I plan to use EEProm of the 8266 and I have some questions about it in
advance.
Provided I was able to store data in the EEProm area, what happens if the
code will be updated by PlatformIO programmer? Is the EEPROM contents
still there after new start?
Is it possible to preset the EEProm area with certain data on demand?
The ESP8266 does not have an EEPROM. This is only emulated. The data is stored in a specific area of the flash. When flashing a sketch, the memory area is retained.
Thank you for this information. I intend to save WiFi settings in the
“EEProm” area. Would be not nice to reprogram everything again and again
during program test phase.
See the examples
[/quote]
That is not what I mean. I’m already able to write and read to “EEProm” area
Possibly I did not express my question good enough.
I would like to know if I can load default settings to the “EEProm” area during upload anyhow?
Thank you again. That’s interesting, I didn’t know that. Nevertheless,
to be able to allow different user to setup different network settings via
UART connection, I plan to store them in “EEPROM”.
You can use a file system such as LittleFS to store configuration files on the ESP.
The file system can be flashed to the ESP separately from the firmware.
A good tutorial can be found here:
