Yes, I do. But rarely i work in more than one at once.
Is it suitable for handling more than one MCU within the same project?
I just took one of them and flashed one of those small programs in it, using VSCode in Windows: SUCCESS
------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (6.6.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
- tool-mkfatfs @ 2.0.1
- tool-openocd-esp32 @ 2.1100.20220706 (11.0)
Found 36 compatible libraries
|-- TFT_eSPI @ 2.5.41
|-- Hardware
|-- Wire @ 2.0.0
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 6.7% (used 21836 bytes from 327680 bytes)
Flash: [== ] 22.8% (used 298777 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Using manually specified: COM6
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v4.5.1
Serial port COM6
Connecting.....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e4:65:b8:e7:7e:a0
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00059fff...
Compressed 17536 bytes to 12202...
Writing at 0x00001000... (100 %)
Wrote 17536 bytes (12202 compressed) at 0x00001000 in 6.7 seconds (effective 21.0 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.2 seconds (effective 116.4 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.2 seconds (effective 434.2 kbit/s)...
Compressed 299136 bytes to 163909...
Writing at 0x00010000... (9 %)
Writing at 0x0001b01c... (18 %)
Writing at 0x000281d7... (27 %)
Writing at 0x0002d6e2... (36 %)
Writing at 0x00032d13... (45 %)
Writing at 0x00038039... (54 %)
Writing at 0x0003d6e7... (63 %)
Writing at 0x00042e62... (72 %)
Writing at 0x00048b02... (81 %)
Writing at 0x000527e1... (90 %)
Writing at 0x0005902e... (100 %)
Wrote 299136 bytes (163909 compressed) at 0x00010000 in 86.8 seconds (effective 27.6 kbit/s)...
Leaving...
Hard resetting via RTS pin...
=================================== [SUCCESS] Took 119.06 seconds ===================================
Then I’ve tried that first module again. For my surprise: SUCCESS again:
Building .pio\build\esp32dev\firmware.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 2 ELF sections
Using manually specified: COM4
esptool.py v4.5.1
Serial port COM4
Connecting............
Chip is ESP32-D0WDQ6 (revision v1.0)
Crystal is 40MHz
MAC: 24:62:ab:dc:a9:38
Uploading stub...
Running stub...
Stub running...
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.2 seconds (effective 113.2 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.2 seconds (effective 368.5 kbit/s)...
Wrote 299136 bytes (163909 compressed) at 0x00010000 in 87.0 seconds (effective 27.5 kbit/s)...
Leaving...
=================================== [SUCCESS] Took 216.23 seconds ===================================
I’m surprised. I hope it’s not an intermittent error!
Yes, that is also possible, but a completely different topic ![]()
This leaves only the inexplicable phenomenon of why the upload worked under Windows. But we certainly won’t find out.
Just in case anyone else comes across this, I just fixed this issue by compiling and flashing a simply hello world program using esp-idf and then came back to Platform.io and everything worked fine.
It seems that something got corrupted/broken in the process of compiling/flashing on Platform.io and esp-idf overwrote the right things again to get us back into a stable state.
