I have a problem with sysenv variables. I have not change my code but I cant charge the values of wifi ssid and password.
My platformio.io file:
-DWIFI_SSID=${sysenv.WIFI_SSID}
-DWIFI_PASS=${sysenv.WIFI_PASSWORD}
My src/main.cpp
#define WIFI_SSID "asd"
#define WIFI_PASS "asd"
delay(WIFI_DELAY);
Serial.println("Conectando al wifi...");
Serial.println(WIFI_SSID);
The result:
asd
asd
asd
asd
If I build from command line and y do a echo $WIFI_SSID they are correctly setted.
Complete code: GitHub - dbgjerez/iot-esp8266-irrigation-system: System to measure ground humidity
Thanks a lot
How do you change the environment variables?
You do restart VSCode after that too?
I have wrote them into my .bashrc. It was working along some weeks, but today…
$ cat ~/.bashrc | grep WIFI*
export WIFI_SSID="MiFibra-32FD"
export WIFI_PASSWORD="mypassword"
I have restart VSCode, my computer and I have build from command line too. :frowning:
Have you logged out and logged in your user account to apply changes to that file?
Yeah, I put them almost one month ago, and it was working.
For example, in new terminal:
$ echo $WIFI_SSID
MiFibra-32FD
Have you removed those lines
otherwise you’re redefining it.
Also per docs you might need to have to shell-escape the environment variable.
Thanks bro!
I have delete those lines and escape the environment variable:
export WIFI_SSID='\"MiFibra-32FD\"'
I dont understand how it was working before, but thanks a lot
