Wondering if anyone has any ideas, I am trying to use : GitHub - Wiznet/ioLibrary_Driver: ioLibrary_Driver can be used for the application design of WIZnet TCP/IP chips as W5500, W5300, W5200, W5100 W5100S. in a project but when I add it into platformio.ini
with
https://github.com/Wiznet/ioLibrary_Driver
and try to compile a test program :
#include <socket.h>
uint8_t sn = SOCK_STREAM;
uint8_t protocol;
uint16_t port = 80;
uint8_t flag;
int8_t mysock = socket( sn,
protocol,
port,
flag);
} // setup
} // loop
I get errors :
.piolibdeps/ioLibrary_Driver/Ethernet/W5500/w5500.h:52:26: fatal error: wizchip_conf.h:
No such file or directory
So then, I’ve tried creating sub subdirectories under lib for “socket” and “wizchip_conf”
and copying the files from within ioLibrary_Driver/Ethernet into them but then get link error :
/tmp/ccqV4NwF.ltrans0.ltrans.o: In function main': ccqV4NwF.ltrans0.o:(.text.startup+0x90): undefined reference to
socket(unsigned char,
unsigned char, unsigned int, unsigned char)’
Does socket have to be compiled into an object file and linked (how?)
or is there something else I’m doing wrong or perhaps I could also if the wiznet ioLibrary_Driver can be added to the official PlatformIO list?
Many Thanks.
