nkuck
July 18, 2019, 8:30pm
#1
The env below doesn’t want to upload to my A10M printer. Do I have an error in the definition?
ATmega2560
[env:megaatmega2560]
board = megaatmega2560
build_flags = ${common.build_flags}
board_build.f_cpu = 16000000L
lib_deps = ${common.lib_deps}
src_filter = ${common.default_src_filter} +<src/HAL/HAL_AVR>
monitor_speed = 250000
nkuck
July 18, 2019, 8:58pm
#3
Error: Unknown environment names ‘megaatmega2560’. Valid names are ‘rambo, DUE_debug, STM32F4, fysetc_f6_13, LPC1768, teensy35, melzi_optiboot, at90usb1286_dfu, sanguino_atmega1284p, megaatmega1280, DUE_USB, JGAURORA_A5S_A1, mks_robin_nano, BIGTREE_SKR_MINI, LPC1769, black_stm32f407ve, at90usb1286_cdc, mks_robin, ARMED, atmega2560, melzi, linux_native, STM32F7, BIGTREE_SKR_PRO, malyanm200, esp32, mks_robin_mini, STM32F1, DUE, sanguino_atmega644p, fysetc_STM32F1’
Looks like there is a syntactical error in the platformio.ini. Can you post it fully here and enclose it in tripple back-apostrophes so that it formats correcty (ref )
nkuck
July 18, 2019, 9:51pm
#5
Here it is. Thanks for any assistance.
# Marlin Firmware
# PlatformIO Configuration File
# For detailed documentation with EXAMPLES:
# http://docs.platformio.org/en/latest/projectconf.html
# Automatic targets - enable auto-uploading
# targets = upload
# By default platformio build will abort after 5 errors.
# Remove '-fmax-errors=5' from build_flags below to see all.
[platformio]
src_dir = Marlin
build_dir = .pioenvs
lib_dir = .piolib
libdeps_dir = .piolibdeps
boards_dir = buildroot/share/PlatformIO/boards
env_default = megaatmega2560
[common]
default_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
build_flags = -fmax-errors=5
-g
-ggdb
https://github.com/MarlinFirmware/U8glib-HAL/archive/dev.zip
LiquidCrystal@1.3.4
TMCStepper@<1.0.0
Adafruit NeoPixel@1.1.3
https://github.com/lincomatic/LiquidTWI2/archive/30aa480.zip
https://github.com/ameyer/Arduino-L6470/archive/dev.zip
https://github.com/trinamic/TMC26XStepper/archive/c1921b4.zip
https://github.com/mikeshub/SailfishLCD.git
https://github.com/mikeshub/SailfishRGB_LED.git
https://github.com/mikeshub/SlowSoftI2CMaster.git
# Unique Core Architectures #
# Add a new "env" below if no #
# entry has values suitable to #
# build for a given board. #
# ATmega2560
# ATmega1280
[env:megaatmega1280]
board = megaatmega1280
# AT90USB1286 boards using CDC bootloader
# - BRAINWAVE
# - BRAINWAVE_PRO
# - SAV_MKI
# - TEENSYLU
[env:at90usb1286_cdc]
platform = teensy
board = at90usb1286
extra_scripts = pre:buildroot/share/atom/create_custom_upload_command_CDC.py
# AT90USB1286 boards using DFU bootloader
# - PrintrBoard
# - PrintrBoard Rev.F
# - ? 5DPRINT ?
[env:at90usb1286_dfu]
platform = teensy
board = at90usb1286
extra_scripts = pre:buildroot/share/atom/create_custom_upload_command_DFU.py
# Due (Atmel SAM3X8E ARM Cortex-M3)
# - RAMPS4DUE
# - RADDS
[env:DUE]
platform = atmelsam
board = due
lib_ignore = c1921b4
src_filter = ${common.default_src_filter} +<src/HAL/HAL_DUE>
[env:DUE_USB]
platform = atmelsam
board = dueUSB
[env:DUE_debug]
# Used when WATCHDOG_RESET_MANUAL is enabled
platform = atmelsam
board = due
-funwind-tables
-mpoke-function-name
# NXP LPC176x ARM Cortex-M3
[env:LPC1768]
platform = https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/master.zip
board = nxp_lpc1768
build_flags = -DTARGET_LPC1768 -DU8G_HAL_LINKS -IMarlin/src/HAL/HAL_LPC1768/include -IMarlin/src/HAL/HAL_LPC1768/u8g ${common.build_flags}
# debug options for backtrace
# -funwind-tables
# -mpoke-function-name
lib_ldf_mode = off
lib_compat_mode = strict
extra_scripts = Marlin/src/HAL/HAL_LPC1768/upload_extra_script.py
src_filter = ${common.default_src_filter} +<src/HAL/HAL_LPC1768>
lib_deps = Servo
LiquidCrystal
U8glib-HAL=https://github.com/MarlinFirmware/U8glib-HAL/archive/dev.zip
TMCStepper@<1.0.0
Adafruit NeoPixel=https://github.com/p3p/Adafruit_NeoPixel/archive/master.zip
[env:LPC1769]
board = nxp_lpc1769
build_flags = -DTARGET_LPC1768 -DLPC1769 -DU8G_HAL_LINKS -IMarlin/src/HAL/HAL_LPC1768/include -IMarlin/src/HAL/HAL_LPC1768/u8g ${common.build_flags}
# -funwind-tables
lib_ldf_mode = off
lib_deps = Servo
LiquidCrystal
TMCStepper@<1.0.0
# Melzi and clones (ATmega1284p)
[env:melzi]
board = sanguino_atmega1284p
upload_speed = 57600
lib_ignore = TMCStepper, TMC26XStepper
# Melzi and clones (Optiboot bootloader)
[env:melzi_optiboot]
upload_speed = 115200
# RAMBo
[env:rambo]
board = reprap_rambo
# Sanguinololu (ATmega644p)
[env:sanguino_atmega644p]
board = sanguino_atmega644p
# Sanguinololu (ATmega1284p)
[env:sanguino_atmega1284p]
# STM32F103RE
[env:STM32F1]
platform = ststm32
board = genericSTM32F103RE
build_flags = !python Marlin/src/HAL/HAL_STM32F1/STM32F1_flag_script.py
${common.build_flags} -std=gnu++14
build_unflags = -std=gnu++11
lib_ignore = U8glib-HAL
c1921b4
libf3c
lib066
Adafruit NeoPixel_ID28
Adafruit NeoPixel
libf3e
TMC26XStepper
#lib_ldf_mode = 1
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32F1>
# fysetc_STM32F1
[env:fysetc_STM32F1]
platform = ststm32
board = genericSTM32F103RC
#board_build.core = maple
extra_scripts = buildroot/share/PlatformIO/scripts/fysetc_STM32F1.py
lib_ignore =
c1921b4
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
lib_ldf_mode = 1
debug_tool = stlink
upload_protocol = serial
# BIGTREE_SKR_MINI
[env:BIGTREE_SKR_MINI]
platform = ststm32
extra_scripts = buildroot/share/PlatformIO/scripts/STM32F1_SKR_MINI.py
lib_ignore =
c1921b4
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
#lib_ldf_mode = 1
upload_protocol = stlink
debug_tool = stlink
# STM32F4 with STM32GENERIC
[env:STM32F4]
platform = ststm32
board = disco_f407vg
build_flags = ${common.build_flags} -DUSE_STM32GENERIC -DSTM32GENERIC -DMENU_USB_SERIAL -DMENU_SERIAL=SerialUSB
lib_ignore = Adafruit NeoPixel, c1921b4, TMCStepper
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32_F4_F7> -<src/HAL/HAL_STM32_F4_F7/*> +<src/HAL/HAL_STM32_F4_F7/STM32F4>
# STM32F7 with STM32GENERIC
[env:STM32F7]
platform = ststm32
board = disco_f765vg
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32_F4_F7> -<src/HAL/HAL_STM32_F4_F7/*> +<src/HAL/HAL_STM32_F4_F7/STM32F7>
# ARMED (STM32)
[env:ARMED]
platform = ststm32
board = armed_v1
build_flags = ${common.build_flags} -DUSBCON -DUSBD_VID=0x0483 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="ARMED_V1"' -DHAL_PCD_MODULE_ENABLED -DUSBD_USE_CDC -O2 -ffreestanding -fsigned-char -fno-move-loop-invariants -fno-strict-aliasing -std=gnu11 -std=gnu++11
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32>
# MKS Robin (STM32F103ZET6)
[env:mks_robin]
platform = ststm32
board = genericSTM32F103ZE
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin.py
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
U8glib-HAL
# MKS Robin Mini (STM32F103VET6)
[env:mks_robin_mini]
platform = ststm32
board = genericSTM32F103VE
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin_mini.py
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
# MKS Robin Nano (STM32F103VET6)
[env:mks_robin_nano]
platform = ststm32
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin_nano.py
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
# JGAurora A5S A1 (STM32F103ZET6)
[env:JGAURORA_A5S_A1]
platform = ststm32@5.3.0
extra_scripts = buildroot/share/PlatformIO/scripts/jgaurora_a5s_a1_with_bootloader.py
libf3c
lib066
Adafruit NeoPixel
libf3e
TMC26XStepper
lib_ldf_mode = 1
# STM32F407VET6 with RAMPS-like shield
# 'Black' STM32F407VET6 board - http://wiki.stm32duino.com/index.php?title=STM32F407
# Shield - https://github.com/jmz52/Hardware
[env:black_stm32f407ve]
platform = ststm32
board = blackSTM32F407VET6
extra_scripts = pre:buildroot/share/PlatformIO/scripts/black_stm32f407vet6.py
-DUSBCON -DUSBD_USE_CDC -DUSBD_VID=0x0483 -DUSB_PRODUCT=\"BLACK_F407VE\"
lib_ignore = Adafruit NeoPixel, c1921b4, TMCStepper, TMC26XStepper, SailfishLCD, SailfishRGB_LED, SlowSoftI2CMaster
# BIGTREE_SKR_PRO (STM32F407ZGT6 ARM Cortex-M4)
[env:BIGTREE_SKR_PRO]
platform = ststm32
board = BigTree_SKR_Pro
extra_scripts = pre:buildroot/share/PlatformIO/scripts/generic_create_variant.py
-DUSBCON -DUSBD_USE_CDC -DUSBD_VID=0x0483 -DUSB_PRODUCT=\"STM32F407ZG\"
-DTARGET_STM32F4 -DSTM32F407_5ZX -DVECT_TAB_OFFSET=0x8000
lib_ignore = Adafruit NeoPixel, c1921b4, TMC26XStepper, SailfishLCD, SailfishRGB_LED, SlowSoftI2CMaster
upload_protocol = cmsis-dap
# Teensy 3.5 / 3.6 (ARM Cortex-M4)
[env:teensy35]
platform = teensy
board = teensy35
src_filter = ${common.default_src_filter} +<src/HAL/HAL_TEENSY35_36>
# Malyan M200 (STM32F1)
[env:malyanm200]
platform = ststm32
board = malyanM200
build_flags = !python Marlin/src/HAL/HAL_STM32F1/STM32F1_flag_script.py -DMCU_STM32F103CB -D __STM32F1__=1 -std=c++1y -D MOTHERBOARD="BOARD_MALYAN_M200" -DSERIAL_USB -ffunction-sections -fdata-sections -Wl,--gc-sections
#-<frameworks>
lib_ignore =
U8glib
LiquidCrystal_I2C
LiquidCrystal
NewliquidCrystal
LiquidTWI2
Adafruit NeoPixel
TMCStepper
Servo(STM32F1)
TMC26XStepper
U8glib-HAL
c1921b4
# Espressif ESP32
[env:esp32]
upload_port = /dev/ttyUSB0
https://github.com/me-no-dev/AsyncTCP.git
https://github.com/me-no-dev/ESPAsyncWebServer.git
lib_ignore =
LiquidCrystal_I2C
LiquidCrystal
NewliquidCrystal
LiquidTWI2
TMC26XStepper
c1921b4
SailfishLCD
SailfishRGB_LED
src_filter = ${common.default_src_filter} +<src/HAL/HAL_ESP32>
# FYSETC F6 V1.3
[env:fysetc_f6_13]
board = fysetc_f6_13
# Native
# No supported Arduino libraries, base Marlin only
[env:linux_native]
platform = native
build_flags = -D__PLAT_LINUX__ -std=gnu++17 -ggdb -g -lrt -lpthread
src_build_flags = -Wall -IMarlin/src/HAL/HAL_LINUX/include
build_unflags = -Wall
lib_ldf_mode = off
extra_scripts =
src_filter = ${common.default_src_filter} +<src/HAL/HAL_LINUX>
nkuck
July 19, 2019, 9:34pm
#7
I got it going, magically? Had to do an upload_port to the wchusbserial port to make it work. Not sure of the PIO version but running MAC OSX Mojave. Thanks for helping.
