nrf52_hall/.pio/build/adafruit_feather_nrf52832/firmware.zip. Flow control is disabled, Single bank, Touch disabled
Activating new firmware
Device programmed.
===================================================== [SUCCESS] Took 16.31 seconds =====================================================
I pushed a branch up to github. I have two top-level directories - nrf52_hall is the platformio project, and nrf52_with_hall has the Arduino file used.
Derp - just used a different UART iOS client, and it’s receiving ok. i.e. PlatformIO’s build behavior is fine; my iOS client is faulty for a TBD reason.
