Thanks a lot.
After clicking the “Verbose Upload”, the output is:
Executing task: C:\Users\wgt04\.platformio\penv\Scripts\platformio.exe run --verbose --target upload
Processing firebeetle32 (platform: espressif32; board: firebeetle32; framework:
arduino; upload_protocol: ch347; debug_tool: ch347)
--------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/firebeetle32.html
PLATFORM: Espressif 32 (5.0.0) > FireBeetle-ESP32
DEBUG: Current (ch347) External (ch347, cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
- tool-mkfatfs @ 2.0.1
- tool-openocd-esp32 @ 2.1100.20220411 (11.0)
Found 32 compatible libraries
<lambda>(["checkprogsize"], [".pio\build\firebeetle32\firmware.elf"])
MethodWrapper(["checkprogsize"], [".pio\build\firebeetle32\firmware.elf"])
RAM: [ ] 4.9% (used 16148 bytes from 327680 bytes)
Flash: [== ] 16.2% (used 212701 bytes from 1310720 bytes)
.pio\build\firebeetle32\firmware.elf :
section
size addr
.rtc.text
0 1074528256
.rtc.dummy
0 1073217536
.rtc.force_fast
0 1073217536
.rtc.data
16 1342177792
.rtc_noinit
0 1342177808
.rtc.force_slow
0 1342177808
.iram0.vectors
1027 1074266112
.iram0.text
50859 1074267140
.dram0.data
13644 1073470304
.ext_ram_noinit
0 1065353216
.noinit
0 1073483948
.ext_ram.bss
0 1065353216
.dram0.bss
2504 1073483952
.flash.appdesc
256 1061158944
.flash.rodata
41336 1061159200
.flash.rodata_noload
0 1061200536
.flash.text
105835 1074593824
.iram0.text_end
1 1074317999
.iram0.data
0 1074318000
.iram0.bss
0 1074318000
.dram0.heap_start
0 1073486456
.xtensa.info
56 0
.comment
166 0
.xt.lit._ZN3nvs4Lock4initEv
0 0
.xt.prop._ZN3nvs4Lock4initEv
72 0
.xt.lit._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv 0 0
.xt.lit._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb
8 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv 108 0
.xt.prop._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb
60 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE9push_backEPS2_
60 0
.xt.lit._ZN3nvs12NVSPartitionD5Ev
0 0
.xt.prop._ZN3nvs12NVSPartitionD5Ev
0 0
.xt.prop._ZN3nvs12NVSPartitionD2Ev
36 0
.xt.prop._ZN3nvs12NVSPartitionD0Ev
36 0
.xt.prop._ZTVN3nvs12NVSPartitionE
12 0
.xt.lit._ZN3nvs19NVSPartitionManagerD5Ev
0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD5Ev
0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD2Ev
36 0
.xt.prop._ZN3nvs19NVSPartitionManagerD0Ev
36 0
.xt.prop._ZN14intrusive_listIN3nvs12NVSPartitionEE5eraseENS2_8iteratorE
84 0
.xt.prop._ZTVN3nvs19NVSPartitionManagerE
12 0
.xt.prop._ZN14intrusive_listIN3nvs8HashList13HashListBlockEE5eraseENS3_8iteratorE 84 0
.xt.lit._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch
0 0
.xt.lit._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj
8 0
.xt.lit._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_
8 0
.xt.prop._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch
0 0
.xt.prop._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj
60 0
.xt.prop._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_
60 0
.xt.prop._ZN3nvs20isVariableLengthTypeENS_8ItemTypeE
48 0
.xt.prop._ZN3nvs4ItemC2EhNS_8ItemTypeEhPKch
60 0
.xt.lit._ZN14intrusive_listIN3nvs4PageEE5clearEv
0 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5clearEv
60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE9push_backEPS1_
60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5eraseENS2_8iteratorE
84 0
.xt.prop._ZTISt9exception
12 0
.xt.prop._ZTISt9bad_alloc
12 0
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE
12 0
.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE
12 0
.debug_frame
53576 0
.debug_info
2574536 0
.debug_abbrev
227268 0
.debug_aranges
21664 0
.debug_ranges
53904 0
.debug_line
1023332 0
.debug_str
228001 0
.debug_loc
399241 0
Total
4798362
<lambda>(["upload"], [".pio\build\firebeetle32\firmware.bin"])
AVAILABLE: ch347, cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = ch347
openocd -d2 -s C:/Users/wgt04/.platformio/packages/tool-openocd-esp32/share/openocd/scripts -f interface/ch347.cfg -f board/esp-wroom-32.cfg -c "adapter_khz 5000" -c "program_esp {{.pio\build\firebeetle32\firmware.bin}} 0x10000 verify" -c "program_esp {{C:/Users/wgt04/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin/bootloader_dio_40m.bin}} 0x1000 verify" -c "program_esp {{C:/Users/wgt04/Documents/PlatformIO/Projects/testE/.pio/build/firebeetle32/partitions.bin}} 0x8000 verify" -c "program_esp {{C:/Users/wgt04/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin}} 0xe000 verify" -c "reset run; shutdown"
Open On-Chip Debugger 0.11.0+dev-00706-g822097a35-dirty (2022-06-08-19:08)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
Info : only one transport option; autoselect 'jtag'
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Warn : Transport "jtag" was already selected
C:/Users/wgt04/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg:50: Error: Unknown target type esp32, try one of arm7tdmi, arm9tdmi, arm920t, arm720t, arm966e, arm946e, arm926ejs, fa526, feroceon, dragonite, xscale, cortex_m, cortex_a, cortex_r4, arm11, ls1_sap, mips_m4k, avr, dsp563xx, dsp5680xx, testee, avr32_ap7k, hla_target, nds32_v2, nds32_v3, nds32_v3m, esp32s2, or1k, quark_x10xx, quark_d20xx, stm8, riscv, mem_ap, esirisc, arcv2, aarch64,
or mips_mips64
in procedure 'script'
at file "embedded:startup.tcl", line 26
at file "C:/Users/wgt04/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/board/esp-wroom-32.cfg", line 3
at file "C:/Users/wgt04/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 50
*** [upload] Error 1
========================== [FAILED] Took 4.54 seconds ==========================
* The terminal process "C:\Users\wgt04\.platformio\penv\Scripts\platformio.exe 'run', '--verbose', '--target', 'upload'" terminated with exit code: 1.
Best regards.
