i have installed platformio. the ide looks awasome
but i have one problem with "Go To Declaration " is not working for arduino project
can anyone help me. I am using Atom 1.6.0 on MAC. i have imported arduino project with multiples CPP , H file using PlatformIO-> Import arduino IDE. when i click on the code , highlight a class name or function and select Go To Declaration. but it does not goto actual code…
can any one help me…
Jump to declaration is implemented in the latest PlatformIO IDE. Please upgrade.
WE ARE HIGHLY RECOMMEND TO SWITCH TO VSCODE + PLATFORMIO
VSCode has built-in IntelliSense engine with code completion, navigation, formatting, etc. You don’t need to install extra software.
That’s a cool feature to have. Many thanks.
I just wonder if it’s possible to replace [F3] with [Ctrl]+[Left Mouse Button Click]?
We are working on it. We will inform later when this feature will be available.
Hi Ivan,
are there any requirements to use the “Jump to declaration” feature? I freshly installed IDE 1.2.2 and set up a basic Blink sketch. But when I want to jump to the “digitalWrite” declaration for example (using F3 shortkey) nothing happens.
I found out that in the context menu there are two entries: “Goto declaration” and “Go to declaration”. Might there be a conflict that prevents the feature from working?
Best regards,
Thomas
Is your sketch with *.cpp/*.c
extension?
Yes. The source file is named “Blink.cpp” and contains the default Arduino Blink example - just with the additional “Arduino.h” include.
Unfortunately I cannot find any Atom syslog file to find out what’s going on…
- Try
Menu: PlatformIO > Rebuild C/C++ index
- Does autocompletion work?
Index is rebuilt and auto completion does work flawlessly. It’s just as if F3 is not bound to anything - but it is as settings menu shows…
Did you try 2 different “Go to declarations” from the context menu?
I did. The “Goto Declaration” item highlights the method the cursor in on, the “Go to Declaration” doesn’t do anything a all.
Please provide:
- OS type
- The source code of
platformio.ini
- The log output (
Menu: View > Developer > Toggle Developer Tools > Console
Thanks.
OS Type:
Windows 10 64bit
platform.ini
[env:nanoatmega328]
board = nanoatmega328
Log:
In file included from <stdin>:16:
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:155:23: warning: unknown attribute __progmem__ ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_mode_PGM[];
autocomplete-clang.coffee:87 C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:109:17: note: expanded from macro 'PROGMEM'
#define PROGMEM __ATTR_PROGMEM__
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:95:41: note: expanded from macro '__ATTR_PROGMEM__'
#define __ATTR_PROGMEM__ __attribute__((__progmem__))
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:156:23: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_input_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:157:23: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_output_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:159:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_port_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:161:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[];
autocomplete-clang.coffee:87 C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:95:41: note: expanded from macro '__ATTR_PROGMEM__'
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:162:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_timer_PGM[];
autocomplete-clang.coffee:87 In file included from <stdin>:16:
In file included from C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:225:
In file included from C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino/USBAPI.h:27:
In file included from C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay.h:43:
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay_basic.h:108:5: error: invalid output constraint '=w' in asm
: "=w" (__count)
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay.h:95:3: warning: "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed" [-W#warnings]
# warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
autocomplete-clang.coffee:87 7 warnings and 1 error generated.
@valeros has just checked it under Windows and reported that this feature does not work. @DerTomm please open an issue here: GitHub - platformio/platformio-atom-ide: PlatformIO IDE for Atom: The next generation integrated development environment for IoT
P.S: It works very well under Unix.
Done.
Good to know
Hello, are there any news on this issue?
We work on the big update for PlatformIO IDE 2.0. I hope after that we will resolve this issue.
This is good to know, is there an estimate release date?
It will be good to have first public beta this year
@ivankravets unfortunately I was a bit busy and I didn’t had the chance to check the progress on this issue.
Has the beta been released to the public? Is the feature working on windows?
I really like this feature when I have a lot of code lines written
