I seem to always have issues from the second time of programming my ESP32 onwards. This first time I click the PlatformIO:Upload button in VSCODE it programs the device without problems but if I change and recompile the code and hit the button again I invariably get this error:
Linking .pio\build\view\firmware.elf
Retrieving maximum program size .pio\build\view\firmware.elf
Checking size .pio\build\view\firmware.elf
RAM: [= ] 5.2% (used 16960 bytes from 327680 bytes)
Flash: [=== ] 26.4% (used 345818 bytes from 1310720 bytes)
Building .pio\build\view\firmware.bin
esptool.py v3.1
Merged 1 ELF section
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM3
Uploading .pio\build\view\firmware.bin
esptool.py v3.1
Serial port COM3
File "C:\Users\mail\.platformio\packages\tool-esptoolpy@1.30100.210531\esptool.py", line 4582, in <module>
_main()
File "C:\Users\mail\.platformio\packages\tool-esptoolpy@1.30100.210531\esptool.py", line 4575, in _main
main()
File "C:\Users\mail\.platformio\packages\tool-esptoolpy@1.30100.210531\esptool.py", line 4074, in main
esp = esp or get_default_connected_device(ser_list, port=args.port, connect_attempts=args.connect_attempts,
File "C:\Users\mail\.platformio\packages\tool-esptoolpy@1.30100.210531\esptool.py", line 120, in get_default_connected_device
_esp = chip_class(each_port, initial_baud, trace)
File "C:\Users\mail\.platformio\packages\tool-esptoolpy@1.30100.210531\esptool.py", line 313, in __init__
self._port = serial.serial_for_url(port)
File "C:\Users\mail\.platformio\penv\lib\site-packages\serial\__init__.py", line 90, in serial_for_url
instance.open()
File "C:\Users\mail\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 64, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)
*** [upload] Error 1
========================================================================================= [FAILED] Took 9.38 seconds =========================================================================================
Environment Status Duration
view FAILED 00:00:09.384
If I keep clicking the Upload button it will eventually work.
Any thoughts on what might be happening?
Andy
