IDE: Clion
PIO Core : 3.6.7
Cannot work out why I cant get the wifi examples to work properly.
I have managed to get basic things like the OLED to work but its struggling to find the correct WiFi.h header.
Source code has been trimmed to get wifi working, hence the other libraries.
using ArduinoIDE I have managed to get it to work, just not in CLion with platformio.
EDIT
Following some more investigation I am not sure that the toolchain is being installed correctly:
thanks in advance
platformio.ini
[common_env_data]
lib_deps_builtin =
SPI
Wire
322
83
Time
;other env removed for clarity
[env:heltec_wifi_kit_32]
board = heltec_wifi_kit_32
board_build.mcu = esp32
architectures=esp32
${common_env_data.lib_deps_builtin}
${common_env_data.lib_deps}
https://github.com/HelTecAutomation/Heltec_ESP32.git
https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series.git
src_filter =
+<main_esp.cpp>
upload_port=
COM9
Compiler output
Processing heltec_wifi_kit_32 (framework: arduino; platform: espressif32; board: heltec_wifi_kit_32)
Detected non-PlatformIO `architectures` option in `[env:heltec_wifi_kit_32]` section
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/heltec_wifi_kit_32.html
PLATFORM: Espressif 32 > Heltec WiFi Kit 32
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Collected 42 compatible libraries
|-- <SPI> 1.0
|-- <Wire> 1.0.1
|-- <DS1307RTC>
| |-- <Time> 1.5
| |-- <Wire> 1.0.1
|-- <SdFat> 1.1.0
| |-- <SPI> 1.0
|-- <RTClib> 1.2.1
| |-- <Wire> 1.0.1
|-- <Time> 1.5
|-- <Heltec_ESP32> 1.0.6 #9b5088b
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
|-- <WiFi_Kit_series> #c7bf261
Compiling .pioenvs\heltec_wifi_kit_32\src\main_esp.cpp.o
Archiving .pioenvs\heltec_wifi_kit_32\libfe0\libSPI.a
Archiving .pioenvs\heltec_wifi_kit_32\lib487\libWire.a
Indexing .pioenvs\heltec_wifi_kit_32\libfe0\libSPI.a
Archiving .pioenvs\heltec_wifi_kit_32\lib66a\libTime_ID44.a
Indexing .pioenvs\heltec_wifi_kit_32\lib487\libWire.a
Archiving .pioenvs\heltec_wifi_kit_32\libc15\libDS1307RTC_ID421.a
Indexing .pioenvs\heltec_wifi_kit_32\lib66a\libTime_ID44.a
Indexing .pioenvs\heltec_wifi_kit_32\libc15\libDS1307RTC_ID421.a
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\MinimumSerial.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SdCard\SdSpiCard.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SdCard\SdSpiCardEX.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SdCard\SdioCardEX.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SdCard\SdioTeensy.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SpiDriver\SdSpiESP8266.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SpiDriver\SdSpiParticle.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SpiDriver\SdSpiSAM3X.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SpiDriver\SdSpiSTM32.cpp.o
In file included from src\main_esp.cpp:154:0:
src\main_esp.h:15:18: fatal error: WiFi.h: No such file or directory
* Looking for WiFi.h dependency? Check our library registry!
* CLI > platformio lib search "header:WiFi.h"
* Web > https://platformio.org/lib/search?query=header:WiFi.h
compilation terminated.
Compiling .pioenvs\heltec_wifi_kit_32\liba6d\SdFat_ID322\SpiDriver\SdSpiTeensy3.cpp.o
Compiling .pioenvs\heltec_wifi_kit_32\lib330\RTClib_ID83\RTClib.cpp.o
*** [.pioenvs\heltec_wifi_kit_32\src\main_esp.cpp.o] Error 1
[ERROR] Took 7.04 seconds
mingw32-make.exe[3]: *** [CMakeFiles\PLATFORMIO_BUILD.dir\build.make:56: CMakeFiles/PLATFORMIO_BUILD] Error 1
mingw32-make.exe[2]: *** [CMakeFiles\Makefile2:104: CMakeFiles/PLATFORMIO_BUILD.dir/all] Error 2
mingw32-make.exe[1]: *** [CMakeFiles\Makefile2:116: CMakeFiles/PLATFORMIO_BUILD.dir/rule] Error 2
mingw32-make.exe: *** [Makefile:130: PLATFORMIO_BUILD] Error 2
main_esp.h
#ifndef CONDITION_MONITORING_ESP_H
#define CONDITION_MONITORING_ESP_H
#include "Arduino.h"
#include "heltec.h"
#include "images.h"
#include "board_pins.h"
#include "build_defs.h"
#include "staffa.h"
//#include "Ota.h"
#include "WiFi.h"
//#define LED 25
extern Heltec_ESP32 Heltec;
extern WiFiClass WiFi;
//void WIFIScan(void);
#endif //CONDITION_MONITORING_ESP_H
main_esp.cpp
#include "main_esp.h"
// WiFi credentials.
const char* WIFI_SSID = "wifi-ssid";
const char* WIFI_PASS = "wifi-password";
void setup()
Serial.begin(9600);
// Giving it a little time because the serial monitor doesn't
// immediately attach. Want the firmware that's running to
// appear on each upload.
delay(2000);
Serial.println();
Serial.println("Running Firmware.");
// Connect to Wifi.
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(WIFI_SSID);
// Set WiFi to station mode and disconnect from an AP if it was previously connected
// WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
WiFi.begin((char*) WIFI_SSID, WIFI_PASS);
Serial.println("Connecting...");
// Check to see if connecting failed.
// This is due to incorrect credentials
if (WiFi.status() == WL_CONNECT_FAILED) {
Serial.println("Failed to connect to WIFI. Please verify credentials: ");
Serial.println();
Serial.print("SSID: ");
Serial.print("Password: ");
Serial.println(WIFI_PASS);
Serial.println();
delay(5000);
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println("Hello World, I'm connected to the internets!!");
void loop()
delay(5000);
Serial.println("Hello World");
